Old 20th July 2014, 13:06   #601
Raghav_K's Avatar
Thanked: 69 Times
Default Re: Buying & Using a Pressure Washer
Yes i did try reducing the water pressure by half-closing the tap. Will get one of these from a hardware store and try again.
Thanks!
Raghav_K is offline   Reply With Quote
Old 20th July 2014, 14:18   #602
sagarpadaki's Avatar
Thanked: 1,272 Times
Originally Posted by Raghav_K View Post
Guys, I went ahead and bought the Black & Decker PW 1570TD car washer.
The problem is my hose pipe fits very tightly on the tap outlet and not so tight but firm on the pump inlet (Image attached).
So when i stop the Water gun the hose pipe pops off from the inlet.
Would getting a smaller diameter pipe do the trick, or do i need any attachments at the tap end/pump end?
What do you use with your pump?
Originally Posted by diyguy View Post
Did you try reducing the pressure on pipe by closing the tap a bit?
However, I use a combination of the green garden hose adapters in the picture attached, on both ends of the hose. It clicks and locks on.Attachment 1263778
You have to use the attachment shown above by diyguy in the pics.
If you have a Bosch dealer who deals in aquatak then you can buy from them. Mostly they will have it.
@diyguy, can you share where you purchased these connector?
Last edited by khan_sultan : 22nd July 2014 at 09:08. Reason: Edited spaces for better readability
Old 20th July 2014, 14:48   #603
diyguy's Avatar
Thanked: 124 Times
I got the connectors at Metro in Bangalore. I tried looking for them in many places in Chennai, including the tools market and the garden hose and accessories market, but didnt find them here. Not tried at a Bosch dealer though... recently my wife lost one of my short pipes with these connectors on both ends and I was really annoyed, as I did not seem to find these in any stores and without these, using the pressure washer is a pain...however, found the hose a week later and was relieved...
diyguy is online now   Reply With Quote
Old 21st July 2014, 00:04   #604
Thad E Ginathom's Avatar
Thanked: 7,481 Times
The click-lock type connectors are very hard to find.
Old 21st July 2014, 07:29   #605
Raghav_K's Avatar
Thanked: 69 Times
These guys seem to have it @ 175 each. Have sent them an enquiry.
http://www.ecotechsolutions.in
But seems they minimum ordering quantity is 3, so i will send off the spare ones to anyone in need of them here
Disclaimer: Definitely not related to them, Else would be getting it for free . Kindly remove link if against rules
The quick connector is not available in any of the nearby hardware stores. Have to order online.
For the time being, got these clamps from the hardware stores at 30 Rs per piece. They kept the hose in place, while i did my first pressure car wash. Have to rotate the screw twice to tighten or loosen.
Note to mods: Unable to edit the previous post, hence double posting. Kindly Merge.
Last edited by khan_sultan : 22nd July 2014 at 09:06. Reason: As requested. One logical post
Old 22nd July 2014, 08:10   #606
diyguy's Avatar
Thanked: 124 Times
I got them for 60rs each initially and recently for 90. Wish my salary rises that much in a 15 month time frame...
Old 22nd July 2014, 09:47   #607
Have you tried contacting any bosch dealers selling aquatak in Chennai? Bosch has them as an official accessory priced @ 84 bucks. Comes in black. Fits all.
sagarpadaki is offline   (1) Thanks Reply With Quote
Old 22nd July 2014, 10:24   #608
archat68's Avatar
Thanked: 242 Times
Get the connectors from Aliexpress. They are reliable. I bought lots of items from them some of them are quite costly. It will take about 30-45days to reach you.
http://www.aliexpress.com/item/Free-...872340011.html
http://www.aliexpress.com/item/Garde...897755418.html
The last one seems to be very well priced considering it is made of brass.
archat68 is online now   (1) Thanks Reply With Quote
Old 22nd July 2014, 12:50   #609
Raghav_K's Avatar
Thanked: 69 Times
The guys at Ecotech did not care to reply to my mail, so not gonna bother with them.
Will search for a local bosch dealer, or will get from Aliexpress. (I too have bought from them before, good service, except for the delivery time)
These connectors take care of the pump end i guess, what about the tap end? I have a regular tap with no threads. That has to be changed?
Old 25th July 2014, 16:44   #610
rlg
Thanked: 48 Times
Have bought the same one in diyguy's post from Total mall in bangalore last year.
rlg is offline   Reply With Quote
Old 31st July 2014, 19:02   #611
kutlee's Avatar
Thanked: 194 Times
After contemplating much, went ahead and bought assembled washer. Planning to install outside the building. The working is very silent. 1hp motor turns the pump, sucks water from bucket. When spray gun is closed water returns to the bucket. gives good pressure throw and reach. can adjust spray from fan to needle pattern.
kutlee is offline   (6) Thanks Reply With Quote
Old 31st July 2014, 23:10   #612
Thanked: 45 Times
Default Buying & Using a Pressure Washer
This is sweet. Hope it turns out to be reliable. How much did you end up paying for this unit?
Vento TDI 1.6
thenomad is online now   Reply With Quote
Old 1st August 2014, 07:22   #613
kutlee's Avatar
Thanked: 194 Times
cost is around 21k. will post a video.
kutlee is offline   Reply With Quote
Old 1st August 2014, 14:11   #614
scopriobharath's Avatar
Thanked: 1,226 Times
Congrats on the Purchase Kutlee. Couple of questions from my side, please help with answers as it might benefit others too.
  • Why did you choose a local brand, As Karcher K3.550 is avaiable for 18K. KArcher is cheaper and also a "brand"
  • if we release the trigger in neutral position, does the motor and pump stop or do they keep running and keep building up pressure?
  • Any link / shop from where you purchased it?
scopriobharath is online now   Reply With Quote
Old 1st August 2014, 15:18   #615
kutlee's Avatar
Thanked: 194 Times
any brand off the shelf home washer is direct driven. (there are some small capacity air compressors also that are direct driven and very noisy). This means the pump operates at same rpm as motor (which normally is higher than required to operate the pump). Why this is done is simply to save space. One example where belt is still used is home wet grinder. we know how space taking it is. My pump is slow speed. hence very silent, happily pumps at slow speed. Does not walk around like a usual home pressure washer (my exp with Skil walking around making noise was bad). My assembled washer can be repaired or damaged part can be replaced without any haggle. This washer also cannot be used for professional use. But for light applications it should suffice. The water is simply returned to tank when gun is closed. I know shops using professional grade Karcher and complained about service support.
kutlee is offline   (2) Thanks Reply With Quote
Rear Wiper & Washer ? Why only on hatch backs and NOT on sedans? Kinetik Technical Stuff 64 22nd November 2016 13:25
VW Polo DIY: Windshield washer low-level sensor & dash warning Gannu_1 DIY - Do it yourself 27 27th August 2016 08:53
Convert Air compressor to a Pressure water washer? rajivanoj Technical Stuff 5 3rd February 2014 00:45
The 'Actual' Tyre Pressure : Is Atmospheric Pressure Counted? sr_1445 Technical Stuff 2 16th January 2014 11:05
High pressure car washer using air compressor recshenoy Modifications & Accessories 2 1st October 2009 09:59
