Old 6th March 2015, 14:48   #766
diyguy's Avatar
Thanked: 181 Times
Default Re: Buying & Using a Pressure Washer
Originally Posted by wolf_lone View Post
Guys is this accessory good enough or a cheaper workaround is available for such use..
http://www.ebay.in/itm/Karcher-sucti.../231497246998?
Price is indeed steep..
An ordinary garden hose is sufficient for the model you have. I have something like this as well as a garden hose.
http://www.groupon.co.in/deals/shopp...-x-hose/723709
diyguy is online now   Reply With Quote
Old 6th March 2015, 16:32   #767
Thanked: 15 Times
Originally Posted by AWD View Post
I guess this particular accessory is for pumping water out from a reservoir. Yes Karcher prices are too steep. Extension hose costs upwards of 5k I guess.
Why opting for this accessory ? No direct/tank supply ?
Will be needing this when overhead tank needs cleaning. Will have to draw water from a water butt since the supply would be disconnected from overhead tank.... Extension hose prices have increased on eBay from 5.5k last month to 6.89k right now..
I will be postponing extension hose purchase & maybe try to get it from Dubai instead where prices are only slightly cheaper..
This accessory is specifically used to lift stagnant water from a water butt since it has a non return valve. Is there any other accessory (non Karcher) for this purpose... Maybe a DIY workaround..
wolf_lone is offline   Reply With Quote
Old 6th March 2015, 16:39   #768
diyguy's Avatar
Thanked: 181 Times
I use the garden hose to suck water out of a bucket of water. If that is similar to your scenario you won't need the non return valve
Old 6th March 2015, 19:56   #769
Thanked: 15 Times
This is the exact same scenario.. So I guess a non return valve is not of much use..
How long can you use the machine in such a setup in one go.. Also any dos & dont's to follow to avoid damaging the motor..
Do you keep the bucket at the level of the pressure washer..
Old 6th March 2015, 20:47   #770
diyguy's Avatar
Thanked: 181 Times
The bucket can be anywhere, the motor sucks the water and for a few seconds running dry is not a problem. I actually used it continually as there was a tap filling the bucket as it was being emptied by the pressure washer
Old 7th March 2015, 10:50   #771
arun_sharon's Avatar
Thanked: 24 Times
I am using an inlet pipe of a washing machine for drawing the water from a bucket to my3.500. This has a lockable head which is an exact match for the Karcher inlet module. The other end of the pipe will be a threaded femail connector which can be used to extend if needed. The washing machine inlet pipe is 300 rs and will be vfm for the requirement.
arun_sharon is offline   Reply With Quote
Old 7th March 2015, 14:01   #772
rm_arjuna's Avatar
Thanked: 55 Times
Hi could you pls post some pics
rm_arjuna is offline   Reply With Quote
Old 8th March 2015, 00:28   #773
Thanked: 15 Times
This is interesting. I've an old IFB washing machine inlet pipe laying around.. I suppose I can use that as well..
Please put some pics as well.. Preferably in action...
Old 8th March 2015, 15:00   #774
Thanked: 24 Times
Its straight forward. The end which goes to tap on a washing machine needs to goto the inlet nipple of karcher.
arun_sharon is offline   (2) Thanks Reply With Quote
Old 9th March 2015, 18:27   #775
Thanked: 15 Times
^.. Good.. I have slightly different pipe setup which will be screwed directly to inlet..
Also for those who require Quick Connect for their pressure washers.. Its now available on AMAZON India & also quite cheap compared to Karcher accessory..
Only Rs. 110/- per piece.. TRAMONTINA which is a very good brand Made in Brazil. Using it myself...
http://www.amazon.in/Tramontina-7850.../ref=pd_cp_k_0
Another option with hose nozzle included ... Also imported, from GreenAge. Have used other products of same company..
http://www.amazon.in/DRIP-IRRIGATION...BHC8K28E4WMTWW
wolf_lone is offline   (5) Thanks Reply With Quote
Old 13th March 2015, 20:57   #776
Thanked: 15 Times
Exclamation Re: Buying & Using a Pressure Washer
Two more cheap but Quality Quick connect options I found... I got these as well for my garden... Quality is quite nice...
Rs. 199/-
(2 nos set)
http://www.ebay.in/itm/Hose-Connecto...item25a0627a2c
Rs. 249/- (2 nos + 1 two way)
http://www.ebay.in/itm/Hose-to-Hose-...item25a06288ec
Once can use eBay coupons released from time to time to get them for chap... Right now I suppose there is some 100 off 200/- for new users...
Old 14th March 2015, 01:59   #777
Thad E Ginathom's Avatar
Thanked: 8,375 Times
This would be wonderful except that I need 3/4-inch hose connector, and these are half-inch.
Old 20th March 2015, 20:34   #778
Thanked: 15 Times
What's the difference between..
http://www.ebay.in/itm/Karcher-0-6-l...item2a4dd90244
http://www.ebay.in/itm/Karcher-0-6-l...item4d216ea1d3
Apart from position of variable knob..
Old 21st March 2015, 22:59   #779
sagarpadaki's Avatar
Thanked: 1,337 Times
The one with the adjustment knob on the top is the newer model.
sagarpadaki is online now   Reply With Quote
Old 22nd March 2015, 03:28   #780
Thanked: 15 Times
Better foam production with new model ???
Rear Wiper & Washer ? Why only on hatch backs and NOT on sedans? Kinetik Technical Stuff 64 22nd November 2016 13:25
VW Polo DIY: Windshield washer low-level sensor & dash warning Gannu_1 DIY - Do it yourself 27 27th August 2016 08:53
Convert Air compressor to a Pressure water washer? rajivanoj Technical Stuff 5 3rd February 2014 00:45
The 'Actual' Tyre Pressure : Is Atmospheric Pressure Counted? sr_1445 Technical Stuff 2 16th January 2014 11:05
High pressure car washer using air compressor recshenoy Modifications & Accessories 2 1st October 2009 09:59
