Old 8th December 2006, 08:24   #16
viper's Avatar
Thanked: 9 Times
Originally Posted by hellspawn View Post
are webber dcoe's easily available.
a carb esteem engine would produce close to 65bhp...am i right?pls correct!!
a mpfi esteem engine would produce 85bhp.so can the two webber carbs produce 20bhp to equal a mpfi e-engine.
wouldnt it be easier to buy a mpfi along with the ecu and plonk it directly into the zen.
does the ecu take into acount the drive ratios of the gearbox because then there might be some problem if you were to stick with the zen gearbox.
A Zen fitted with a single weber would smoke a Mpfi zen if set up correctly. This is assuming both cars have basic mods like exhaust & filters. With twin webbers he would kill the mpfi zen.
The answer to your 2nd part is no. It snot a simple a job as you make it out to be to convert a Carb car to MPFI, lot sof wiring involved and would be expensive as well.
Viper
viper is offline   Reply With Quote
Old 10th December 2006, 05:12   #17
hellspawn's Avatar
Infractions: 0/1 (10)
@viper:are you talking about the carb zen with weber versus the mpfi zen.
or are you talking about a carb e-zen with weber versus the mpfi e-zen.
since i have a mpfi zen was wondering which would be better.a carburetted esteem engine or a mpfi esteem engine.
hellspawn is offline   Reply With Quote
Old 10th December 2006, 09:04   #18
viper's Avatar
Thanked: 9 Times
I am referring to same capacity engines. I prefer a Carb setup. All depends on your tuner.
Viper
Maintenance cost - Maruti 800 Carb and MPFI models vinfriend Technical Stuff 9 17th November 2009 12:16
MPFI or CARB. for CNG breezydrive Technical Stuff 5 15th November 2007 23:06
Carb/MPFI - Which is having longer engine life ? mithun Technical Stuff 47 10th October 2007 01:58
carb or mpfi? which gives more power? iceman91 Technical Stuff 18 5th April 2005 10:48
DO MPFI cars have CARB's kakx Technical Stuff 9 25th April 2004 00:54
