Old 19th May 2006, 14:59   #211
Psycho's Avatar
Thanked: 95 Times
Originally Posted by Edmund
What are the preventive measures then? Should i go in for SS or MS??
SS Headers are the best provided you have them TIG or MIG welded as they provide the best flow, in the absense of that you can use MS. As for heating up both the headers heat up equivalently depending on the wall thickness, but the SS headers will tend to radiate more heat.
I agree with you khaadu, my previous FF setup [Now running stock exhaust setup!] was designed primarily for sound, even though i specificallly told him that i wanted performance!!! I stood around in the workshop and observed 40% of my setup being made, there was absolutely no calculations, just chop-bend-weld!!!! Since he was recommended and i had already given him the dough there was no turning back!! That setup is now history and i hope my new one is nothing but performance oriented.
Welcome to the world of header design , I do know most of the run of the mill header makers tend to design the headers to fit the area available rather than maintaining the right lengths.
Old 19th May 2006, 15:05   #212
Thanked: 97 Times
@ Psycho: Thanks for the info, So if the SS headers radiate more heat does it affect anything???
Edmund is offline   Reply With Quote
Old 19th May 2006, 16:46   #213
shazikon's Avatar
Thanked: 19 Times
Actually SS headers should not dissipate heat as SS is not a good conductor of heat.. but MS is a good conductor. Using MS headers, heat at the headers are dissipated to the surroundings inside the engine bay. but with a SS header, heat generated propogates along the tube this also aids exhaust gasses propogation along the tube there by maintaining exhaust gas velocity.. On the contrary this may heat up the entire length of the exhaust track. with headers welded properly with TIG process should give better performance than a same spec header fabricated with MS.
shazikon is offline   Reply With Quote
Old 19th May 2006, 16:50   #214
shazikon's Avatar
Thanked: 19 Times
while researching the web on headers, i came across this bful website dedicated to header design.. It even has header calculation embedded.
You can calculate your header dimensions with this tool:
http://headerdesign.com/index.asp
Old 19th May 2006, 17:55   #215
Psycho's Avatar
Thanked: 95 Times
Good one for basics... try changing parameters you will only notice the pipe dia's changing not much changes on the lengths
Old 1st July 2006, 13:46   #216
rareone's Avatar
Thanked: 11 Times
Question Free Flow Exhaust Maintenance
Hi TBHPian's
Almost 6 - 8 months back i have installed a Free Flow Exhaust from Automech (Mumbai). But since few days i m getting a feeling that the air which passes thru the exhaust is taking pressure 2 come out (not like free flow). Sometimes i feel the pressure tht the air puts 2 come out.
Is it somethiing which i m just thinking and feeling or there is some problem.
Also let me if there is some kind of maintenance to be done on the Free Flow Exhaust 2 make it run smothly.
Thanx
rareone is offline   Reply With Quote
Old 4th July 2006, 12:16   #217
rareone's Avatar
Thanked: 11 Times
It feels like the air flow is getting choked somewhere???
Old 4th July 2006, 14:29   #218
jkdas's Avatar
Thanked: 1,436 Times
There was a thread by another TBHPian who drives an Esteem ( run some 500odd kms) with freeflwo and rest of teh works. he too faced simialr problems and was rectified by a faulty muffler.
Old 4th July 2006, 20:11   #219
Mpower's Avatar
Thanked: 1,687 Times
Default OD tests Automech
Cant remember which month the long term review appeared, but OD has a green Swift on a long term test and installed an Automech exhuast on it.
They claim 0-100 has improved to ~11.3 secs. When you flip to the performance index on the last page, it shows stock Swift as 12.9 secs......that a real good improvement if you ask me.
But they dont mention if its cat back or header to tailpipe system.
Old 5th July 2006, 12:22   #220
rareone's Avatar
Thanked: 11 Times
So JKdas shall i go 2 automech once and get the muffler and free flow checked once.
Old 6th July 2006, 15:32   #221
jkdas's Avatar
@rareone; update please.
can I get just a header for my Xing + OE exhaust?
Old 7th July 2006, 18:40   #222
rareone's Avatar
Thanked: 11 Times
I think u can..
Have read somewhere on this site abt header with OE exhaust
Old 7th July 2006, 18:47   #223
viper's Avatar
Thanked: 9 Times
I think u can..
You can use a Header with OE rear muffler but, you will not experience the full gains one finds from a complete Free Flow system.
Viper
viper is offline   Reply With Quote
Old 11th July 2006, 22:41   #224
~ H O N D A ~'s Avatar
Thanked: 9 Times
Question
guys for the time being im not getting the mods done on my OHC i'll start the work within 2-3 months....
i wanned my ride with a nice deep sound
my question to guys is that is that possible by just changing the Muffler or do i have to install the complete free flow exhaust...
help me out guys....
~ H O N D A ~ is offline   Reply With Quote
Old 12th July 2006, 08:31   #225
viper's Avatar
Thanked: 9 Times
If its only sound you are looking at then the answer is yes only a muffler change will do.
Viper
Exhausts - Automech Engineers (Parel, Mumbai) GTO Mumbai 30 23rd March 2018 12:29
Automech exhausts SYJ Modifications & Accessories 1 13th November 2007 11:14
More Smile With Full Free Flow From Automech finetuning Modifications & Accessories 5 6th April 2006 20:55
Automech ?? khaadu75 Modifications & Accessories 2 11th June 2004 00:23
