Old 28th August 2006, 13:23   #1
Ram
Ram's Avatar
Thanked: 149 Times
Default Maruti 800 rear wiper
We'd like to have a wash-wipe system on backlight of our 2002 Maruti 800.
Has anybody installed this on their Maruti 800 (1987-to-current model)?
I know that high-end Zens and Altos came with them.
Seeking your experience-based recommendations.
Ram
Ram is offline   Reply With Quote
Old 28th August 2006, 15:42   #2
Thanked: 167 Times
Did this on my 1990 model 800. Unfortunately I have sold the car so cant show you a pic of this. Although this helps during rains, the motor and the wiper will considerably increase the weight of the rear door. The single rear door Spring(cant think of another word for that black thing that keeps your rear door open. Zen and Alto have 2) will not be able to take this increased weight and it would be really irritating as you would have to manually hold the rear door every time you need to keep/remove something from rear. So if you do this do think of adding another spring or some other way. Hope this helps
Malgudi
malgudi is offline   Reply With Quote
Old 28th August 2006, 15:58   #3
Rtech's Avatar
Thanked: 221 Times
This is something I would love to get done on the Octavia as well. The earlier models came with the rear wash/wipe, but the cost cutting meant that it didn't make it to the Indian made Octi's.
Old 28th August 2006, 15:59   #4
Thanked: 11,067 Times
Consider using Rain X or similar to enable the water to bead and run off.
Old 28th August 2006, 16:05   #5
Rtech's Avatar
Thanked: 221 Times
Thats ok, but the grime and dirt becomes a problem at times. Wish they had left the rear wiper and got rid of the wing mirror heaters instead!
Old 29th August 2006, 09:05   #6
Apparently, the Octy abroad never came with a RRW then customers demanded it so it was later added. India seems to be rather backward on this - witness the new Wagon R - rear wiper no longer an option -
Ram - consider using a ZEN or wagon R rear wiper components. Since rear screen is flat, there are not too many issues
Fitting rear wiper to Maruti A-star humveeguy Modifications & Accessories 15 2nd December 2011 01:02
Maruti 800 Wiper mounts collapsed (due to rust) sumeethaldankar Technical Stuff 11 25th September 2011 17:21
Maruti 800 Combination Switch and wiper washing Jehan-Sam Technical Stuff 0 20th February 2009 12:13
EPS and Rear Wiper for M800 sureshshanmugam Modifications & Accessories 9 1st October 2007 17:38
rear wiper for swift lxi CarDude Modifications & Accessories 18 18th February 2007 01:18
