Old 24th January 2014, 18:03   #511
rlg
Thanked: 48 Times
My bosch aquatak 100 went completely dead last week. It had hardly had an hour of use cumulatively in almost an year since I bought it. Checked the warranty and found it was just for 6 months. After a few choicest words for Robert Bosch and his grand father, I decided to open it.
There is a pressure switch which was the first suspect.
Sure enough it was stuck open. There is a small brass pin which actuates the switch. Pushed it down and put a tiny drop of oil to lubricate it. The picture was taken after pushing it down.
It works fine now. For now I did not open any plumbing fearing leaks. But if it happens again, I'll open it and spray silicon on the O-rings.
rlg is offline   (4) Thanks Reply With Quote
Old 25th January 2014, 14:21   #512
Thad E Ginathom's Avatar
Thanked: 7,481 Times
Default Re: Buying & Using a Pressure Washer
Thank you. Yesterday I could not see your pics, but today they are showing up. This is useful information to remember for the future.
My Aquatak failure is the spray trigger. It is mostly stuck open. I just live with it, as I'm not enthusiastic about taking it apart --- but probably some lubrication is all that is needed.
Old 25th January 2014, 23:40   #513
a_myth's Avatar
Thanked: 23 Times
Thinking of buying a pressure washer myself. After going to countless threads, looks like Karcher is the most preferred brand. However this brand does not have any support centre in Goa (where i live), hence had to look for other options.
A shop in Panaji is quoting a price of @Rs.8.2k for Black and Decker entry level washer (not aware of the model). While going through some online shopping sites came across this, B&D PW1570TD for Rs. 8.5k.
http://www.flipkart.com/black-decker...9-fa056de14ab0
Should i go for it?????
a_myth is offline   Reply With Quote
Old 25th January 2014, 23:50   #514
Bluu's Avatar
Thanked: 85 Times
I live on the 14th floor of an apartment complex which does not have any convenient points where I can wash my bike. The 390 is notoriously easy to get filthy and I'm at my wit's end to find a solution to easily wash the bike apart from using multiple buckets of water which are inconvenient and don't provide satisfactory results since there is no pressure.
A couple of days ago, some chaps had come to my house to spray the liquid that kills bees on to a hive which had formed near my bedroom balcony. I noticed that the guy was using a non-electric, hand operated pump. He filled up water and then pumped the device a few times and got a decent spray to a distance of about 8 ft.
My questions are:
1. Can this device be used to wash a bike? Will it generate enough pressure to clean the hard to reach places?
2. If yes, where can I purchase it from?
MODS: My question is about an "analog" pressure washer but please move if this is the wrong thread.
Bluu is offline   Reply With Quote
Old 26th January 2014, 01:19   #515
diyguy's Avatar
Thanked: 124 Times
I doubt that generates enough pressure to blow mud away. There are some petrol/diesel operated pressure washers that you can consider. There was a discussion many pages back...
diyguy is offline   Reply With Quote
Old 26th January 2014, 11:06   #516
archat68's Avatar
Thanked: 242 Times
Since you live in a 14 storeyed building you'll have very good pressure at the parking space. You can simply add pressure nozzles like this to a PVC pipe and that will be sufficient to generate ample pressure to wash your car/bike.
http://www.ebay.in/itm/IMPORTED-PRES...item2c7b59cefd
http://www.ebay.in/itm/Water-Zoom-Hi...item3f2f275afc
You can also buy this type pressure nozzle from aliexpress.com (better quality at lesser price). Try to find a all brass one.
Check these:
http://www.aliexpress.com/item/Car-w...897845838.html
http://www.aliexpress.com/item/New-P...658739728.html
http://www.aliexpress.com/item/Water...888243575.html
archat68 is offline   Reply With Quote
Old 26th January 2014, 11:24   #517
Sebring's Avatar
Thanked: 846 Times
The advantage with Karcher is that (it says on the pack), it saves 80% of water by releasing high pressure water droplets. I find it very effective on wheel wells.
Rest of the car is (Could be) taken care of by the watchman.
Sebring is offline   Reply With Quote
Old 26th January 2014, 12:52   #518
samarth.bhatia's Avatar
Thanked: 292 Times
When you use such a device, the energy that is generated by the manual pumping mechanism is minuscule. At best, it can help generate maybe 3 Bars of pressure, and flowrate is not affected at all.
For cleaning vehicles effectively, you require atleast 80 to 90 Bars of pressure, and a flowrate over 5 Litres per minute is helpful too.
I've said this earlier as well, water pressure will define the effectiveness with which the spray will attack the mud/other items stuck to the surface, while flowrate will determine the SPEED with which the areas are cleaned. You need a combination of both. And that's possible on an optimum power consumption:effectiveness ratio by High Pressure Washers.
Originally Posted by archat68 View Post
What these nozzles attached to a garden hose will do is increase the output pressure, by reducing the size of the opening (thus reducing the flowrate). Again, the output pressure is generally 2 Bars, if its really good, and that will increase to about 4 Bars by these nozzles, while flowrate of 20 LPM, will reduce to about 15 LPM.
This will not make them as effective as you'd want, while still you will end up using more water everytime you wash the vehicle.
The advantage with Karcher is that (it says on the pack), it saves 80% of water ...
This fact is true, and applies to almost all high pressure washers. You can read my inputs on this here (Buying & Using a Pressure Washer).
Cheers,
Sam
samarth.bhatia is offline   (3) Thanks Reply With Quote
Old 26th January 2014, 13:40   #519
scopriobharath's Avatar
Thanked: 1,226 Times
My questions are:
The spray is sufficient to dislodge grit and grime say under the hood/bonnet. it can be used to spray soap but not powerful enough to "wash" the bike.
if money is not a constraint, but Karcher K3.550 which has bucket suction. it retails for around 17,000/-
scopriobharath is online now   (1) Thanks Reply With Quote
Old 26th January 2014, 14:54   #520
archat68's Avatar
Thanked: 242 Times
Cheers,
Sam
WHen there is no way to use a pressure washer this type of nozzles are the best thing. Specially in a 14 stoereyed building which will have already sufficient water pressure at the basement. Use one and see. This may not not helpful in dislodging caked out mud but those can be taken care of by spraying some diluted shampoo and soaking a few minutes and then attacking with water spray.
The water nozzles are far better than the manual pressure pumps which the OP suggested.
BTW I do have a pressure washer - these are a nifty tool but where there is no power these are useless.
Old 26th January 2014, 20:20   #521
Thanked: 292 Times
I agree with the fact that these can be used to spray the liquid soap solution. That will then need to be followed by manually scrubbing the surface with a microfiber sponge / cloth for effective cleaning of bird droppings/sticky things.
And then ofcourse the surface will have to be washed with plain water, to remove the dirt plus soap, and then dried.
samarth.bhatia is offline   Reply With Quote
Old 26th January 2014, 22:31   #522
I have not done this, but I remember this hint...
Carry some small bottles of carbonated (fizzy) water in the car. In case of bird droppings, open bottle, place thumb over opening and shake hard. Then squirt the bird dropping. (and the bird if it looks like it is going to do it again ).
I vaguely remember something about the fizzy water being alkaline, and therefore good to neutralise acids. Could this be true? Are bird droppings acidic? The certainly seem to be able to eat into surfaces.
Old 27th January 2014, 11:05   #523
Thanked: 613 Times
Fizzy water or carbonated water is composed of water and carbon dioxide and is actually carbonic acid. So it won't help neutralise the uric acid in bird droppings. What would help is baking soda which is a base and mildly alkaline. Mix a small amount with water to form a watery paste and apply on the bird dropping. Wipe away after the dropping has softened.
Motard_Blr is offline   (4) Thanks Reply With Quote
Old 27th January 2014, 12:08   #524
SunnyBoi's Avatar
Thanked: 2,796 Times
I keep some QD solution in a Mr Muscle spray bottle. It has got a strong stream, sufficient enough to peel off the bird poo without having to scrape it off. I make it a point to take off the poo as soon as possible; every hour counts.
SunnyBoi is offline   (2) Thanks Reply With Quote
Old 9th February 2014, 22:44   #525
Thanked: 15 Times
How is Hymatic Pressure washer.. HYM-VA-90.. It comes with Induction motor unlike the carbon brush motors of others..
Pressure: 90bar(1300psi)
Max Pressure: 160bar
Flow: 6L/min(1.6GPM)
Motor: 1850W
Voltage: 230V-50Hz 120V~50Hz-60Hz
Weight: 15kgs
Dimensions: 84*35*33cm
PRICE : - Rs. 5500/-
Weight is more than your regular brands but it does have wheels...
wolf_lone is offline   (1) Thanks Reply With Quote
Rear Wiper & Washer ? Why only on hatch backs and NOT on sedans? Kinetik Technical Stuff 64 22nd November 2016 13:25
VW Polo DIY: Windshield washer low-level sensor & dash warning Gannu_1 DIY - Do it yourself 27 27th August 2016 08:53
Convert Air compressor to a Pressure water washer? rajivanoj Technical Stuff 5 3rd February 2014 00:45
The 'Actual' Tyre Pressure : Is Atmospheric Pressure Counted? sr_1445 Technical Stuff 2 16th January 2014 11:05
High pressure car washer using air compressor recshenoy Modifications & Accessories 2 1st October 2009 09:59
