Old 18th July 2007, 10:50   #16
aZa
aZa's Avatar
Thanked: 17 Times
Yes you are right bout the 2 cylinder thing Aditya! Why not try and get ur hands on a tacho which has a 2 cylinder option. This option is usually called "DIS COMPATIBLE". When using a DIS compatible tacho u can get the correct signal/output from just one of the ignition coils.
Old 18th July 2007, 11:20   #17
gd1418's Avatar
Thanked: 656 Times
You still didn't let out from where you got these. I might be inetersted in the voltmeter, Vaccum, Boost. If also you could let know the size of hole it would drill in the pocket...
Originally Posted by aZa View Post
I have this one faithless bhai, but i wont suggest u buy it till i solve the RPM issue. it revs only till 3K
Old 18th July 2007, 12:52   #18
aZa
aZa's Avatar
Thanked: 17 Times
GD!! It was available with DRIVEN before he shutdown. The meters were about for 1800-2500 and the Stands/pods were for Rs500
Old 26th July 2007, 19:23   #19
jkdas's Avatar
Thanked: 1,436 Times
does the limited edition Xing come with tachos? ( and maroon upholstery) ?
Old 26th July 2007, 22:06   #20
aZa
aZa's Avatar
Thanked: 17 Times
Yep JKD, The limited edition comes with a tacho and "hooded" intrument panel ( i think ) and Dark red/ maroon fabrics all around seats + panels. It also has Alloys and spoiler.
Old 26th July 2007, 22:34   #21
Deepz's Avatar
Hi, I cant help with the installation bit, but I do have a AutoMeter Tacho on my santro, it works perfectly and is quite accurate. You can see the RPM rize a little as soon as I put the A/C on. Its a very simple one with cool blue back-light and an in-built shift light with maual adjustment.
Deepz is offline   Reply With Quote
Old 21st August 2007, 20:11   #22
jkdas's Avatar
where did you get the meter from? Could you post pix of it.
The service centre guys said they will help me fix one if I get one.
Old 21st August 2007, 20:37   #23
m4ugr8's Avatar
Thanked: 123 Times
Originally Posted by harsh87 View Post
i bought it from malaysia and cant find anyone to install it in delhi anywhere
You can try autopsyche or try out drivens shop in east of kailash....I show he has fitted a tacho in a swift Lxi which does not have a tacho signal....
m4ugr8 is offline   Reply With Quote
DIY tacho for a car, using a bike's tacho ilangop DIY - Do it yourself 64 25th November 2016 14:59
DIY: Tacho Install in Maruti WagonR vishwaschettri DIY - Do it yourself 45 17th November 2013 15:35
Tacho for Santro deepak_ms Modifications & Accessories 50 3rd June 2009 13:01
tacho meter sanket12 Shifting gears 1 9th February 2005 12:12
RaceR Tech tacho blown! steroidauto Modifications & Accessories 7 5th January 2005 13:23
