| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here! |
| | Thread Tools |
| | #46 (permalink) |
| BHPian | Zak, Dont paint your hoses or any rubber parts - 2 reasons 1-All paints contain solvents, most hoses & natural rubber parts will be affectced by these solevents and lead to deterioration & leaks 2- In the event that any hoses etc are aging and due to fail/ be renewed, you will never be able to tell that the part is on its way out as there will be a coat of paint disguising/covering any defects or wear. Not advisable at all
__________________ The Swift DZire has a 6 Month waiting period to give you time to seriously reconsider buying something that Ugly |
| | #47 (permalink) |
| Senior - BHPian | Thanx Revvhead! What about painting the metal pipes like AC pipes, Brake liners, Airfilter pipes etc.. ? And what about painting the engine itself? Not the whole thingy, but those shiny parts which are seen outside?
__________________ If you want to see a rainbow you must first sit through the rain. (Hungarian Proverb) |
| | #49 (permalink) |
| BANNED | Hi, To answer your question, I had my callipers painted screaming yellow on my Esteem about 6 years ago, & the paint never wore off / faded / darkened. Used the same paint for the Lancer's pads in Feb this year, & no change so far... I've also had my rear drums painted black on both cars. All with a brush. The only thing that'll make them look bad is road grime & brake dust, which you need to get washed off regularly, maybe during your service. The paint used: regular oil paint (Nerolac, methinks). Works wonders, dunno about paint pricing specifically, though I paid Rs. 250.00 for labour, brush & paint! ------------------------ All those guys who wish to paint discs, engine bits, etc.: Dudes, I suggest you go out & buy about 40 litres of oil paint to paint your engine. You could use a brush / spray, but a better idea would be to just empty the entire bucket onto a cold engine. That way you'll get paint in all the crevices, etc. & shall get an even, finished, 'professional' look. After you finish slathering your engine bay, close the bonnet & start the engine. This will serve 2 purposes: 1. The whirly bits that go round & round in the engine bay shall splatter the paint all over the insides of the bonnet, giving you a custom paint job for your engine. 2. Your paint will dry to a high gloss shine due to the heat. For an even more professional look, & to really impress your tuner, you should empty out another 20 litres of paint into the gas tank & the intake manifold. That way, even the insides shall be coated with the paint of your choice. I suggest you use contrasting colors so you get a nice effect & avoid that boring steel grey that comes as stock. Painting your discs can be done the same way. Personally, I don't think you should stop there... Buy more paint (another 40 litres?) & paint your windscreens, taillamps, headlamps, seats, dashboard, pedals, windows, etc. Think of it that way, it's never been done before. Imagine the money you could save on window film, seat covers, etc. WARNING & DISCLAIMER: These modifications might be illegal & dangerous. You are advised to check with your authorised service centre & / or mechanic before doing this. You should also post their advice / reaction to your desires here to warn other people who'd like to do this. Last edited by elf : 18th July 2006 at 19:15. |
| | #50 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
__________________ There is a very fine line between "Hobby" and "Mental Illness". | |
| | #51 (permalink) |
| BANNED | Oops, forgot to add... The brake pads have this dirty habit of scrubbing the paint off your newly painted discs over time, so there's mod for that as well... There shall be a thin metal pipe connected to a rubber pipe over your brake calliper. Simply disconnect that pipe. Some dirty reddish / whitish fluid may leak when you do this. Don't worry - it's normal. After all the fluid has leaked out, tie a small knot into the rubber hose. You could also crimp the metal tube if you like, for a more professional look. Now go out & have fun. The disclaimer at post #58 still stands. Last edited by elf : 18th July 2006 at 19:17. |
| | #52 (permalink) | |
Elf - Despite the disclaimer you do know that you are going to be in big trouble soon right!! Some wisecrack is going to try these EXPERT mods you know ![]()
| | #54 (permalink) | |
| Senior - BHPian | Quote:
Some nice and very much easy advice you've got lined up here. ![]() But of a serious note, Do you mean to say that no engine painting should be done whatsoever???
__________________ If you want to see a rainbow you must first sit through the rain. (Hungarian Proverb) | |
| | #55 (permalink) |
| BANNED | I personally don't think much of do-it-yourself engine painting. You may be able to procure pre-colored (factory) bits & pieces, which have been anodized or powder coated. These have been done with paints / coatings tested specifically for the temperatures present in your engine bay. For example, you may get an anodized intake pipe for your high-velocity aftermarket intake filter. The paint / coating / anodization would have been tested to ensure that it would not peel / crack under normal running of your vehicle. Simply slathering paint onto a pipe would do you no good whatsoever, as (from personal experience ) I have found that the paint simply flakes off.The same goes for the tappet cover painting. If you can manage to find the specialized paint, it should work for you, but remember that theoretically, it may lead to higher temperatures due to the different heat conduction properties of the paint compounds. So, to answer your question, if you think you have a good paint / coating & the requisite experience & knowledge to go around making your engine bay your coloring book, please do so by all means. Methinks you should also take the opinion of Viper, Arush, Ported_Head, Nitroxx, & other guys that may have done this before. Ciao! _________________________________ & for the morons... in case you didn't get it, I was kidding in the earlier posts... So don't come after me if you nuts actually do what I was kidding about. |
| | #59 (permalink) |
| BHPian Join Date: Nov 2005 Location: Bombay
| I think its quite lame to paint the calipers of any car that has drum brakes at the rear. Painted drums are particularly hilarious... Its like shouting, "look, i have a slow car with antiquated brakes". On an Alto? Please dont. |
| | #60 (permalink) |
| Senior - BHPian | i"ve painted my brake callipers and Engine accents. It sure looks good. No one paints the brake drums!! Very rare maybe! I have'nt done so.
| Thread Tools | |
Similar Threads | ||||
| Paint for disc brake pads & rear brake drums | VC12 | Modifications & Accessories | 6 | 20th August 2007 16:45 |
| Only brake OR clutch+brake | swiftcrazy | Technical Stuff | 8 | 10th July 2007 23:19 |
| My accident - Bad brakes, bad rain, bad luck... | vezj420 | Street Experiences | 41 | 22nd May 2007 10:49 |
| radial brake callipers? | diesel_headrock | Motorbikes | 1 | 15th August 2006 01:05 |
| bad bad NSX | manticore | The International Automotive Scene | 17 | 20th May 2004 15:52 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
