Old 18th June 2009, 17:05   #181
Just got Bosch wiper blades for my Swift and Maruti 800.
The problem is that the Maruti 800 is a Carb '95 Model and i am not sure if these clip on blades can be fitted on this model. Therefore, before i open the box i would like to know if its possible to fit these Bosch blades on this car.
P.s:- This model has a screw on system of some sort.
HELP!! It's going to start raining soon ;-)
Need_4_Speed is offline   Reply With Quote
Old 19th June 2009, 09:21   #182
toiingg's Avatar
Thanked: 83 Times
You will need the SS adapter to fit these on older screw type models. Ask the shop where you bought the wipers from to get them.
toiingg is offline   Reply With Quote
Old 20th June 2009, 21:00   #183
Thanked: 706 Times
Default Santro wipers - deviation in dimensions
Bosch wipers for santro are wider/longer than stock wipers. Passenger side wide is 420mm instead of 400mm. Has this caused any problem, any feedback from santro owners?
Similarly, rear wiper is shorter at 340mm instead of 350mm. This would mean less glass area being cleaned.
Another surprise, Bosch sells rear wipers in pairs for all applicable cars.
Why would anyone need two rear wipers? Or does Bosch expect the customer to have two cars of same make & model?
sukiwa is offline   Reply With Quote
Old 21st June 2009, 20:03   #184
Thanked: 161 Times
Hi folks is it worth buying the Bosch aero twins or just the regular Bosch wipers will do ??
jinu_joseph is offline   Reply With Quote
Old 21st June 2009, 20:13   #185
abhinav.gupta88's Avatar
Thanked: 310 Times
What is the size of a Skoda Octavia.
I am looking to change to Bosch.
The OE ones are not pretty good.
Old 21st June 2009, 20:51   #186
Thanked: 706 Times
@ abhinav.gupta88:
Bosch catalog states 530mm (21") and 480mm (19") for the set, part number is '3 397 010 053'.
Old 22nd June 2009, 04:02   #187
k_shanz's Avatar
Thanked: 64 Times
Is that flexible one like that seen on Skoda Laura available for other Indian cars. Am looking that type for my zen!
Please Help.
k_shanz is offline   Reply With Quote
Old 22nd June 2009, 18:51   #188
bhp
bhp's Avatar
Thanked: 152 Times
wat is the difference in bosch aero twins and regular bosch wipers...
regulars are for 340/- mrp for swift
aero twins for 1850/- mrp for swift
are aero twins worth that kind of money
If somebody can write a review if used both the products it would be very helpful to all the bhpians
bhp is offline   Reply With Quote
Old 22nd June 2009, 18:55   #189
MileCruncher's Avatar
Thanked: 357 Times
The flexible owns I feel do a better job than the normal ones and also last quite a bit longer. But all the cars I have seen them, have a spray washer rather than a nozzle with pointed flow.
MileCruncher is offline   Reply With Quote
Old 24th June 2009, 12:52   #190
NiTviN's Avatar
Default Bosch wiper blades for Safari
My Safari wipers were a year old and had become hard. So I thought of changing the blades to Bosch ones. Checked on this thread and bought the 22" Bosch Blades last sunday from Bangalore Distributor at J C Road.
When I replaced the old one with new ones, I found that the right one of the stock was longer (I think 24") and left one was shorter (20"). Now I was surprised to see this. My Maruti 800 has the same size for both sides!!! Later I came to know that the newer cars have diff. length wipers. Now, the left side (which was shorter) wiper is replaced with a 22". So a small portion say about 0.5" extends beyond the windshield glass and rests over the bubber beading.
Do you guys think this can create any problems? I did not have chance to test them out yet, since it did not rain after sunday . I also replaced the rear wiper with 13.5" Bosch and found that the stock one was shorter (may be 12.5"). However this is good for me since the new wipers will clean more glass and does not extend beyond the windshield.
Has any Safari owners faced this issue before?
Last edited by Technocrat : 29th June 2009 at 13:22. Reason: Only two smilies per post allowed, please read th board rules carefully before proceeding further, thanks
NiTviN is offline   Reply With Quote
Old 28th June 2009, 10:58   #191
WasavaTyres's Avatar
Thanked: 255 Times
NitVin you just need to bend the blade just a wee bit to make it fall in line (literally). If you're unsure about it or built like Shwaznegar you'd do well to take it to a mechanic or the shop where you picked it up from.
WasavaTyres is offline   Reply With Quote
Old 28th June 2009, 11:14   #192
vigsom's Avatar
Thanked: 603 Times
Cut the rest off - but do it neatly
Old 29th June 2009, 11:55   #193
NiTviN's Avatar
With what can I cut it off? Remember its not just the bubber, there is a metal piece also needs to be cut.
Old 29th June 2009, 13:11   #194
amit_mechengg's Avatar
Thanked: 1,556 Times
it can be cut perfectly with a Hacksaw blade. however after cutting file the edges with a file, or the back filer portion of a nail cutter so that you dont gets cuts on your hand due to wipers while cleaning your car
Old 29th June 2009, 13:42   #195
akshay4587's Avatar
Thanked: 1,686 Times
whats so special about aero wipers?
i have to get wipers of my accent replaced
are they worthy enough of spending 1800 bucks over 350 for regular bosch?
VW Passat DIY: Replacing the Wiper blade element rpunwani DIY - Do it yourself 9 23rd June 2016 15:21
Palio Wiper Blade size RedMM340 Modifications & Accessories 10 22nd January 2010 17:15
Silicon/Water blade greenhorn Modifications & Accessories 4 7th October 2009 11:03
