Old 11th September 2010, 00:18   #121
AWD
Thanked: 218 Times
More keen on local prices, differences should be small.
I think the members who have quoted low prices may be having some confusion regarding models.
AWD is offline   Reply With Quote
Old 11th September 2010, 14:25   #122
sagarpadaki's Avatar
Thanked: 1,337 Times
Guys,I have a problem with my Aquatek plus.The water pipe which i connect at inlet keeps popping out when i start using the machine.The back pressure is too much for the pipe to be in place.How to make it stay put in the place?I connect the pipe directly to the inlet.Also what pipe size should i use?
sagarpadaki is online now   Reply With Quote
Old 11th September 2010, 15:20   #123
Thanked: 36 Times
You can do two things.
Either try and tie it to the tap with a piece of rope or get a metal fastener which is also used inside your engine bay to tighten the air filter hose securely by screwing it tight. They come in small sizes as well at hardware shops. Look inside your engine bay to get an idea, I don't know the exact name for it. I bought a pair today itself.
For the pipe size, just use the normal one suitable for your tap.
abhipuru16 is offline   Reply With Quote
Old 11th September 2010, 15:34   #124
Thad E Ginathom's Avatar
Thanked: 8,379 Times
In UK we call the Jubilee clips --- maybe after a long-forgotten brand, I don't know, but here they seem to be called just hose clips.
Alternatively, there is the adapter that fits to the tap with a click-on/click-off fitting on the hose. These are very good, and commonly available in UK garden shops. Although they are rare here, my pressure washer came with a set supplied. It is the same as clicks onto the input of the washer itself.
Old 11th September 2010, 15:58   #125
headers's Avatar
Thanked: 464 Times
reduce the inlet water pressure by 2 turns..it usually works!
Old 11th September 2010, 16:25   #126
Sorry to have not made myself clear.by inlet i mean the inlet of the aquatek and not the water tap.the pipe at the tap end will be fine.but its the pipe at the aquatek end that keeps popping out.
Old 11th September 2010, 17:02   #127
Attachment 421972
Yea,i do have these along with the plugs.But as i said the problem with is at the aquatec inlet and not of the tap.
Aquatec users,can you please share the size of the garden pipe you are using?like 1/2",3/4"
Old 11th September 2010, 17:25   #128
sohail99's Avatar
Thanked: 200 Times
I too was thinking of getting one! especially for the underbody cleaning!
but I read through the whole thread and a few others and it seems Aquatek kinda conks off after some use??
Is it true?(any approx life?)
Precautions/tips to prevent premature motor burnout/ unit death?
sohail99 is offline   Reply With Quote
Old 11th September 2010, 18:26   #129
Thanked: 40 Times
Sagarpadaki,
well , i have been using this device for about an year now. I have taken a slightly undersized hose, burnt it the open end of the hose to the extend of the inlet's length of the Aquatek and just fixed it. It holds on very tight once the hose cools down. Its working really well.
Sohail,
as i have mentioned above, i have been using this for about any year & am very happy with no problems till now.One needs to follow the simple instructions given and it will serve to your requirement well. It saves a lot of time by cutting visits to the wash centers and waiting.
nandans2005 is offline   Reply With Quote
Old 11th September 2010, 19:57   #130
I have been using the aquatec 100 plus for 2 years now.Its awesome !Never gave any problem.Go for it.It will help you in your car detailing sessions also by ripping off stubborn dirt
Originally Posted by nandans2005 View Post
Sagarpadaki,
Could you please take a pic of it post.It will be really helpful in understanding.thanks
Old 11th September 2010, 22:10   #131
Thanked: 36 Times
You can use those metal clips at the Aquatak's inlet end. Try it.
Old 11th September 2010, 22:48   #132
Then you should have one of these. It will click-fit onto the aquatec. Your supplier should have given you one (or even sold you one!)
I think my hose is 3/4 inch. I think this particular fitting is a half inch one, but the only difference is --- size!
Old 12th September 2010, 09:28   #133
headers's Avatar
Thanked: 464 Times
Attachment 422209
Yup, you should have got the one shown in the picture. It works fine for me, ofcourse mine is just 4 months old and have done 2 dozen washes!!
BTW, any method how to use the soap / liquid gel bottle and get to spray the car.
Am unable to use the bottle with the pressure nozzles
Old 12th September 2010, 09:45   #134
anilisanil's Avatar
Thanked: 288 Times
I see only guys from Chennai/Bengaluru mostly involved! Or did I miss someone form Pune!
I am looking to buy this (Aquatak 100) from Pune, anyone who procured this from Pune kindly let me know!
Also I am to use this from a normal tap supply, though I did go through the thread, I would like to confirm that this works in that case!
Also, is there a considerable difference between the 100 and 100 Plus models?
I see that a few guys are using accessories like shampoo dispensers are these standard or should be bought separately?
Also I tried to search for the user manual for this product but could not find one, it would be great if someone could post that! My car manual says no pressure wash and hence I am concerned and wanted to be doubly sure about the decision!
anilisanil is offline   Reply With Quote
Old 12th September 2010, 09:53   #135
rk_sans's Avatar
Thanked: 784 Times
@awd/@sumitb,
Here are pics of the model box and the bill. I am sorry i quoted wrongly as Rs.6100/- but it was Rs.5900/- actually
rk_sans is offline   Reply With Quote
Rear Wiper & Washer ? Why only on hatch backs and NOT on sedans? Kinetik Technical Stuff 64 22nd November 2016 13:25
VW Polo DIY: Windshield washer low-level sensor & dash warning Gannu_1 DIY - Do it yourself 27 27th August 2016 08:53
Convert Air compressor to a Pressure water washer? rajivanoj Technical Stuff 5 3rd February 2014 00:45
The 'Actual' Tyre Pressure : Is Atmospheric Pressure Counted? sr_1445 Technical Stuff 2 16th January 2014 11:05
High pressure car washer using air compressor recshenoy Modifications & Accessories 2 1st October 2009 09:59
