Old 13th September 2006, 20:59   #16
~ H O N D A ~'s Avatar
Thanked: 9 Times
How much would it cost if i want to put spacers and increase the height
Also if you can, lemme know what are the downside of spacers
~ H O N D A ~ is offline   Reply With Quote
Old 13th September 2006, 22:31   #17
redeye's Avatar
i don't recommend spacers i had them in my zen and believe me .. they make the ride jumpy,.. the car shakes a lot on humps , suspensions are important i recommend u to go with koni sports shocks or any other good shocks of good company like HR springs & others .
suggest u buy the original
koni sports suspensions cost u 6500/- per side i mean one piece, so for the whole car would be 26000/-
this is the price in bangalore..
to know more in detail check it in www.methods.co.in
suspensions are a very important part of the car so carefull while choosing
u can also adjust these shocks yourself
redeye is offline   Reply With Quote
Old 13th September 2006, 22:47   #18
redeye's Avatar
body kit looks good how much did it cost and like ur red eyes in ur lamps pls give me details about the head lamp ring.. thanks lot
Old 13th September 2006, 23:14   #19
hellspawn's Avatar
Infractions: 0/1 (10)
hey nice bodykit.the angel eyes look hot.like everybody else said ,you need to go for alloys and better rubber.
hellspawn is offline   Reply With Quote
Old 14th September 2006, 10:42   #20
Thanked: 9 Times
Thanks alot buddy for the help....
Will surely think bout it
Those are the one which my friend bought for me...
I had an extra pair which i sold it....
My friend has an extra pair Brand New complete Box packed if you want it i can hook u up with him... Asking price 2.5K
Old 17th September 2006, 00:20   #21
Thanked: 9 Times
here are some more pics taken by my cellphone camera !!!
Old 6th May 2009, 01:50   #22
Hi Buddy,
Where can I get the kit you've installed on your car? I live in Hyderabad. would love to have something similar done to my honda.
Syed
riderinthestorm is offline   Reply With Quote
Old 15th September 2010, 13:55   #23
Thanked: 9 Times
Default Overhauling My Love OHC - Suggestions Please
I have a OHC 1.3 Exi Type 2 - 2000 Model
Looking for complete overhaulin
new shoes
Denting and painting
stage 1 mods
Guys please suggest some nice garage where i can get the denting and painting done
My Ride as on Today
im thinking of something like this
our should i keep the car in some simple single tone color
Problems facing ---
  1. As the car was kept idle for almost a year now
    (driven only a few times in past 1 year)
    when i took it out for a drive yesterday it was jerking (may be misfiring dont know) = = = what could be the problem ? ?
  2. Suspension i need the car to be hightened a bit so that it wont get draged on every single speed breaker.
    Should i modify the stock suspension or use pedders or koni for the same
  3. A bit of water leakage i guess from the front wind shield (tat can be taken care of during the paintwork)
Guys would really appreciate your suggestions here.
Old 15th September 2010, 14:22   #24
joshguy's Avatar
Thanked: 92 Times
Hi Honda
You got a good simple car,
BTW here are my suggestions
    when i took it out for a drive yesterday it was jerking (may be misfiring dont know) = = = what could be the problem ? ?Problem might be in the ignition coil or injectors so just a general service will do away with that problem
    Pro
    Should i modify the stock suspension or use pedders or koni for the same - New suspension with high end shock (koni/bilstiens) will improve the suspension to an extend
  3. A bit of water leakage i guess from the front wind shield (tat can be taken care of during the paintwork) It should be a problem with AC/Leak via bonnet/leak thru firewall or Thru rubber beading so tinker can take care of this problem
My suggestion is please keep the car as simple (OE) as possible,but if you want is to be spruced up then go for single colour with good stickering
All the best for the restoration
joshguy is offline   Reply With Quote
Old 15th September 2010, 14:37   #25
Thanked: 9 Times
thanks for your suggestions joshguy
the water leakage is only in monsoon season and can see almost a pool of water even after car kept idle for almost a week so my guess its from somewhere around the windshield.
correct me if im wrong
Old 15th September 2010, 18:33   #26
Unknownsatan's Avatar
Thanked: 1,486 Times
If you are going for paint change, then try for white. It is simple and yet look good with good shoes and skirts. Remember there are not many white OHCs. For me, the skirt you are having is a bit over the top, try something like vinayvtec's one. It looks really good.
Unknownsatan is offline   Reply With Quote
Old 15th September 2010, 19:11   #27
yzfrj's Avatar
Thanked: 119 Times
Originally Posted by ~ H O N D A ~ View Post
1. (driven only a few times in past 1 year)
dirty fuel line, clogged air filter, conked off plugs just to name a few.
A proper service should do the trick.
Change oil, change plugs, clean fuel tank, replace air/fuel/oil filter, check/adjust timing, check the brakes.
Also flushing the radiator is also highly recommended.
Suspension i need the car to be hightened a bit so that it wont get draged on every single speed breaker.Should i modify the stock suspension or use pedders or koni for the same
The only "bolt on" kit is from Hotbits (fully adjustable coil-overs)
That will set you back some serious $
However I'm not sure if this will increase the height.
Anyway this is not really recommended with the stock suspension and its already soft and increasing the height will "kill" whatever handling is left.
Clogged A/C evaporator ?
There is no easy way to find this.
Is there rust near the A pillar ? How is the rubber that is on the windscreen ?
+1
I'll advice to keep it simple and clean.
Suggestions
Body :
A metallic white shade (like in the swift)
Nothing too blingy. White with Vtec spoiler, 16" rims 195/205 low profile rubber and a subtle body kit.
Performance mods :
Synthetic Engine Oil
Stock replacement filter
Iridium Plugs (not really sure how good they are)
A decent FFE (custom made preferable, no automech please)
Replacement (read : performance) brake pads
A better Clutch (Stage 1) - Not really required, but never hurts to get a better clutch.
yzfrj is offline   Reply With Quote
Old 15th September 2010, 21:08   #28
avishar's Avatar
Thanked: 977 Times
Like everyone has said i too would love it if you would paint your colour white,and try to get that Vtec spoiler.It looks perfect with the OHC.
A nice set of 5 spoke alloys(powder coated),new tyres and it will look awesome.
Mods same as yzfrj mentioned.
1.A good free flow exhaust with a cold air intake,headers and exhaust system would be enough.
2.Uprated brakes,stiffened suspension.
Perfomance coils with iridium spark plugs does not really bring about much notieciable change to a stock car,except they last a longer time than ordinary plug.
Performance clutch also can be installed but only if you are really going to do some serious mods.
avishar is offline   Reply With Quote
Old 15th September 2010, 21:16   #29
Thanked: 9 Times
@Unknownsatan: thanks alot buddy... white is one of the few colors already on my mind
@yzfrj: I've changed engine oil after flushing it with ABRO Flush. i dont think i must have even driven 500 kms after oil change. the car had been sitting idle for quite a long time with ocassional 10-15 kms once a month i guess. most of the time i travel in my safari as the tyre oh my OHC are worn out and a bump has come out of the tyre so didnt take it out much fearing it might turn into a punctured tire in the middle of the road.
didnt change the tyres earlier as im still thinking about what color should i go for so that accordingly i'll choose the alloys.
im thinking of 15 or maybe 16 inchers with 195/40 either Potenza or Yokohamas
visited Saifee yesterday liked 2 designs i clicked image of one of the design
guys what do u think
Old 15th September 2010, 21:20   #30
Thanked: 9 Times
@avishkar: thanks for your suggestions
lately i have noted that the power or the punch which i used to get earlier is missing.
It feels like the engine is trying hard to get the pickup. i dont know what could be the problem.
Modified Honda City TORQUED Modifications & Accessories 27 15th December 2010 20:42
My Modified - Wide Body Honda City 1.5 vtec ollie Modifications & Accessories 61 7th July 2008 01:43
My Car Honda City Vtec Modified ollie Modifications & Accessories 83 18th June 2006 09:50
