View Poll Results: What would you prefer: Engine Swap or Forced Induction
Engine Swap 12 50.00%
Forced Induction 4 16.67%
Both !! 8 33.33%
Voters: 24. You may not vote on this poll
Closed Thread
Old 9th August 2006, 00:19   #61
Sideways's Avatar
Thanked: 18 Times
Originally Posted by v1p3r
Jitu, I thought the only restriction on JDM cars was that the speedo shows only 180 kmph. I've seen this in a 3000 GT, and in JDM bikes like the Honda X-11. Didn't know the engine output itself was restricted to that max speed.
Akshay, whilst the speed remains restricted power is not. I have maxed out on the speed of my car but still have about 2300 rpm more until redline. There is a speed densor in the gearbox which is linked to the ecu. When you touch 185, the ecu induces a fuel cu ans restricts you from going faster. This connection can however by disabled if you have the ECU wiring diagram. i have not done it myself but have read about it in another forum, specifically run for people who are running mivecs.
www.mivec.co.nz
You will find more information there.
Sideways is offline
Old 9th August 2006, 00:21   #62
Sideways's Avatar
Thanked: 18 Times
Apparently on disabling this feature the car maxes out at 257Kmph. Crazy stuff.
Sideways is offline
Old 9th August 2006, 00:38   #63
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
Complete drool maal .. I still insist , where is that ride u promised us in ur MIVEC .. Its been two track days since and more than 3-4 months ..
mclaren1885 is offline
Old 9th August 2006, 00:41   #64
Sideways's Avatar
Thanked: 18 Times
next time you are here. Pukka.
Sideways is offline
Old 9th August 2006, 00:53   #65
v1p3r's Avatar
Thanked: 27 Times
That will be very soon, if things go to plan.
v1p3r is offline
Old 9th August 2006, 01:53   #66
veyron1's Avatar
Thanked: 38 Times
Great stuff so far. Ok then- in summary...
1) TC'ing is ultimately the way to go either ways, bot not as yet. Not enough experience/equipment here.
2) Swapping is the best compromise. Gives you a better bargain.
3) At least for the next 3 years, until we have skilled application-specific technicians, still deeper knowhow and better resources, swapping is the way to screaming performance with peace of mind.
4) From some rough calcs, swaps seem to be more VFM as well, since you don't end up with holes in your piston or melted plugs/poppets or cracked gudgeon pins every other month.
5) The best bet seems to be; Go for a swap, run for 2 years and when you get tired, boost it (in case of N.A; in case of a existing TC a'la the MIVEC or so, increase in boost....), since people would have enough knowhow and equipment for it then.
@mclaren; A neatly overhauled B18c, N.A, in factory spec, belts out 210 horses at the crank....
veyron1 is offline
Old 9th August 2006, 02:24   #67
v1p3r's Avatar
Thanked: 27 Times
Hey Veyron, just to point out, MIVECs don't come with factory turbos on them. And the highest a B18 has ever put out in factory trim is 197 bhp, from the JDM B18C5.
v1p3r is offline
Old 9th August 2006, 12:44   #68
Sideways's Avatar
Thanked: 18 Times
I think Veyron has sumarrised this entire discussion excellently. If the moderators wish to close this thread they may do so. As far as costs for both option are concerned I would request all to please PM me and i can provide you with the necessary details. Thank you everyone for your inputs.
Sideways is offline
Old 9th August 2006, 13:14   #69
Thanked: 11,013 Times
Thanks Sideways and Veyron for your wise words
due to sensitivity issues which occured earlier, I succumb to temptation and am closing this thread
ajmat is offline
Closed Thread
Engine Swaps for M800 Tazzy Boy Modifications & Accessories 11 9th November 2012 00:27
Modified MM550XDP 4x4 my daily use "car" RedMM340 4x4 Vehicles 83 20th September 2011 16:11
Battery question - Can I use Indica Spec Battery in Scorpio, or other such swaps? shekharlele Technical Stuff 18 7th September 2010 09:05
engine swaps deathrow Modifications & Accessories 10 18th July 2005 12:21
