Old 9th September 2006, 23:23   #1
bayuin2004's Avatar
i have got the round neon which are usually fitted on the roof to the bottom my zen.will there be any problem and it would be good if u ppl suggest something better
bayuin2004 is offline   Reply With Quote
Old 20th October 2006, 02:45   #2
ankitahuja's Avatar
Thanked: 46 Times
Exclamation Not a good idea!
I think these would not be a good thing to do, you should rather go for under body neons which will be water proof to some extent.
The round neons that you are talking about are only like a replacement for you cabin light which is not meant to be under the car.
I can get you Type R under body neons for a good price.
Old 20th October 2006, 18:53   #3
Thanked: 21 Times
Whats the cost of Type R neons. i had a set of neons but the wires got damaged due to the heat underneath had to take it out. and these were the tubes ones covered with plastic...
nosfreak is offline   Reply With Quote
Old 21st October 2006, 01:19   #4
hellspawn's Avatar
Infractions: 0/1 (10)
is the pic in your avtar with the earlier set of neon tubes or with the round ones.
why dont you take a pic of the car with the neons in the night and then maybe we can judge better.
otherwise its not really advisable since they are not meant to attached to the underbelly of the car.
hellspawn is offline   Reply With Quote
Old 21st October 2006, 13:18   #5
ankitahuja's Avatar
Thanked: 46 Times
They cost between 1200-1500 (not sure of the current price) for a pair of 24" tubes. I guess these are made to withstand a lot of heat as the tubes dont get hot by themself and run very cool without draining the battery even a bit!
Old 23rd October 2006, 09:47   #6
NIP
NIP's Avatar
Thanked: 94 Times
remains to see what happens when water splashes on these...i dont think they are built to install outside...
NIP is offline   Reply With Quote
Old 23rd October 2006, 13:29   #7
blueraven316's Avatar
Thumbs up StreetGlow Neons
Streetglow neons are expensive but worth it, I had hit water logged recidency road near garuda mall and forgot to switch off the neons, they did not even turn off, so came out fine swimming, usually these kits are supposed to turn off till they dry and work again, the kit I have is 2 years old and no damage yet tho I drive fast pretty often.
Instead of spending 4 to 5k on cheap neons every 6 months this looks like the best solution to me,
blueraven316 is offline   Reply With Quote
Old 24th October 2006, 10:20   #8
NIP
NIP's Avatar
Thanked: 94 Times
dude blueraven316, how much did the StreetGlow neons cost you and where did you buy/install them ?! i have also seen StreetGlow gearknobs at Lo, but since they were just opening shop, i could not get prices. Any idea about this !?
Old 24th October 2006, 13:20   #9
Originally Posted by vijjukrishna
the cost of the round one for me just costed only 300 per one...i got 3 at present and i am planning to put two more ....
Mr.krishna garu
u r in confusion round neons r only for interier use because they r not waterproof
underbody neons r waterproof and unbrakable
u have any other doubts plz come pitstop at rajbhavan road in hyd
ph no 9866234562,66666663
thank u
pitstop_hyd is offline   Reply With Quote
Old 24th October 2006, 21:00   #10
Thanked: 21 Times
Originally Posted by pitstop_hyd
Mr.krishna garu
thank u
Hello Mr pitstop...
will be visiting ur shop next month.. got m800 ... maybe u can advise which the best for m800.
Old 1st November 2006, 16:04   #11
Awaiting Email Confirmation
Smile pls suggest
im plannin to go in for the streetglow blueline series for my zen
a) i think that 2 48" tubes and 2 30" tubes that come with the kit wudb too much for the car. shud i go in for running length streetglow neons instead? i dont want to overdo the lights
b) where and at what price can i source this kit plus other streetglow stuff in bombay.
thanks
vidvai is offline   Reply With Quote
Old 1st November 2006, 16:13   #12
Knight Rider's Avatar
Thanked: 11 Times
Hiya,
Can anyone tell me the current rates for under-body neons i bangalore? Cant afford street-glow tho.
Thanks in advance team.
Knight Rider is offline   Reply With Quote
Old 1st November 2006, 19:41   #13
i need ur help
what can the approx cost of street glow under body neons for WAGON R in Delhi.
Where can i get them and are they original or fake.
rEgi is offline   Reply With Quote
Old 1st November 2006, 20:14   #14
There are Pyle Neons avilable for some 6k I think, but you need to look around.
Old 1st November 2006, 20:47   #15
Default @wagonR neons
@rEgi
the streetglow undercar kit is standard for all cars....2 48"tubes nd 2 30" tubes.....they come as gold series, blueline series, etc
Check out: www.streetglow.com
in delhi u cn source 'em at autopsyche, kbagh
alternate way to fix neons on zen mclaren1885 Modifications & Accessories 11 17th August 2007 12:39
mounting a audio system,neons etc in any car TEAM R.A.R Modifications & Accessories 5 13th October 2005 09:46
RPM / NEONS for sale .rs. Shifting gears 5 22nd September 2005 15:55
how long can u keep neons on z klasse Technical Stuff 10 19th January 2005 14:37
Remote control Neons on my car WILDTHING Modifications & Accessories 23 10th January 2005 21:27
