Old 2nd September 2015, 11:49   #1
Chethan B G's Avatar
Thanked: 788 Times
Question OBD2-interfaced Digital Display
I am thinking of a dashboard gadget which would give us real time information on the following TDI engine parameters:
  1. Air flow, Intake temperature, Boost pressure and Turbo RPM.
  2. Engine load, Rail pressure and Engine oil temperature.
  3. Exhaust gas temperature.
  4. Gearbox oil temperature.
  5. Power / Torque figures based on map presets.
  6. Read / clear error codes.
  7. Setting alarms for Boost pressure / Engine oil temperature / EGT / GB oil temperature / Air flow.
Instead of installing additional sensors OR connecting available sensors individually; it would be simple if the gadget could connect (wired or BT) to OBD2 port of the car, to acquire information from the CPU.
This information would help us enthusiasts to know what is actually happening inside the engine and would be of great advantage in a remapped car.
I found this as I was browsing through the web: Banks iQ for 2009-2014 VW & Audi 2.0L & 3.0L TDI 61201
Link: http://www.ebay.com/itm/Banks-iQ-for...8792#vi-ilComp
There is one more solution for android based smartphone users: If a BT-OBD2 adapter is purchased online, an application called "Torque" is available for download from play-store, for a fee. There are mixed reviews on this and I am not sure if it works.
I am aware of the VCDS option. But that would be cumbersome to leave it connected all the time. Or is it?
I wanted to know if any of our forum members are already using any of these gadgets OR better still; If anybody is aware of a easier / affordable / solution.
Kindly suggest!
Thanks in advance!
Chethan B G is offline   (1) Thanks Reply With Quote
Old 2nd September 2015, 13:27   #2
devilwearsprada's Avatar
Thanked: 919 Times
Default re: OBD2-interfaced Digital Display
Originally Posted by Chethan B G View Post
Kindly suggest!
Thanks in advance!
Just out of curiosity, in case you are running a fully equipped track car, you might need a data logger always on.
However, for general logging needs you are better off with a good software and an OBD connected to a laptop or VCDS.
devilwearsprada is offline   (1) Thanks Reply With Quote
Old 2nd September 2015, 13:45   #3
Dr.AD's Avatar
Thanked: 1,241 Times
Although not for a VW, but for my Maruti SX4 I am using an OBDII adapter (ELM327) and Torque app on my phone and it is working perfectly fine. Overall I am a very happy user of this combination. I have given more details of my setup here: http://www.team-bhp.com/forum/modifi...cessories.html (Review: My "Instrumentation" (Torque Pro/OBDII setup, TPMS etc.) and related accessories)
However, in that thread, someone has pointed out that the ELM327 adapter did not work on Skoda Fabia. That makes me wonder if the VW group uses a proprietary protocol or is there something else going on with Skoda. In general, all cars in India made after 2010 support OBDII protocol, and VW should support that too. But I am not yet 100% sure about this given the one Skoda experience that I read.
Dr.AD is offline   (2) Thanks Reply With Quote
Old 2nd September 2015, 15:17   #4
Thanked: 788 Times
Arrow Re: OBD2-interfaced Digital Display
This the very reason I was looking for a real time meter, but in a different sense. Sounds thrilling to understand the functioning of various parameters.
I know this looks stupid; More so, since it is an expensive option.
Chethan B G is offline   Reply With Quote
Old 2nd September 2015, 15:39   #5
jkdas's Avatar
Thanked: 1,436 Times
Default Re: OBD2-interfaced Digital Display
I use and there are few here who use it a lot.
http://www.team-bhp.com/forum/techni...dian-cars.html (OBD (On-board diagnostics) for Indian Cars)
The best one should be the below one ( which he now uses in his Nano AMT!).
http://www.team-bhp.com/forum/test-d...display-5.html (My City warrior! Figo TDCI with a custom heads-up-display)
jkdas is offline   (2) Thanks Reply With Quote
OBD2(VAG-COM) cable + workshop manual saraf_suman Technical Stuff 13 10th October 2013 12:16
OBD2 Parameter IDs (PIDs) and what they mean? Sankar Technical Stuff 15 30th August 2012 19:39
Looking for digital clock + temperature display for NHC hrishig Modifications & Accessories 10 30th May 2010 10:15
XETA GLX OBD2 Codes Sumit19629 Technical Stuff 0 26th April 2008 18:20
SET2 DIGITAL Rudra Sen Shifting gears 15 6th July 2007 08:59
