Old 17th June 2014, 19:55   #886
aghosht's Avatar
Thanked: 17 Times
Default re: The 'Wiper Blade' Thread
Originally Posted by unk9ja View Post
You could ask the dealer to show the pages on which single wipers are mentioned in the catalogue. There are single ones available too. You can pair these up as per your requirement and use.
Originally Posted by triedeverything View Post
We (a group of XUV 500 owners on FB) are ... Has anyone else recently installed aero twins for their XUV? Was there a compromise on the size that results in an unwiped patch?
You should also watch out for the connector type. See here.
aghosht is offline   Reply With Quote
Old 18th June 2014, 11:36   #887
WasavaTyres's Avatar
Thanked: 240 Times
Wink re: The 'Wiper Blade' Thread
the dealer says 19 inch blades are not available as a set for aero twins.
Aero twins were mostly shipped as singles, so it should not be an issue for the sizes. But getting Aero twins could be another story, due to the price not many retailers stock them as they cost nearly twice (in csome sizes thrice) of what normal wiper blades cost and hence are not quick off the shelf.
WasavaTyres is offline   Reply With Quote
Old 18th June 2014, 11:44   #888
aghosht's Avatar
Thanked: 17 Times
Try as I might I could not get Bosch 19" and 24" blades with the Top Lock connector. For explanations on connectors See here. I am told Bosch is only selling Hook type connectors here in India - don't know if its true or just ignorance at the retailers part.
Does anyone know if the above is true and if not can anyone help me with the part number so that I can give it to an authorised dealer and request him to find out.
Old 21st July 2014, 21:51   #889
Anoopscv's Avatar
Thanked: 23 Times
Can someone tell me if it's possible to get the wiper blade rubber(refill) alone? or should buy the wiper blade assembly?
Anoopscv is offline   Reply With Quote
Old 22nd July 2014, 07:03   #890
naveen.raju's Avatar
Thanked: 3,251 Times
You get it online. I have seen wiper blade rubbers alone in aliexpress, dx and few other sites. But guess these are local chinese make and not bosch.
naveen.raju is offline   (1) Thanks Reply With Quote
Old 22nd July 2014, 10:35   #891
Anoopscv's Avatar
Thanked: 23 Times
Any branded ones can be bought locally or online? or its only cheap Chinese make?
Old 22nd July 2014, 10:42   #892
Havent seen any branded ones. Just check aliexpress. You will have a lot of options and prices starts from 400 a piece.
EDIT: Bosch refills
http://www.autobulbsdirect.co.uk/Wip...efills-c-1392/
Old 22nd July 2014, 10:51   #893
mayankk's Avatar
Thanked: 3,507 Times
FYI, bosch has been making wipers in china since 2012.
You can pick them up from Ali, and they will not be cheap.
mayankk is offline   Reply With Quote
Old 31st July 2014, 17:12   #894
Thanked: 69 Times
Got the bosch aerotwin 26" for my etios just now from waterloo motors (bosch dealer) on tilak road, pune for Rs. 1200. The wiping is amazing! Cursing myself for using some cheap chinese copy of the aerotwin for the past one year.
raghuvir is offline   Reply With Quote
Old 2nd August 2014, 19:24   #895
Thanked: 1,083 Times
Can you quote the part number on the carton of the wiper. Someone was on the lookout a few pages back and there was no answer to it, hence this request.
unk9ja is offline   Reply With Quote
Old 2nd August 2014, 22:44   #896
Thanked: 69 Times
Sure thing! Part number for 26" (inches) Bosch Aerotwin Wiper blade (for Etios): 3397 008 122.
raghuvir is offline   (1) Thanks Reply With Quote
Old 6th August 2014, 16:56   #897
tasuray's Avatar
Thanked: 34 Times
My WagonR VXI (2013) has the wiper blades of 20" & 16" size. I have searched for 'Clear Advantage' by Bosch but a dealer told that it comes in the size of 20" & 17" in a pack. Now, I want to know that if I take 20" & 17" , whether it will work or create any problem for that extra one inch?
tasuray is offline   Reply With Quote
Old 6th August 2014, 17:07   #898
Originally Posted by tasuray View Post
My WagonR (2013) has the wiper blades of 20" & 16" size. I have searched for 'Clear Advantage' by Bosch but a dealer told that it comes in the size of 20" & 17" in a pack. Now, I want to know that if I take 20" & 17" , whether it will work or create any problem for that extra one inch?
AFAIK, the extra one inch wont be a problem. I have a similar case on my ecosport. Went for that extra one inch wiper and absolutely no problems. If you are buying from a local shop, you can check it before buying.
Old 6th August 2014, 18:06   #899
Sahil's Avatar
Thanked: 2,249 Times
I need 24inch & 20inch wiper for my Audi but they are the Push Botton type, same as the Skoda Superb's wipers. They aren't the usual hook system as most other wipers cars.
Is there a reputed brand like Bosch or Hella available in this size and push button system?
I was forced to buy from Skoda this monsoon as the long brand I could find with this system in the open market last year was syndicate. Those turned out to be of horrible quality. The Skoda original ones costed 4000 a pair!
Sahil is offline   (1) Thanks Reply With Quote
Old 12th August 2014, 23:20   #900
moralfibre's Avatar
Thanked: 6,214 Times
Default List of available Bosch wiper blades! Have a safe monsoon drive!
Picked up a pair of Bosch clear advantage blades for my Swift. They came as a set and cost me ₹ 840/- after discount. Initial impression is satisfactory as the wipers tend to leave a smudge on the edges. Will update with more details after I undertake a long drive to Goa this weekend.
Neatly packed set. The clearadvantage blades offer a cost advantage over the twice as expensive Aerotwins:
Frameless design is same as the aerotwin:
Installation instructions:
Part number for the Swift:
Clearadvantage catalogue:
Old Aerotwin catalogue:
moralfibre is offline   (3) Thanks Reply With Quote
VW Passat DIY: Replacing the Wiper blade element rpunwani DIY - Do it yourself 9 23rd June 2016 15:21
Palio Wiper Blade size RedMM340 Modifications & Accessories 10 22nd January 2010 17:15
Silicon/Water blade greenhorn Modifications & Accessories 4 7th October 2009 11:03
