Old 6th July 2017, 08:34   #931
Sahil's Avatar
Thanked: 2,648 Times
Default Re: Buying & Using a Pressure Washer
Originally Posted by Sahil View Post
Here are the pics. Hope it brings some clarity to figure out a solution
Someone please help!
Old 6th July 2017, 08:43   #932
SunnyBoi's Avatar
Thanked: 2,829 Times
You should get the new connectors at any gardening/agri store.
If not, amazon to the rescue :
http://www.amazon.in/Dolphy-Plastic-.../dp/B071H4BST1
http://www.amazon.in/Spanco-Plastic-.../dp/B01M3U7Y87
SunnyBoi is offline   Reply With Quote
Old 6th July 2017, 12:08   #933
scorpian's Avatar
Thanked: 221 Times
So my black & Decker died on me in middle of washing my car.
Yeah just died. Gave some weird smell and was making some funny sounds and then went quiet.
i tried in vain to get it started didn't help.
Now have to take it to service centre and get it checked.When i bought this i didn't know that it didn't have a the foam attachment,In-case if the repair cost is high i would like to buy a new one of any brand but with a foam lance. Which one would you guys recommend.
scorpian is offline   Reply With Quote
Old 6th July 2017, 12:29   #934
Sahil's Avatar
Ok I think I figured out the issue here. I have been connecting one end of the pipe into the pressure washer and other end into the tap directly. However, the other end actually needs to be put in a bucket of water from what I read online.
Is this how you guys have been used your pressure washers using a pipe in bucket instead of connecting it to a tap??
Old 6th July 2017, 12:48   #935
sagarpadaki's Avatar
Thanked: 1,331 Times
Nope, that is not mandatory. Infact that will work only if the pressure washer is self priming and the entire length from the washer inlet to the bucket is completely air tight.
The hose adapter is faulty. Based on whether you are using a 1/2 inch or a 3/4 inch garden hose get the appropriate sized hose adapter.
Old 6th July 2017, 15:49   #936
james's Avatar
Thanked: 541 Times
You can hook it up to a tap as well, Sahil. I had a similar issue as the hose I was using was too stiff. The moment i replaced it with a supple hose, it started sealing well.
james is offline   Reply With Quote
Old 21st September 2017, 09:47   #937
Thanked: 11 Times
Wanted to inform BHPians that Resqtech has launched two pressure washers over at Amazon. The first is a 135 bar, induction motor unit at 8k; the second is a 1800 watt universal motor unit at the same pressure rating. Both with 2-year warranties.
I'd buy one of these at a snap, but for the damning fact that my basement car parking doesn't have a power connection.
(I am not affiliated to Resqtech in any way--apart from excessive desire for a pressure washer.)
The other deal I saw was on the Begmann Typhoon tyre inflator--but I think my desire for inflators has worn off. Still open to persuasion.
oldshivabull is offline   (1) Thanks Reply With Quote
Old 21st September 2017, 20:20   #938
Thanked: 40 Times
you can buy the electrical cable (to the length that you want) which is used by camera man (45rs/metre) and connect a 15 amp socket to it and a 2 pin. Its a 5 minute work and the shop keeper did it for me.
anandharamanp is offline   (1) Thanks Reply With Quote
Old 21st September 2017, 22:32   #939
Thad E Ginathom's Avatar
Thanked: 8,341 Times
Puzzled by that...
What is the practical difference? Why would they offer both: why would someone buy one rather than the other?
Not impressed with the pricing, which seems to be set to match the import price of the competition, which sells for substantially less elsewhere in the world.
Old 22nd September 2017, 09:46   #940
Thanked: 92 Times
The more expensive one has an induction motor.
There is a 10℅ discount and another 10℅ on specific debit cards.
torque18 is offline   Reply With Quote
Old 22nd September 2017, 11:25   #941
Thanked: 11 Times
Puzzled by that...
Is the universal motor better? Here is the link to the first of the products. Pricing is less than Bosch, right?
https://www.amazon.in/dp/B075PSLZGY/...=IK5D6FHMJS5AG
Old 22nd September 2017, 11:38   #942
Prowler's Avatar
Thanked: 303 Times
Puzzled by that...
The induction motor will be quieter than the universal motor. I have a Bosch pressure washer that nearly wakes up my neighborhood as it has a universal motor. But other than the noise, I have no complaint.
In the same page, there are other better options - like Karcher available at about 5.5 k.
Prowler is offline   Reply With Quote
Old 22nd September 2017, 21:37   #943
OK, I confess I do not understand the difference between these motors. In terms of noise, though, I would have thought that most of it would come from the pump?
Old 22nd September 2017, 21:52   #944
Thanked: 11 Times
From what I learn, Thad, the induction motor whould be better; the universal motor would be noisier. Anyone who is an electrical engineer here would know better. My source is https://www.popularwoodworking.com/t..._about_motors1
(FYI: The induction motor unit is costlier by 2k at INR9,999.)
oldshivabull is offline   Reply With Quote
Old 23rd September 2017, 21:04   #945
Ah, thanks for that. Learnt some basics that I probably ought to have known before!
Rear Wiper & Washer ? Why only on hatch backs and NOT on sedans? Kinetik Technical Stuff 64 22nd November 2016 13:25
VW Polo DIY: Windshield washer low-level sensor & dash warning Gannu_1 DIY - Do it yourself 27 27th August 2016 08:53
Convert Air compressor to a Pressure water washer? rajivanoj Technical Stuff 5 3rd February 2014 00:45
The 'Actual' Tyre Pressure : Is Atmospheric Pressure Counted? sr_1445 Technical Stuff 2 16th January 2014 11:05
High pressure car washer using air compressor recshenoy Modifications & Accessories 2 1st October 2009 09:59
