Old 14th August 2014, 22:30   #1
Thanked: 1,264 Times
Default Electrically-folding ORVMs - Aftermarket options?
Could not find any related thread, hence creating a new one. For cars with electrically operated ORVMs is it possible to use aftermarket solutions to add the auto folding/retracting functionality?
I understand this comes as an optional accessory in the Toyota Fortuner. Is this possible in other cars e.g. Toyota Innova?
sachinayak is offline   Reply With Quote
Old 16th August 2014, 14:22   #2
IshaanIan's Avatar
Thanked: 3,131 Times
Default Re: Electrically-folding ORVMs - Aftermarket options?
It most certainly is. I know a place in Hyderabad that does this so there definitely ought to be a few options in Bangalore
IshaanIan is online now   (1) Thanks Reply With Quote
Old 17th August 2014, 12:06   #3
Thanked: 21 Times
I would sincerely suggest you not to let after-market dealers tamper with the circuit of a car as reliable as Innova or Fortuner. A cut in the wire at the wrong place to draw current can have irritating long-term effects. Electrically-folding is a nice to have feature but not a must-have feature. Electrically-adjusting in contrast is a must-have feature which I am sure you car would have. Finally, your call, your are the master of your car! :-)
anujatwork is offline   (2) Thanks Reply With Quote
Old 17th August 2014, 17:25   #4
joybhowmik's Avatar
Thanked: 1,905 Times
It just might be possible to fit the Fortuner's harness(related to this feature) into the Innova
But as the folding would depend on a different servo motor - which spins along the axis of the joint...you are probably going to be looking at replacing the old mirrors altogether.
Now a pair of the Innova mirrors (electrically adjustable but not folding) - itself costs Rs 20k. Assuming the Fortuner's mirror set costs at least that (but probably more) , and a few K for the harness.
And you can ask at the spares department for the kit, and get it fitted by a competent electrician.
But do you want to go through all this hassle and expense just for the joy of folding it? Surely more easily done by just folding them shut with your hands.. isn't it?
Old 17th August 2014, 21:14   #5
batterylow's Avatar
Thanked: 677 Times
Originally Posted by joybhowmik View Post
Now a pair of the Innova mirrors (electrically adjustable but not folding) - itself costs Rs 20k. p
The Figo's electric mirrors cost me about 2k apiece (1.3k for the housing & motor + 350 for the mirror + ??? for the plastic cover)
Considering that,I find the cost of the Innova's mirror atrocious!
batterylow is offline   Reply With Quote
Old 17th August 2014, 22:14   #6
joybhowmik's Avatar
hold on.... I did not tell you about the labour - add another 600 for that. And essentially you can see how quickly the money drains from the pocket.
Old 18th August 2014, 23:31   #7
Wow. Thanks for the feedback. Wonder why such a huge price difference.
The reason I was considering this is that my daily office route takes me through some narrow by-lanes and having electrically folding mirrors is very useful, specially if you have a wide vehicle (btw, i currently drive a Manza, which is pretty wide and am planning to get a pre-owned Innova). When you have to squeeze in those tiny gaps, it does help to have retractable mirrors, for sure.
That said, i first chanced upon this thought when reading one of the ownership threads on the Fortuner, which indicated that the cost of adding something like this should cost around 4-4.5K, which i think is reasonable.
In hindsight, i think i misread the context. Fortuner perhaps comes with electrically retractable mirrors, which is missing on the Innova (at least the 2009-2012 models) and thus the additional cost involved in just for the auto folding option.
Old 19th August 2014, 07:19   #8
Thanked: 159 Times
The costliest part is the auto folding mirror. But you can try to source the same from some car used parts dealer. If your car model has a top variant from manufacturer with retractable mirrors then things become easier as you can get all the necessary parts like the folding switch and the wiring harness along with the mirrors. If not then you need to build a harness. Will not go in much details but for folding or unfolding the mirror there would be 2-3 wires which you need to connect to battery and use a aftermarket switch and you are done. Sounds complex but a good electrician can do the wiring in an hour or so.
malgudi is offline   Reply With Quote
Old 19th August 2014, 21:00   #9
97_Octane's Avatar
Thanked: 75 Times
Was looking out for a similar option for my Ecosport. Power folding mirrors are sorely missed
I don't understand why Ford would not provide such a useful feature on a 12L+ car. My daily route also takes me through small narrow streets. Having power folding mirrors would be so convenient!
But then again, I wouldn't want my car's wiring to be tampered outside Ford themselves.They could provide it as an accessory at least (even the Grand i10 Sportz comes with these). Ford, are you listening?
97_Octane is offline   Reply With Quote
Old 19th August 2014, 23:31   #10
djoel99's Avatar
Thanked: 17 Times
Are you sure cedia does not have this feather as my 2004 lancer has it.
You can try and use some parts from lancer.
djoel99 is offline   Reply With Quote
Old 2nd April 2016, 16:07   #11
ecosport rules's Avatar
Thanked: 1,341 Times
Can you please share the Hyderabad address?
Did you find a solution for the auto fold ORVM's for your Ecosport ?
ecosport rules is offline   (1) Thanks Reply With Quote
Old 2nd April 2016, 17:34   #12
IshaanIan's Avatar
Road No. 4 Banjara Hills after you take a right at the vet on the left side. Got this done on a friend's Baleno many years ago completely out of touch with the owner and forgot the name of the store unfortunately
Old 3rd April 2016, 00:11   #13
Thanks for the quick response.
It it between Dr.Laxmi's clinic and Meriden school?
ecosport rules is offline   Reply With Quote
Old 3rd April 2016, 00:24   #14
IshaanIan's Avatar
Yup exactly Let me know how it goes or if even if there is a shop left there anymore. I could suggest a few other guys who might know how to do it (not sure since I would not have ever had such a job done by them)
Old 16th August 2016, 09:59   #15
97_Octane's Avatar
Thanked: 75 Times
Unfortunately I haven't found a satisfactory solution for this. Have learned to live with it (or should I say without it ) now.
Electrically Adjustable Side-View Mirrors gd1418 Modifications & Accessories 16 11th July 2013 08:05
Retractable ORVMs. Boon or burden (folding them manually)? pgsagar Technical Stuff 42 7th September 2011 14:16
Integrated Head Units - Is this the death of the aftermarket for aftermarket HU's ajmat In-Car Entertainment 44 27th July 2011 16:48
Am I Electrically overloading My Maruti 800 ? Trust_In_Thrust Technical Stuff 39 18th April 2009 13:15
Indian Cars/SUV's with electric folding ORVM dadu The Indian Car Scene 21 7th August 2007 09:43
