Old 24th July 2012, 09:18   #616
goandude's Avatar
Thanked: 447 Times
Default re: The 'Wiper Blade' Thread
Originally Posted by raul View Post
I have had bad experiences consistently with 'Bosch' wipers and so has my friend.
Originally Posted by jatinpatel View Post
Had bad experience with Bosch wiper blades twice and after that switched from bosch to Hella
The hella blades in my lancer are 2years old and still clean like new no streaks no juddering no nothing.
And two blades costed 300rs from shetty motors.
I too had a bad experience with Bosch. They started to chatter after a short while. I remember last year monsoon drive to Mumbai to Bangalore the wipers were on almost continuously and the chatter and noise was awful.
Got hella dynaedge yesterday. for 1180/- yet to use them and will comment after that. They claim to be aerodynamically shaped to reduce noise and lift
goandude is offline   Reply With Quote
Old 29th July 2012, 08:36   #617
goandude's Avatar
Thanked: 447 Times
Default Review of Hella Dynaedge
A quick review of the hella dynaedge wipers.
The wipers actually swivel at the hinge which causes the squeegee action to be pronounced. Also they have a small aerodynamic fairing on the front.
Testing conditions: light to very heavy rains. Speed upto 60 kmph.
Verdict: excellent cleaning of the windshield at all speeds, no chatter at all. Absolutely silent.
highly recommended if you don't mind paying a bit more for them
goandude is offline   (1) Thanks Reply With Quote
Old 29th July 2012, 19:31   #618
Thanked: 322 Times
I have been using the regular Hella blades for a couple of years now and they have lasted well. V satisfied and would definitely recommend them over the basic Bosch blades
Mortis is offline   Reply With Quote
Old 3rd August 2012, 10:36   #619
sumathindra's Avatar
Thanked: 192 Times
Default Re: Review of Hella Dynaedge
I have been trying to get the bosch twin aero however due to want of stock, not able to source one yet. Anyways where do you get the Hella blades around Jayanagar or JP Nagar? any idea please.
sumathindra is offline   Reply With Quote
Old 3rd August 2012, 10:52   #620
Thanked: 98 Times
Can anyone suggest me a good pair of wiper blades for my New Wagon R under 500 Rs.
Please also suggest the appropriate size.
born_free is offline   Reply With Quote
Old 4th August 2012, 10:30   #621
Default Beam blade wipers
Friends, could someone advise if beam blade wipers are definitely better than the normal ones? If yes, kindly recommend a brand and model which I can pick up for my SX4. Do the wiper arms also need to be changed when the blades are changed to beam ones? What about the wiper motor? Does this need to be changed as well? Does changing these invalidate the manufacturer\'s warranty?What would be the cost of getting these on a SX4?Where can I get these blades fitted at Bangalore?What is the typical life of these blades (assuming the normal ones need to be replaced once a year)? Thanks, Satya.
satyabratpanda is offline   Reply With Quote
Old 4th August 2012, 10:45   #622
Thanked: 26 Times
Am due for my ANHC's 30k service. The OEM wiper blades have run out, and they now make a grinding sound sometimes. OEM blades according to service folks will cost about INR 1000. Are the OEMs recommended or a shift to Bosch is a better idea?
Also, how much would be the price of an equivalent/better Bosh set and where are they available in Gurgaon?
achyutaghosh is offline   Reply With Quote
Old 4th August 2012, 11:12   #623
Mohan P Rao's Avatar
Satya, I worked briefly as a Product Manager at MICO BOSCH and they had some great wiper blades. Though I didn't handle the wiper blade portfolio but I did see a presentation on the technology on offer. Your local BOSCH dealer should easily be able to answer your queries.
The website resource is http://www.boschcleartheway.com/.
Mohan P Rao is offline   Reply With Quote
Old 4th August 2012, 11:15   #624
rajeev k's Avatar
Thanked: 1,734 Times
Default Re: Beam blade wipers
Bosch blades are good but buy from a reputed dealer so that stocks would always be fresh. Badly stored blades with a shelf life through thick summer is likely to cause noise while wiping. Better to change before onset of monsoons but would work neatly for couple of years if vehicle is not parked under the sun regularly. Also not necessary to change arms unless damaged.
rajeev k is offline   (1) Thanks Reply With Quote
Old 4th August 2012, 18:39   #625
el lobo 6061's Avatar
Thanked: 982 Times
Really confused which one to go Bosch Aerotwin or Hella DynaEdge?
I wanted to replace wiper blades on my Vento 24" & 16". Please advise.
Anyone aware of shop in Mumbai where I can purchase these, since in Vashi, Navi Mumbai, nobody stocks them.
At one of the shop there were wiper blades same type as Aerotwin by a company name DSC for Rs. 450 a pair for Vento. Any pointers.
el lobo 6061 is offline   Reply With Quote
Old 4th August 2012, 20:22   #626
shashank.nk's Avatar
Thanked: 734 Times
Hey I've been using the hella wipers on our car over that last year. Its been excellent till now. Had a problem with the drivers side wiper so had to replace it.
That apart, the passengers side wiper is over a year old but swipes like new. This after the car is parked in the open for 6 to 7 hrs a day.
Very good vfm ! Try it out
I found it in reliance auto too,u can check there.
shashank.nk is offline   Reply With Quote
Old 4th August 2012, 22:59   #627
Thanked: 9 Times
Here in the suburbs almost all the accessory shops have bosch and hella . opera house is your best bet .
M124 is offline   Reply With Quote
Old 5th August 2012, 00:38   #628
Thanked: 322 Times
I would suggest the Hellas. Both Dynaedge and regulars are available at Reliance stores
Old 5th August 2012, 01:35   #629
Thanked: 982 Times
Thanks, shashank.nk, M124, Mortis. Hella DynaEdge would it be.
But there are no Reliance AutoZones in Mumbai?
Old 5th August 2012, 15:27   #630
Tejas@perioimpl's Avatar
Thanked: 5,059 Times
Bosch calls them Aerotwin wiper blades. They are wonderful.
Bosch - Aerotwin Wiper Blades
Even Hella has come up with a similar product, however, i haven't used those.
EDIT:
Also read:
http://www.team-bhp.com/forum/modifi...rs-mumbai.html (Bosch Wipers - Mumbai)
http://www.team-bhp.com/forum/techni...our-wiper.html (How to maintain your Wiper)
http://www.team-bhp.com/forum/modifi...oon-drive.html
Tejas@perioimpl is offline   (2) Thanks Reply With Quote
VW Passat DIY: Replacing the Wiper blade element rpunwani DIY - Do it yourself 9 23rd June 2016 15:21
Palio Wiper Blade size RedMM340 Modifications & Accessories 10 22nd January 2010 17:15
Silicon/Water blade greenhorn Modifications & Accessories 4 7th October 2009 11:03
