Old 29th May 2015, 20:13   #1
Thanked: 25 Times
Default Too short to drive! Unable to push brake pedal
Hi All
My wife has been happily driving her i10 and uses a pillow for that minor assistance and hopefully continue ever after
Now the problem started when she wanted to drive my XUV. She is unable to push the brake pedal all the way
Now, if you can't stop the car then you better not drive it
Can anyone guide me if I can have an modification which can allow me to take care of the problem
vaibhavdalal is offline   (1) Thanks Reply With Quote
Old 30th May 2015, 15:47   #2
SS-Traveller's Avatar
Thanked: 11,626 Times
Default re: Too short to drive! Unable to push brake pedal
Solution 1: Change car.
Solution 2: Change wife.
Solution 3: Buy 6" platform heels for wife.
Naah, just kidding! No offence intended.
The usual solution is to use a set of pedal extenders. A thread exists about it on Team-BHP too (Pedal Extenders), though there's not much information there. You could either do a DIY such as in the following video:
or you could choose to buy them from proprietary manufacturers such as
or http://www.pedalextenders.com/
I don't see any direct sellers in India though. You would likely have to import them.
SS-Traveller is offline   (10) Thanks Reply With Quote
Old 30th May 2015, 20:19   #3
Thanked: 201 Times
.... if I can have an modification which can allow me to take care of the problem
Any adjustment in seat possible ?
Or change the seat itself which has slightly lesser height and lesser steering to seat gap.
Ravindra M is offline   Reply With Quote
Old 31st May 2015, 20:15   #4
Thanked: 25 Times
I am happy with my XUV so won't be changing that for sure
Now changing wife, it's cheaper to change your car
As my wife says "want another girl in life? Can you afford to??
Looking at diy option now, will get in touch with a fabricator for making the pedals
Last edited by ampere : 31st May 2015 at 20:43. Reason: Removed the video link from the quoted post
vaibhavdalal is offline   Reply With Quote
Pedal/Seat modifications for short people vsathyap Modifications & Accessories 8 6th September 2011 20:34
Brake pedal too high, causing right leg pain ulhas.ahirrao Technical Stuff 16 4th February 2011 11:44
Too much ride in my cluth pedal after servicing ghostrider4385 Technical Stuff 5 27th May 2007 21:40
