Old 26th October 2008, 15:57   #361
anantnehru's Avatar
Question
Ok, so after going through a few threads on Free Flow Exhausts and K&N Air Filters, I have understood the following - please correct if I am wrong. I am also including in this a few questions, which hopefully someone will answer, since I'm completely alien to the performance aspect of a car.
1. FFEs change your entire exhaust system, and add to your performance. They can also help you FE but in most cases doesnt because gun the engine to hear the sound.
2. K&N Air Filters alongwith FFEs are the best combination for a performance upgrade. From what I remember a long time ago, there are a few types of K&Ns; which is best choice and for how much?
Also, do you need a Cold Air Intake with a K&N? Or is that another addon?
3. End cans improve the sound of the engine making it deeper but do not have FE or performance value adds as such. Any particular brand and what price range? (For an Sx4)
4. Installation of your FFE will rid the engine of the catalytic convertor. Not too good for the environment, I have read someone's post in this thread who has a catback system. What is the further cost involved for a set up like this?
5. Headers. Not sure if they're related to the FFE, but read that they also can add to performance(??). Whats the benefit of these and again, costs involved?
Oh and I dontknow if this was the proper thread for the above, but it was the most active out of all the FFE threads.
anantnehru is offline   Reply With Quote
Old 26th October 2008, 17:13   #362
Strangerintown's Avatar
Thanked: 85 Times
Have never run a FFE on my cars but have tried to answer what little I know based on my understanding, appended in bold below.
Originally Posted by anantnehru View Post
1. FFEs change your entire exhaust system, and add to your performance. They can also help you FE but in most cases doesnt because gun the engine to hear the sound. Absolutely right
2. K&N Air Filters alongwith FFEs are the best combination for a performance upgrade. From what I remember a long time ago, there are a few types of K&Ns; which is best choice and for how much? K&Ns and FFEs are the easiest and most painfree way of getting additional performance in most cases. The best mods will depend on your budget and how much you want to risk tampering with the engine.
Also, do you need a Cold Air Intake with a K&N? Or is that another addon? A CAI is good to have but not a necessity.
3. End cans improve the sound of the engine making it deeper but do not have FE or performance value adds as such. Any particular brand and what price range? (For an Sx4) End cans are only for sound and appearance. Not sure about brands. I know Automech makes end cans too - not sure about availability for SX4.
Strangerintown is offline   Reply With Quote
Old 27th October 2008, 16:06   #363
Thanked: 103,414 Times
Only a conical filter requires a well-designed CAI system. The stock replacement filter doesn't as it will use your existing routing.
A catback simply means "everything behind the catalytic converter". It will be cheaper than a full free flow exhaust that includes new headers.
Effective header design is most crucial to a performance enhancing custom exhaust.
Old 27th October 2008, 20:17   #364
anantnehru's Avatar
Cool thanks!
But what are the different types of filters available? I've pretty much only seen conical filters.
So a catback is the same as a FFE? As in, ok you retain you convertor but is there any difference - performance wise?
Header most crucial, ok, but necessary?
Also, thanks strangerintown!
Old 30th October 2008, 16:22   #365
ankitahuja's Avatar
Thanked: 46 Times
Can someone give a detailed explanation on what exactly is the role of the Mid Muffler AND Expansion Chamber in an FFE set up.
Is one of them used in place of the other or how does it work?
Old 6th November 2008, 15:47   #366
naveen.kk's Avatar
Thanked: 29 Times
Sorry for a question over the another one. I have Palio 1.6 with Custom FFE. I use its most in city, than on highways. I feel low end is ok, and mid range is fine, and high end is best, and grunt is too loud. I am looking to change it a little to get gains on low end, and make it sound quiet at low rpms atleast.
Can any one suggest me anything?
I was adviced to replace the end can for reducing the grunt. But, what will help in gaining more low end?
Thanks in advance.
naveen.kk is offline   Reply With Quote
Old 6th November 2008, 19:29   #367
nc1bad's Avatar
Thanked: 15 Times
Default automech honda
Hi, been following this thread for quite some time,i have installed automech exhaust in my OHC 1.5 , the note etc is satifactory,but the build quality is bad. I have attached couple of pics showing total break-off of the silencer can and the pipe. Its been fixed now but i still have some rattling sound at a specific rpm.
nc1bad is offline   Reply With Quote
Old 6th November 2008, 19:38   #368
vikram_d's Avatar
Thanked: 940 Times
Wow that is bad. Rattling sound at a specific RPM generally indicate a problem with the rubber mounts that hold the exhaust system. Have all the rubber mounts checked.
Old 7th November 2008, 03:32   #369
anantnehru's Avatar
Default Would this suit the Sx4?
Ok, so since there havent been too many replies I started looking out for performance exhausts. I came across one, but its specs are all greek to me. So if anyone could tell me whether this would suit the Sx4 or not, I would be extremely grateful! Also, if it doesnt suit the Sx4 what specs should I look out for and if Im being painful, again - please feel free to let me know
(Or can you just plonk on any exhaust onto any car without any issues?)
Muffler, Super Turbo, 2 1/2 in. Inlet/2 1/2 in. Outlet, Steel, Aluminized, Each
Case Length (in) 14.000 in.
Case Shape Oval
Inlet Diameter (in) 2.500 in.
Inlet Location Offset
Inlet Quantity Single
Internal Construction Turbo-style
Muffler Finish Aluminized
Muffler Material Steel
Notes Inlet and exit are out the same side.
Outlet Diameter (in) 2.500 in.
Outlet Location Offset
Outlet Quantity Single
Outlet Style Standard, without tip
Overall Length (in) 15.500 in.
Thickness (in) 4.250 in.
Width (in) 9.750 in.
Old 7th November 2008, 16:53   #370
ankitahuja's Avatar
Thanked: 46 Times
@Anant - What you are talking about is only the exhaust / end can / muffler and not a complete Free Flow Exhaust system (which includes headers, mid muffler, mid pipes and then the end muffler).
Generally, the end cans are universal and can be fitted to any car, but choosing the right design (correct inlet diameter and outlet etc) can sometimes be useful. Changing only the muffler would not make any difference unless your OE muffler is 'highly restrictive', else it will be only change in sound to a sporty one.
In simple terms - A FFE looks exactly the same as a stock exhaust system, only difference is in the diameter of the pipes used and tweaks in the header design (molds of the pipes) and sometimes the material of the piping.
See pictures:
END CAN Only:
Free Flow Exhaust System:
Headers
With Cat Con bypass
Complete with end can (this is the stock exhaust system)
Name:  FFE system.JPG
Old 7th November 2008, 18:30   #371
anantnehru's Avatar
Ooohk..Thank for the heads up.
So the one I've mentioned would basically suit any car? So I dont have to keep in mind certain specifications right?
Old 7th November 2008, 19:23   #372
ankitahuja's Avatar
Thanked: 46 Times
That's not entirely true. The muffler you choose should have the same or at least 0.5" bigger inlet pipe than your existing mid pipes. Check that the muffler is not restrictive (see if you can see straight through the muffler to the other end).
Sound will depend on the overall diameter/length and amount of glass-wool used to make a muffler.
The specs you've mentioned state 2.5" inlet and outlet. For it to look good, you might want one with at least a 3" outlet/tip for those good looks?
"Notes Inlet and exit are out the same side" - This surely has left me confused! Post pics / link if you can.
Also, see this thread - http://www.team-bhp.com/forum/collec...w-exhaust.html
Old 9th November 2008, 11:33   #373
nc1bad's Avatar
Thanked: 15 Times
thanks shall get it checked
Old 15th November 2008, 05:44   #374
abhik's Avatar
A Mid-Muffler is mainly installed to modulate sound. It consists of meshes and fins through which sound reflects and produces a note which is desired by the muffler designer. One can regulate the pitch of the exhaust note i.e sharpness and bass and also its loudness. No/little dampening takes place here. The main dampening of sound is done by the end-can which consists of glass wool etc to dampen sound.
The mid-muffler does however contribute to exhaust restriction.
An Expansion Chamber, ideally meant for 2 stroke engines, is meant to increase performance. In simple terms, it works by accumulating exhaust gasses in the enlarged section of the chamber and pushing it out with force with the gasses from the next cycle.
The first pic shows Expansion Chambers and the next shows a Mid-Muffler.
abhik is offline   Reply With Quote
Old 16th November 2008, 15:20   #375
anantnehru's Avatar
Case Shape Oval
Well here are the same specs with a picture of the end can.
Exhausts - Automech Engineers (Parel, Mumbai) GTO Mumbai 30 23rd March 2018 12:29
Automech exhausts SYJ Modifications & Accessories 1 13th November 2007 11:14
More Smile With Full Free Flow From Automech finetuning Modifications & Accessories 5 6th April 2006 20:55
Automech ?? khaadu75 Modifications & Accessories 2 11th June 2004 00:23
