Old 18th December 2009, 17:12   #76
Originally Posted by bj96 View Post
Pardon my ignorance. I have a basic question. Do these high pressure washers need running water connection e.g. a hose connected to the tap supplying water continuously, or, do they work off the stored water source like a bucket too?
They require running water connection.
Also do they require 15amp (large) power plugs or normal (5amp) power plugs?
Hymatic comes with German connector. You can work thro' an adapter or cutoff the original connector and put in an Indian connector. 15A is recommended
Is there any model which can work off the car battery- less pressure is fine?
I have no idea. To best of my knowledge, Hymatic does not have such a model. You may,however, visit their web-site (posted by me in an earlier post) and check out.
-BJ
My reply is context of Hymatic model only and in bold against your queries.
kingshukt is offline   Reply With Quote
Old 18th December 2009, 17:14   #77
rk_sans's Avatar
Thanked: 602 Times
Guys,
Today morning, i saw the demo of Bosch and Black & decker models in Metro. Any reviews about B&D Model.
I am planning to buy one. Any suggestions ?
@bj96,
As per the demo person, it should have running water and most important we cannot use it continuously for not more than 10 mins.
rk_sans is offline   Reply With Quote
Old 18th December 2009, 17:16   #78
SS-Traveller's Avatar
Thanked: 11,061 Times
Default Update: Black & Decker
Did a bit of trawling the www for Black & Decker Pressure Washers, and got the address and phone number of their sole importer and distributor in India - Gryphon Impex Pvt. Ltd. at Okhla, New Delhi. Spoke to them about the product.
Unfortunately, they are not permitted to import this particular product line (pressure washers), and cannot provide after-sales support either.
Well, without service support, I don't want to buy B&D.
...we cannot use it continuously for not more than 10 mins.
Well, there you have my viewpoint of B&D - don't know how Metro is selling the stuff if the sole importer is not bringing it in.
As to using it for 10 minutes only - what car do they want us to wash? Matchbox cars?
Old 18th December 2009, 17:59   #79
Default Update: Bosch Aquatak
Bharat Sales is the authorized dealer for Bosch products, including Aquatak, in Delhi. Spoke to them just now. All product models, spares and service available, but they are located in Azadpur, not too easily accessible. The prices quoted were Rs.8400 for the Aquatak 10, and Rs.12000 for the Aquatak 100 Plus (would these be effective in washing an SUV? - the product brochure says they are ideal for light spring-cleaning). For cleaning cars, the minimum recommendation is for Aquatak 110/110 PLus/115 Plus, though for bigger cars the recommendation is for at least Aquatak 1200 Plus.
Old 18th December 2009, 18:21   #80
rk_sans's Avatar
Thanked: 602 Times
The Bosch representative views on this was that, after 10 mins we need to give a break for 2 to 3 mins to resume it back. He explained some technical stuff that the washer(or something like that) they use in the machine is like that and he was honest enough to tell also that to reduce the price they have done like that.
The prices quoted were Rs.8400 for the Aquatak 10.
Price quoted in Metro was Rs.6300
B&D model Rs.6500
Old 18th December 2009, 20:43   #81
Thanked: 21 Times
tia,
-BJ
Never seen one that works from a car battery but there are petrol ones available.
Also the pressure from a simple water pump is more than adequate to wash a car. That is what I got at home in India, it has a direct feed from the water tank. It is simple and can be repaired locally, the pressure is enough to take mud and dirt off without damaging the paintwork.
You can also use the pressure type setups you get for spraying with tractors. That produced a lot of pressure and again can be easily repaired locally.
bigman is offline   Reply With Quote
Old 18th December 2009, 20:54   #82
AbhiJ's Avatar
Thanked: 468 Times
I spray my CR-V within 7-8 mins max. And this includes the underbody..
AbhiJ is offline   Reply With Quote
Old 18th December 2009, 21:22   #83
Thanked: 13 Times
Anyone tried this - http://www.team-bhp.com/forum/owning...ml#post1635257 ?
Cheap & reliable. May be not as powerfiul, still might do the job.
jigbarai is offline   Reply With Quote
Old 18th December 2009, 22:10   #84
Thanked: 13 Times
Can we spray high pressure air to blow the water off with Bosch? I have used such public systems abroad. By blowing the water off, you don't need to wipe too much water. Its extremely helpful
suneet_ag is offline   Reply With Quote
Old 18th December 2009, 23:05   #85
Thad E Ginathom's Avatar
Thanked: 7,482 Times
bj96... yes, they require a tap with running water*. My Bosch has a 5-amp plug; maybe the large models may require 15, I don't know.
I haven't heard of a battery-operated one.
*afterthought: I think I've heard of some models being able to be used as a pump. Maybe they might work off a drum of water. Just a thought.
Old 19th December 2009, 09:23   #86
rk_sans's Avatar
Thanked: 602 Times
No, you cannot do it with Bosch. It is only for pressure water.
Old 19th December 2009, 10:07   #87
That would be brilliant!
But I'd guess that pressurising air and pressurising water probably differ somewhat as engineering problems.
Old 19th December 2009, 21:42   #88
Thanked: 13 Times
In the public use system that I am talking about, you put in money and then high pressure waters flows in for about 45 secs, followed by 10 secs of shampoo, followed by another 45 secs of high pressure water. It ends with about 20 seconds of high pressure air which lets you blow the water and residue away. 2 mins and it works brilliantly.
If bosch does only water jet then i know in bangalore around JC road you can buy nozzles with pipe which would serve the same purpose. The only advantage would be portability with bosch
Old 9th January 2010, 09:30   #89
...Rs.12000 for the Aquatak 100 Plus...
Bought (booked) an Aquatak 100 Plus (with 5 attachments) at the Auto Expo yesterday for a special discounted price of Rs.7500 + 4% VAT after watching the demo and trying it out myself. Home delivery after the Expo ends next week. Six months warranty included. Service and spares are not an issue, I was assured, since Bosch have their office and service centre in Panchkuian Road, New Delhi.
Old 9th February 2010, 21:01   #90
Bought an Aquatak 100 Plus...
A series of pics of the washer in action after today's rainy and slushy 140-km run to work and back. It took less than half an hour to complete the job.
The Scorpio has too many nooks and crannies for easy cleaning, and manual cleaning takes over an hour, that too excluding the insides of the mudguards.
SS-Traveller is offline   (1) Thanks Reply With Quote
Rear Wiper & Washer ? Why only on hatch backs and NOT on sedans? Kinetik Technical Stuff 64 22nd November 2016 13:25
VW Polo DIY: Windshield washer low-level sensor & dash warning Gannu_1 DIY - Do it yourself 27 27th August 2016 08:53
Convert Air compressor to a Pressure water washer? rajivanoj Technical Stuff 5 3rd February 2014 00:45
The 'Actual' Tyre Pressure : Is Atmospheric Pressure Counted? sr_1445 Technical Stuff 2 16th January 2014 11:05
High pressure car washer using air compressor recshenoy Modifications & Accessories 2 1st October 2009 09:59
