Old 31st March 2011, 10:34   #406
sumathindra's Avatar
Thanked: 205 Times
Default Re: Reverse camera or Sensor ?
Can someone help me in deciding in chossing a reverse sensor or a camera for my figo. Would it be better to have it fitted at ford showroom or buy outside? Waiting for a quick response as i intented to get this on saturday...
sumathindra is offline   Reply With Quote
Old 31st March 2011, 11:40   #407
Thanked: 158 Times
Usually you don't need any thing in/for Figo. However if you think you need it, install reverse sensor. It saves your pocket and does its job (camera will add little more). I always suggest not buy it from showroom. RS installation doesn't cuts any wire, so it won't void any warranty (as Showroom might claim) if you do it outside. The price difference is enormous.
I had reverse sensor installed in my fiesta from Redsoul directly! Same model quoted by lathangi is 6.5K, where redsoul gave me for 3.5K! My parking system has a 4 back sensor, with distance shown in IRM (its IRM comes with RPS).
RaguHolla is offline   Reply With Quote
Old 31st March 2011, 11:47   #408
mayankk's Avatar
Thanked: 3,559 Times
If youre sticking with the factory HU, take the sensors.
cheaper.
If planning to upgrade to a compatible 2DIN, then camera will work out the same.
mayankk is online now   Reply With Quote
Old 7th April 2011, 18:13   #409
Thanked: 205 Times
wow,exhaustive thread.
Does anybody know if the reverse camera can be connected to a mapmyindia navigator?
I mean,it plays videos etc, so it should be a possibility,eh?
yes vx240 is capable of RVM fotage as well...
Old 7th April 2011, 20:18   #410
mayankk's Avatar
oh yeah,now you tell me.......
already splurged on something else.
but just out of curiosity, how?
Old 7th April 2011, 20:41   #411
siddheshb's Avatar
Thanked: 251 Times
Sensors seem to work better, cameras get covered in mud/spray during the rains, for example, when they are needed the most!
siddheshb is offline   Reply With Quote
Old 8th April 2011, 17:25   #412
Awaiting Email Confirmation
No such complaints with my camera sensor, but then I do not go off roading
I also got an extra wiring + switch installed to use the sensor even while driving and this has been helpful in maintaining safe distance from autos and other aggressive drivers in bumper-to-bumper traffic, signal stops and turns etc.,.
Vijay
vjoy3 is offline   Reply With Quote
Old 8th April 2011, 17:54   #413
mayankk's Avatar
@vjoy3: please elaborate.dont these sensors warn acoustically?
would be annoying to hilt in b2b traffic....
or do you use just the visual cues, cutting out the sound.
Old 12th April 2011, 14:42   #414
No they don't warn acoustically during regular driving - just the live visuals. Got the setup done in showroom itself since I wanted these extra wiring and a bill to show just in case had issues.
Vijay
Old 12th April 2011, 19:43   #415
hiren.mistry's Avatar
Thanked: 250 Times
Hi all,
I plan to install parking sensors for my Civic, want to go in for 6 sensor set up (2 front and 4 rear). Have sent an inquiry to RD for 950 and 970 models.
Does anyone have them installed on their cars?
hiren.mistry is offline   (1) Thanks Reply With Quote
Old 24th May 2011, 23:05   #416
tachobells's Avatar
Thanked: 115 Times
Has anybody thought of buying an OEM camera-mirror set from new Hyundai Verna and fitting it on other cars? Will it work? How much does it cost?
tachobells is offline   Reply With Quote
Old 29th May 2011, 15:14   #417
Thanked: 364 Times
I have a question on the acoustic parking sensors - How accurate can they be? I usually park my car very close to the wall and looking for a solution that gives an indication of the distance between the rear bumper and wall to the last mm. The standard one's that i have seen are programmed in such a way that they give a warning indication when the distance is around 50mm of so from the object, but doesnt do a count down till the last mm. Do you have any recommendations or suggestions for me?
bala80 is offline   Reply With Quote
Old 23rd June 2011, 01:10   #418
I got redsoul 4 sensor installed in my grande punto and it works flawlessly. The display is through a small unit placed on the dash. Cost including fitting 3.5K. It has voice in place of buzzer. It keeps showing distance till 0.3m, below which it says "STOP". Will post a small video demo tomorrow.
smilyinblue is offline   Reply With Quote
Old 23rd June 2011, 10:02   #419
mayankk's Avatar
why would you want get so close?
50mm is just 5cms.
most of these sensors are preprogrammed with such a threshhold, so its highly improbable that youll get something OTS looking at the last mm also.
plus its got something to do with sonics also, that the feed generated at such low levels may/may not be accurate.
you could try a video option if you want to get so close.
a camera with 120+ degree field of view perhaps?
Old 23rd June 2011, 10:14   #420
Thanked: 205 Times
Post the pics please. I am yet to decide if i need to go for a reverse camera or the sensors will do.
Extra mirror for reverse sensor; what happens to OEM Day/Night Mirror? libranof1987 Modifications & Accessories 15 16th September 2016 18:14
RedSoul reverse sensor marathp Modifications & Accessories 0 18th October 2010 18:19
Cam Sensor-Crank Sensor-TDC Sensor. Are They The Same Thing? genesis Technical Stuff 8 5th October 2009 11:17
