Old 5th November 2012, 12:21   #676
Vid6639's Avatar
Thanked: 19,599 Times
Default re: The 'Wiper Blade' Thread
Originally Posted by sumathindra View Post
The rear glass :-) wiper size was 12" and got it replaced with the same size.
From where? I measured 10 or 11 last time. Noone had it. All said smallest 12" so went to Ford and paid Rs.650 for a new one with Ford stamp.
Old 5th November 2012, 12:53   #677
sumathindra's Avatar
Thanked: 192 Times
Got it in Konark in Jayanagar east end road. All 3 costed Rs. 445/-. Honestly I did not measure the stock wiper, the guy told me a 12" will fit and I asked him to change it. All this when it was pouring heavily last week :-(
sumathindra is offline   (1) Thanks Reply With Quote
Old 5th November 2012, 14:07   #678
nkrishnap's Avatar
Thanked: 4,163 Times
Hella has come out with the Dyna edge wiper blades in various sized. The sizes that I have seen till date at the Reliance Auto zone double road branch are
  1. 11 inch
  2. 14 inch
  3. 20 inch
  4. 22 inch
  5. 24 inch
  6. 26 inch
These should suffice quite a few cars. Just measure the blade length and pick the one that suits you.
Cost from 500 to 800 varying as per the size.
nkrishnap is offline   Reply With Quote
Old 7th November 2012, 17:23   #679
nkapoor777's Avatar
Thanked: 88 Times
  1. 11 inch
  2. 14 inch
  3. 20 inch
  4. 22 inch
  5. 24 inch
  6. 26 inch
But do check whether the adapter would fit your car. It doesn't fit the new-gen Fiats at least.
nkapoor777 is offline   Reply With Quote
Old 7th November 2012, 17:28   #680
nkrishnap's Avatar
True, the adapter for Linea and Punto is different. But both these cars come with nice wipers and the need to replace it with after market does not arise.
The Hella Dyna edge blade if bought for punto and linea will cost more than oem ones by around 200-300 bucks and the OEM ones cost around 1000 bucks, so 200 savings when replacing it. Atleast FIAT has not cut cost by giving ordinary wipers.
Old 5th December 2012, 08:35   #681
SunnyBoi's Avatar
Thanked: 2,796 Times
Changed front wipers to Bosch ClearAdvantage in the front for my S10. A pair of 24 and 16inches cost me 870 at Konark, Bangalore.
They're very good when the windscreen is totally covered with water. However they seem to stutter when there are light rains. Perhaps my windscreen needs the toothpaste treatment!
Used the old 16inch blade to DIY fit it on the rear wiper arm as well. All prepared for this round of rains!
SunnyBoi is offline   Reply With Quote
Old 17th December 2012, 08:18   #682
rishie's Avatar
Thanked: 30 Times
Tyre plus, HSR is out of stock for 24" + 16" combo of Bosch Clear advantage blades. ETA told was around 2 weeks, Just ring them up before going if someone is looking for this size of blades.
rishie is offline   Reply With Quote
Old 1st January 2013, 18:02   #683
RGK
RGK's Avatar
Thanked: 212 Times
Thought of changing the wipers for my 2 and 1/2 old Figo. Want to go for Aero Twins 22" and 16" blades.
Do anyone know where is it available in Chennai?
RGK is offline   Reply With Quote
Old 1st January 2013, 21:51   #684
Sheel's Avatar
Thanked: 4,987 Times
RGK ; I have used Bosch normal ones & they aren't a patch on Ford OE ones. In case you don't come across Aero Twins, stick with OE.
The OE ones cost approximately ~Rs. 850 (pair) & from what I have heard Aero Twins cost around Rs. 1,800 for a pair.
Sheel is offline   (1) Thanks Reply With Quote
Old 3rd January 2013, 11:45   #685
Thanked: 18 Times
Wink re: The 'Wiper Blade' Thread
Hi Guys,
Let me know if you guys need any Bosch Products for Automobiles. I know of a distributor near J. C road in Bangalore, so can have it arranged for you guys by speaking to him and since he is a distributor, the costs maybe lesser as well :-)
Cheers!
vikramv4u is offline   (1) Thanks Reply With Quote
Old 5th January 2013, 20:20   #686
ankan.m.blr's Avatar
Thanked: 496 Times
I purchased a new set of MGP blades from Pratham Motors, Bellandur for my Ritz in October. The wipers were not used after that. Recently I started the wipers when cleaning my car; I saw that the wipers are making the windshield hazy and there is a vibration while they are running on the glass. The windshield becomes so hazy after a wiper run, that I am not able to see though it. I find it hard to believe the wipers become ineffective in 3 months even without using them a single time. Is there anything wrong with my wiper motor assembly? Or should I go and replace the wipers again? :(
ankan.m.blr is offline   Reply With Quote
Old 5th January 2013, 20:33   #687
Schoudhury's Avatar
Thanked: 470 Times
I think the rubber might have become hard .
You can definitely change the wiper to something better , but I guess you can wait till the monsoon arrives .
Bdw I'm using Bosch aero twin on my Ritzy,if yoy want you can try those on yours.
Schoudhury is offline   (1) Thanks Reply With Quote
Old 5th January 2013, 22:14   #688
Thanked: 496 Times
Can you please tell me the blade sizes? Mine I think is 19" , 16". I guess VDI & ZXI sizes would be same.
Old 5th January 2013, 22:54   #689
Schoudhury's Avatar
Thanked: 470 Times
I got 22/16 blades for Ritz.
I think it should be the same for all the variants .
Cheers.
Schoudhury is offline   Reply With Quote
Old 5th January 2013, 23:19   #690
Thanked: 205 Times
Cheers.
How much did the 22/16 aero twins cost you? Is 900 a good price for the pair? Also how does the performance compare with the regular Bosch wiper blades?
naut is offline   (1) Thanks Reply With Quote
VW Passat DIY: Replacing the Wiper blade element rpunwani DIY - Do it yourself 9 23rd June 2016 15:21
Palio Wiper Blade size RedMM340 Modifications & Accessories 10 22nd January 2010 17:15
Silicon/Water blade greenhorn Modifications & Accessories 4 7th October 2009 11:03
