Old 11th July 2018, 22:59   #991
scopriobharath's Avatar
Thanked: 1,264 Times
Default Re: Buying & Using a Pressure Washer
Originally Posted by Acelerar View Post
Question - Does it need the 16A source or can I use plug adapter and use it with normal 6A source safely? Thanks
Buy a 16 amp plug socket and wire and Do a diy extension box. I made this myself this and use this every week for washing my Nexon with Bosch AQT 37-13 plus
scopriobharath is online now   (1) Thanks Reply With Quote
Old 12th July 2018, 11:59   #992
Thanked: 28 Times
Folks, just bought the AQT 35-12 but the plug is of 16 A. Started searching for more information and came across this wonderful thread.
Unfortunately, I have no 16 A plug close by to wash place (the nearest one is about 40 feet away) and even the heavy duty 16A extension cords available in Amazon are of max 4m length which does not suffice.
Give it to the local electrician shop. He'll add as many meters of wire as you need.
maverhick is offline   (2) Thanks Reply With Quote
Old 12th July 2018, 20:34   #993
It might void the warranty. Extension box is a better option.
Old 12th July 2018, 21:00   #994
R2D2's Avatar
Thanked: 2,192 Times
Folks, just bought the AQT 35-12 but the plug is of 16 A. Question - Does it need the 16A source or can I use plug adapter and use it with normal 6A source safely? Thanks
I've posted my thoughts on this here: bosch-aqt-35-12
R2D2 is offline   (2) Thanks Reply With Quote
Old 14th July 2018, 23:18   #995
ishlinea7260's Avatar
Thanked: 263 Times
Default BOSCH vs KARCHER
So my almost a decade old Bosch aquatak plus is running on its last legs. Leaks oil, has become noisier and the worst part is local Bosch outlet cannot repair it since the model is quite old.
I am thinking of buying a Karcher product this time, K3 to be exact, since I have heard that newer BOSCH products suffer from inferior quality.
Fellow bhpians who use pressure washers, your opinions will be highly appreciated.
ishlinea7260 is offline   (1) Thanks Reply With Quote
Old 15th July 2018, 11:48   #996
Thanked: 47 Times
Exclamation Re: Buying & Using a Pressure Washer
Originally Posted by raihan View Post
I was targeting a Karcher K2 but after going through this thread have decided to buy one with a metal head with a budget of 15-16K tops.
Can someone pl tell me what to buy with the relevant links/place to buy in Bangalore.
Thx.
PS Also which one would be better w.r.t service/accessory pricing? As I understand this is not a buy & forget kind of product.
Quoting myself here, I enquired about Karcher K3 premium from Karcher Bangalore dealer & he quoted 16.5K(similar to amazon). The bad part is the 1 year warranty applicable to only motor & not accessories.
Whereas in UK they give 3-5 years warranty. Does it conclude that they make inferior products for price sensitive markets like India?
Doesn't give much confidence to proceed I should say.
raihan is online now   (2) Thanks Reply With Quote
Old 28th July 2018, 13:30   #997
Thanked: 263 Times
Default Bosch AQT 37-13 Plus
Purchased Bosch AQT 37-13 Plus, got a pretty good deal actually.
Initial impressions are mostly positive, I no longer have to change the connectors since it comes with a "3 in 1" nozzle.
Also there is a separate mechanism for using car shampoo which I really like, saves time in interchanging between washer bottle and the pressure wash nozzle.
One thing which I didn't like was that the cable is 6m long and you need to purchase an extension separately so that you can easily wash the car without having to drag the machine with you.
ishlinea7260 is offline   Reply With Quote
Old 28th July 2018, 14:25   #998
lurker's Avatar
Thanked: 696 Times
Go to electrical shop, get a roll of 2.5 sq mm (90 metres)*and a 16 amp socket and 16 amp 3 pin plug and wire the extension yourself as much length as you want. If you have doubts ask the electrical shop owner to connect the wire to socket and pin for you. Best extension cord ever and will give you years of service.
* prefer to get seperate 50 feet of wire in red and black colour for ease in determining live and neutral.
lurker is offline   Reply With Quote
Old 28th July 2018, 15:36   #999
thoma's Avatar
Thanked: 1,145 Times
I am also on the lookout for making/buying extension cord for my Karcher.
Pardon me, didn't get what you meant by 2.5 sq mm wire, is it for 16 amp current? Earth wire is not required? Will the electrical shop usually have the box(wood or plastic) to house the 16A socket?
thoma is online now   Reply With Quote
Old 28th July 2018, 21:53   #1000
sandeepmdas's Avatar
Thanked: 790 Times
The earth wire should be the same diameter of phase/neutral wire upto 16 sq.mm. For wires bigger than 16 sq mm and lower than 35 sq mm, the earth wire must be 16 sq mm.
It should be green or yellow in color.
Look for a PVC modular 4-switch box.
Then either: 2 slots for the 16A socket, 1 for switch and 1 for a pilot lamp. If possible, avoid a switch with built-in pilot. Also buy a plug with fuse. You need to buy the covering plates etc.
or: simply use a Cona or Anchor 16A socket with fuse and pilot all-in-one socket. The Cona 2351 looks very dated, but it is a workhorse socket.
sandeepmdas is online now   (1) Thanks Reply With Quote
Old 29th July 2018, 01:46   #1001
Tejas@perioimpl's Avatar
Thanked: 5,490 Times
Anyone using this?:
https://www.amazon.in/gp/product/B07...A2Z2814OSM61V2
Induction motor and good reviews from verified purchasers. Though the later has gotten me a bit suspicious.
Tejas@perioimpl is offline   Reply With Quote
Old 29th July 2018, 10:37   #1002
lurker's Avatar
Thanked: 696 Times
i
wires are classified by their current carrying capacity.
1 sq mm is upto 6 Amps
1.5 sq mm is upto 9 Amps
2.0 sq mm is upto 12 Amps
2.5 sq mm is upto 15 Amps
3.0 sq mm is upto 18 Amps
So 3.0 sq mm is good for carrying 16 Amps load but wires get considerably thicker and heavier esp when you talk of 15-20 metres.
Earth wire not required because all pressure washers are made of ABS plastic body which is shock proof and the earth pin given on their 3 pin is usually a dummy plastic black material and not useful for earthing. You will only need positive and negative wires preferably of different colours for easy identification. If you get a big roll of red wire then how will you identify which wire is which when it comes to conmecting wires to socket. Also braid these wires so that they become manageable. Once you braid them, identifying which wire is connected to which becomes difficult if they do not have distinct colour. So lets say you need 40 feet of wire. Then buy 15 metres of red wire and 15 metres of yellow/black wire for negative.
All electrical shops have plastic 16/32 Amp socket and it is plastic housing so it is also waterproof. No need to use wood box.
lurker is offline   (2) Thanks Reply With Quote
Old 8th August 2018, 23:20   #1003
Leoshashi's Avatar
Thanked: 15,638 Times
Got the Bosch AQT 130:
Thanks everyone on this thread who cleared all my doubts.
More details here: http://www.team-bhp.com/forum/long-t...ml#post4441254 (The love of my life - A 2000 Maruti 800 DX 5-Speed. EDIT: Gets export model features on Pg 27)
Leoshashi is offline   (5) Thanks Reply With Quote
Old 9th August 2018, 07:07   #1004
Happysmiles's Avatar
Thanked: 109 Times
Originally Posted by Tejas@perioimpl View Post
Anyone using this?:
Got the Resqtech induction model couple of weeks ago.
I liked the build quality. The Resqtech motor can also draw water from a bucket. Have used it many times this rainy season to wash my bike and car. Also at home, the balconies get washed quite often.
With a 2year warranty, VFM pricing and good service backup, Iam a happy customer.
Happysmiles is offline   (2) Thanks Reply With Quote
Old 9th August 2018, 13:07   #1005
Attachment 1788486
Attachment 1788487
Attachment 1788488
Thanks, what about the foam lance? Is it part of the package? On amazon reviews i read that it doesn't come with it.
Rear Wiper & Washer ? Why only on hatch backs and NOT on sedans? Kinetik Technical Stuff 64 22nd November 2016 13:25
VW Polo DIY: Windshield washer low-level sensor & dash warning Gannu_1 DIY - Do it yourself 27 27th August 2016 08:53
Convert Air compressor to a Pressure water washer? rajivanoj Technical Stuff 5 3rd February 2014 00:45
The 'Actual' Tyre Pressure : Is Atmospheric Pressure Counted? sr_1445 Technical Stuff 2 16th January 2014 11:05
High pressure car washer using air compressor recshenoy Modifications & Accessories 2 1st October 2009 09:59
