Old 31st December 2016, 13:55   #916
S_U_N's Avatar
Thanked: 381 Times
Default Re: Buying & Using a Pressure Washer
Originally Posted by Samfromindia View Post
I had upto 10k budget and went ahead with Bosch AQT 35-12.
Good to know. I would look forward to a review from you after 6 months. Hope the product quality lives up to the brand name.
S_U_N is offline   (1) Thanks Reply With Quote
Old 1st January 2017, 12:05   #917
Samfromindia's Avatar
Thanked: 591 Times
Yes 6 month will be a good time to see how well it holds up. Also i need to check how good is their support and availability of parts & accessories. I have seen amazon selling many attachments for AQT range like the wash brush and 90 degree nozzle.
http://www.amazon.in/s/ref=nb_sb_nos...d-keywords=aqt
If only they had a Bosch foam lance
Samfromindia is offline   Reply With Quote
Old 24th March 2017, 20:57   #918
dre@ms's Avatar
Thanked: 172 Times
Originally Posted by dre@ms View Post
In Metro cash and carry, Bosch AQT 33-10 is priced at 5999/- and B&D HP Washer at 5499/-
Which one is a best buy. Primary need is for cleaning my City and Bike's.
Guys, any suggestions?
dre@ms is offline   Reply With Quote
Old 27th March 2017, 00:11   #919
rosh_aveo1.4's Avatar
Thanked: 288 Times
Well....I took the plunge and settled for Karcher K2. Actually I was very close in buying Bosch AQT 35 but didn't like the attitude of the service center when I enquired about warranty if purchased online...something I didn't find Karcher so bad with but who knows in the future. And since it was 1 year warranty vs 6 months of Bosch and most others...decided for Karcher. Just got the unit and tried it today. I first thought the 110 psi pressure of Karcher vs 120 of the Bosch would be a problem but was quite happy with the results. The garden hose is not fitting well now...gets disconnected every now and then...need to find a way to make it tight and disconnect when needed.
Tried the soap jet thingi that came with the set and just experimented with my standard 3M shampoo and was surprised with the amount of foam generated.
rosh_aveo1.4 is offline   Reply With Quote
Old 27th March 2017, 01:05   #920
Thad E Ginathom's Avatar
Thanked: 7,451 Times
I'm sure it is not a problem, as one should never use anything like the full pressure on any part of a car. If the fan jet in your pic is adjustable, I would suggest opening it up to a wider, slightly gentler jet.
Congratulations on our new machine
Thad E Ginathom is offline   (2) Thanks Reply With Quote
Old 27th March 2017, 01:40   #921
harsh79's Avatar
Thanked: 599 Times
@rosh_aveo1.4
As the K2 doesn't come with a Vario lance, better to keep some distance while using the regular one.
I'd strongly suggest getting a Vario lance.
harsh79 is offline   (1) Thanks Reply With Quote
Old 27th March 2017, 05:05   #922
Thanked: 288 Times
Originally Posted by harsh79 View Post
@rosh_aveo1.4
OK....sorry for being ignorant on this but you say this since the standard lancer that I got can damage the car paint or such? Saw in YouTube videos they use it normally so didn't know what the problem is.
rosh_aveo1.4 is offline   (1) Thanks Reply With Quote
Old 27th March 2017, 13:22   #923
I think it may be possible to damage paintwork, but more likely to affect wax finish, etc.
Also there is a danger that the pressure will affect rubber window seals etc.
Mostly I am just echoing the warnings I have read, but that includes the pressure washer manual.
Frankly, I find hose pressure (we have good hose pressure) more than ample for car washing, with the exception of underbody and wheel arch areas where caked mud gets built up, and maybe wheels, where it is labour saving. Thus I have not bothered to replace my failed Bosch.
However, I wouldn't put anybody off buying one, because it is so useful for many tasks such as cleaning stone and concrete and it is fun to use!
Thad E Ginathom is offline   (1) Thanks Reply With Quote
Old 27th March 2017, 14:05   #924
harsh79's Avatar
Thanked: 599 Times
If used really close up, it could strip the clear coat or paint.
The Vario lance is very convenient while going over headlights, taillights, radiator grill and the engine bay.
The dirt blaster lance is a stirict no-no.
Old 27th March 2017, 19:25   #925
Thanked: 288 Times
Thanks. I'll keep that in mind. So the workaround is keep a distance and not too close. The vario lance costs 4k, nearly half of the overall unit! Should buy that later though. Yup, I read everywhere the dirt blaster lance shouldn't be used at all. Thanks for clearing this.
Old 28th June 2017, 15:42   #926
Sahil's Avatar
Thanked: 2,233 Times
I got the Bosch AQT 33 and am having problems setting it up. When I connect the water pipe into the filter inlet on the pressure washer and start the tap, the water starts gushing out.
I tried to tighten the water inlet but yet the problem persists.
Please help!
Old 29th June 2017, 00:56   #927
You're using the click type of hose fittings, originally designed by Hozelock and now copied widely?
There should be an O-ring on the male (pump) fitting. Check that there is. Further than that, I think we need pictures, please!
Old 29th June 2017, 09:49   #928
Sahil's Avatar
Here are the pics. Hope it brings some clarity to figure out a solution
Old 29th June 2017, 16:46   #929
Oh! I never had this problem! My ideas...
Are you sure the hose is the right size for the connector. Although if it isn't it should not fit at all.
Are you pushing the hose as far as it will go.
Are you screwing down nice and tight?
If yes, yes and yes... I'm afraid you need to get a new connector. Or a new hose? I suppose it is possible that the inner diameter is correct, but the hose body is not thick enough to crimp properly?
Old 29th June 2017, 17:01   #930
archat68's Avatar
Thanked: 238 Times
Anybody has a reference for a Skil pressure washer 90 degree wash nozzle that can be used to wash the underside of the car?
archat68 is offline   Reply With Quote
Rear Wiper & Washer ? Why only on hatch backs and NOT on sedans? Kinetik Technical Stuff 64 22nd November 2016 13:25
VW Polo DIY: Windshield washer low-level sensor & dash warning Gannu_1 DIY - Do it yourself 27 27th August 2016 08:53
Convert Air compressor to a Pressure water washer? rajivanoj Technical Stuff 5 3rd February 2014 00:45
The 'Actual' Tyre Pressure : Is Atmospheric Pressure Counted? sr_1445 Technical Stuff 2 16th January 2014 11:05
High pressure car washer using air compressor recshenoy Modifications & Accessories 2 1st October 2009 09:59
