Old 14th September 2006, 22:04   #16
Thanked: 294 Times
Originally Posted by iraghava
Not necessarily Abhimanyu. You can run the Components off the HU too but you won't be using them to their full potential because of the meagre output the HU's give out compared to a dedicated amp. So the comps will simply not get enough juice. If you are getting good comps then it is advisable to spend money on a decent amp to amplify them.
another budget increasing point....
for getting max from the componets get a amp for it......
Old 15th September 2006, 00:01   #17
gr8guzzler's Avatar
Thanked: 38 Times
gr8...i'm for it, let me know the amp i should go for with the right component system.
Cheers!!!
gr8guzzler is offline   Reply With Quote
Old 15th September 2006, 00:53   #18
iraghava's Avatar
Thanked: 156 Times
Cheers!!!
Brother sincerely speaking, fix a budget before asking for such advice! Give us a ballpark figure to play around with since we'll surely exceed it anyways!!!
I would suggest a budget of about 13-15k if you need only front & rear speakers & amplifier for them. If you also need a subwoofer then the budget should be around 23-25k.
Old 15th September 2006, 01:05   #19
Thanked: 11 Times
Cheers!!!
First Tell Budget..
Then Wait For Suggestions...
And Dont Forget To Have A Look At This Post.
Cheers,
Mugen_Power.
Mugen_Power is offline   Reply With Quote
Old 15th September 2006, 01:07   #20
hellspawn's Avatar
Infractions: 0/1 (10)
but without the amp the sound will be louder and clearer than the regular 4"-5" speakers that you get for the front doors,right?
@gr8guzzler:the cheapest amp that you can get is the sony 222.it will cost close to 2500bucks.
as soon as the audio gurus invade this thread,whatever budget you keep aside will turn out to be a very small amount
hellspawn is offline   Reply With Quote
Old 15th September 2006, 15:48   #21
aZa
aZa's Avatar
Thanked: 17 Times
helli dont tell me u planning to switch the front speakers to comps as even i'm planning to do that lol !!! lets not go to raunaq for this ya i told him that i wanted comps hez like "arrey usse bhi achi cheez hai ki aap 4" speakers + Ts20 fit karlo" .............................
Old 15th September 2006, 20:47   #22
go in for gto507 jbl 5 1/4" components connect it through HU will improve the sound & solve ur problem for which u enquired, think abt th upgrade after that
autoshop is offline   Reply With Quote
Old 20th September 2006, 04:09   #23
gr8guzzler's Avatar
Thanked: 38 Times
Thanks guys...I'll try the JBL components and later add a Amp if needed.
Old 26th February 2007, 19:10   #24
Thanked: 294 Times
hello sir any upgrade done or still running through the HU.......
Old 27th February 2007, 03:19   #25
gr8guzzler's Avatar
Thanked: 38 Times
Nahi yaar, haven't even upgraded the front speakers yet. Of late have not been using the car a lot and hence the lack of enthu to get it done. I'll surely give you a call before I upgrade.
Cheers!!!
Old 27th February 2007, 09:08   #26
moralfibre's Avatar
Thanked: 6,532 Times
Someone told me that the stock size in the front of the Ikon is only 4 inches. Can you confirm.
Old 27th February 2007, 11:37   #27
rchimni's Avatar
That's correct it is four inches for the front .. though am given to beleive it is possible to fit five inches components as well..
rchimni is offline   Reply With Quote
Old 27th February 2007, 12:13   #28
esteem_lover's Avatar
Thanked: 451 Times
Not sure if there is a 4" component system (I gave up my chase). Try to see if you can fit a 5 1/4" speakers in your front door. That is the best possible way to get decent sound from the front.
Old 27th February 2007, 12:42   #29
prince85's Avatar
Thanked: 117 Times
Originally Posted by esteem_lover View Post
Not sure if there is a 4" component system (I gave up my chase). .
Well, i use Kicker 4" Component system (Ex 4.2) which cost me 5k in my Esteem for sometime now. There are other brands like MTX and Blaupunkt which also have components in this size.
prince85 is offline   Reply With Quote
Old 27th February 2007, 13:13   #30
vezj420's Avatar
Thanked: 17 Times
4" components, eh? hmmm....But if u're spending that much anyway, you might as well get 5.25" comps fitted.
That's what I have in my Ikon - JBL 5.25 comps in front. Got em for 5.5k in BLR. And no, u don't have to radically change the housing to fit them.
vezj420 is offline   Reply With Quote
front speakers required filcord Shifting gears 8 3rd December 2007 09:56
Basic Audio Solution - only Front Speakers? samueldotj In-Car Entertainment 1 15th November 2007 12:22
For HT front speakers - 2 way or 3 way ?? w 12 Gadgets, Computers & Software 3 4th September 2006 22:07
protecting the front speakers??? amit_sound In-Car Entertainment 9 26th April 2006 23:11
Suggestion for front speakers for my Sumo nitrous In-Car Entertainment 23 1st February 2006 02:10
