Old 5th October 2014, 09:58   #676
arun_sharon's Avatar
Thanked: 24 Times
Default Re: Buying & Using a Pressure Washer
Originally Posted by Twiny View Post
My car park is about 30m away from the tap. I wanted to keep the machine inside my apartment (which is one level higher to the car park) near the tap and run only the pressure hose for easiness. Do any brands have got Extension pressure hose of 25-30m length. I don't mind loosing some pressure due the length.
You will get the extension pressure hose from karcher. This might work out for you.
arun_sharon is offline   (1) Thanks Reply With Quote
Old 5th October 2014, 23:41   #677
Shubz's Avatar
Thanked: 989 Times
I ordered THIS on Oct-1 along with This
I got delivery of the second item, awaiting the first. How I wish I had got the washer before the Ayudha Pooja!
Shubz is offline   (1) Thanks Reply With Quote
Old 6th October 2014, 11:01   #678
n_aditya's Avatar
Thanked: 2,755 Times
So I finally got around to use the new B&D pressure washer last week.
My earlier posts list the experience i went through where the first B&D unit i bought suffered a motor burn out. The executive at Metro had replaced the unit but I had no time to use it owing to busy schedules. I also wanted to buy a longer and better quality hose pipe.
Thanks to the holidays this past week, I got around to buying a 25 meter pipe (more than enough length) for around 500 bucks from a local hardware shop in the neighborhood.
I was skeptical using the washer this time given my prior experience.
Thankfully I faced no issues and I comfortably washed, shampooed and rinsed all vehicles in my garage with the new unit.
n_aditya is offline   (1) Thanks Reply With Quote
Old 28th October 2014, 12:01   #679
vindrider2626's Avatar
Thanked: 45 Times
Originally Posted by james View Post
I ended up buying it through ebay. Paid a few rupees shy of 7k for a k2.120. I had some major issues with ebay payment etc. Finally paid for it on Monday and i hope to get it by wednesday. Its coming all the way from CH via FEDEX!
The only consolation is that the seller was very helpful and provided answers to all my questions. He also contacted me directly to tell me that its been shipped and provided me with the tracking number although ebay also does the same.
http://www.ebay.in/itm/Karcher-2-120...item4d0e5514b0
Hlo James,recently bought a karcher pressure washer and have not used it till now,but reading opinions about not to use dirt blaster on car body, am a bit confused about how to find the proper pressure lance for cleaning.Any help appreciated by all.Do i need to buy a variable pressure lance from karcher as an add on?
vindrider2626 is offline   Reply With Quote
Old 28th October 2014, 20:31   #680
james's Avatar
Thanked: 541 Times
Hello! Ive been using both, the normal lance as well as the dirt blaster on my cars. I just make sure i dont hold the dirt blaster too close to the body. I start from 3 feet away and move closer if the dirt refuses to budge. I use the dirt blaster only for the lower part of the car to get rid of heavy particles that may have been thrown up by the tyres.
I wouldn't want to invest in a vario lance. I can do pretty much the same with the 2 lances provided with the kit although interchanging them every now and then can get cumbersome!
james is offline   (1) Thanks Reply With Quote
Old 28th October 2014, 21:55   #681
Thanked: 45 Times
James ,how do you connect the hose to the pressure washer?What type of connecter do you use for connecting the machine to the tap?Here i cant find anything which suits most.Please throw some light on this too.
Old 29th October 2014, 03:07   #682
Thad E Ginathom's Avatar
Thanked: 8,341 Times
Strongly advise that you do not use high pressure or high-pressure lance on any part of your car. It really can do damage.
If dirt refuses to budge, just use a microfibre cloth or soft-bristle brush.
Old 29th October 2014, 07:32   #683
james's Avatar
Thanked: 541 Times
I use a span-on adapter that i picked up from a local hardware store. I managed to get it by fluke. None of my friends managed to source it post that which leads me to believe that not many people stock them. Im sure you'll find one in big hardware stores in metros. You could try searching online.
Thad, thats precisely what i dont want to do. I dont want to use any cloth or brush to dislodge dirt on the body. Using the dirt blaster from a safe distance is fine imo.
james is offline   Reply With Quote
Old 29th October 2014, 22:22   #684
Is there anything in the manual? There was a strong warning in the manual of my now-dead Bosch.
Why do you not want to use cloth or brush? Is it because of potential damage to the paint? That is certainly why I favour pressure washer for removal of the general abrasive dust layer, but combine that with high pressure and you have a sand blaster!
It is amazing how some marks, or particles of bird crap, etc, seem to resist the spray. It is almost unbelievable! I used to just dislodge them with my finger tip --- bt well away from the spray jet, of course.
Old 29th October 2014, 22:41   #685
::CMS::'s Avatar
Thanked: 470 Times
Be very careful with the jet, as it can be dangerous, has the potential to cut into your flesh at the max pointed setting.
::CMS:: is offline   Reply With Quote
Old 6th November 2014, 11:58   #686
quadra's Avatar
Thanked: 58 Times
Came across this product on naaptol.com. For 4k, it seems to good.
quadra is online now   (1) Thanks Reply With Quote
Old 9th November 2014, 23:50   #687
Thanked: 232 Times
I actually bought this last month. I thought it would be a cheap product but the quality turned out to be pretty good. It is by no means a pressure washer but it's great for cleaning your car even if it is coated with dirt. The hose has an adjustable nozzle that sprays water either as a gentle shower or as a pressure stream. I think the specification is it can spray up to 40 psi. It's also great because it has a water tank. This is a boon for me because in my apartment complex using a hose pipe to wash cars is banned!
The motor hooks up to the 12V socket in the car. The lengths of the wire and the hose pipe are very decent. I clean my car once a week with this and it works great.
bowser is offline   (4) Thanks Reply With Quote
Old 13th November 2014, 01:24   #688
thewhiteknight's Avatar
Thanked: 199 Times
For anyone in the market for one of these, the Bosch AQT 35-12 1500-Watt is coming up on the Amazon daily sale tomorrow at 10. Currently priced at 89xx. Should see a decent drop hopefully.
thewhiteknight is offline   (1) Thanks Reply With Quote
Old 29th November 2014, 19:42   #689
S_U_N's Avatar
Thanked: 383 Times
Black & Decker PW1570TD B101 Home & Car Washer is available for Rs. 5118.
http://www.flipkart.com/black-decker...m1=16CL1Xdeals
Is it a good and reliable product? Warranty is only 6 months.
S_U_N is offline   Reply With Quote
Old 2nd December 2014, 23:31   #690
Thanked: 46 Times
So during wash you have to keep one of the windows open for the power cord to pass?
wishnipon is offline   Reply With Quote
Rear Wiper & Washer ? Why only on hatch backs and NOT on sedans? Kinetik Technical Stuff 64 22nd November 2016 13:25
VW Polo DIY: Windshield washer low-level sensor & dash warning Gannu_1 DIY - Do it yourself 27 27th August 2016 08:53
Convert Air compressor to a Pressure water washer? rajivanoj Technical Stuff 5 3rd February 2014 00:45
The 'Actual' Tyre Pressure : Is Atmospheric Pressure Counted? sr_1445 Technical Stuff 2 16th January 2014 11:05
High pressure car washer using air compressor recshenoy Modifications & Accessories 2 1st October 2009 09:59
