Old 1st December 2015, 19:53   #1
PatchyBoy's Avatar
Thanked: 1,195 Times
Default Review: A8 Head-Up Display
The product
It is simply called A8 HUD. No brand name. It connects to the OBD port and does not need any extra power source. When I found that this was available for $ 37.99 with free shipping, I bit the bullet and ordered it.
Features
Displays various things like
  • Speed
  • RPM
  • Coolant temperature
  • Trip distance
  • Fuel consumption
Pretty much plug and play. When it was delivered today, all I did was open the box and plug it in. I am yet to tweak any settings.
What is in the box?
Clockwise from top left -
  1. Non-Slip mat & reflective sticker
  2. Product box
  3. User Manual
  4. HUD unit
  5. OBD Cable
There is a protective film on the device which needs to be removed to reduce unwanted reflections. After removal, the device has a nice matt finish.
Initial impressions
Pros -
Looks cool
LED is bright and produces vivid colours
Nice useful and thoughtful features like -
  • When car is cranked and the device powers up, it displays battery voltage.
  • It then switches to trip distance
  • When car is stationary, fuel display show L/Hour
  • Once car reaches 5 kmph, displays L/100 kms
  • Ambient light sensor automatically adjusts display brightness
  • Once the car crosses 80 kmph, only speed & fuel are displayed. Less distraction
  • Has a shift reminder. Not sure if it is solely RPM based or takes engine speed, vehicle speed and load in consideration
  • Turns on & off automatically with the car
Cons -
  • Since it is connected to OBD, I expected faster refresh
  • Slight distraction, possibly because today was the first time I used it
  • Double reflection on the windshield. Not really a product con though. I haven't installed the supplied reflective film yet
  • Trip distance gets reset each time the car is turned off. Also given that there is only provision for 2 digits and one decimal place, I am assuming it will get reset to 00.0 after 99.9 kms, rendering it useless for highway runs. I feel that the water temperature / voltage displays would be far more useful. Sadly, can display only one of these three values at a time.
Here is a short video I shot with my dashcam
Will post long term observations with more usage. While it is not a must have accessory, it does add to the cool quotient of the car
PS: Pictures are off the internet. Credits to respective owners.
Last edited by GTO : 15th January 2016 at 14:48. Reason: Absolutely NO gearbest promotions on Team-BHP
PatchyBoy is offline   (25) Thanks Reply With Quote
Old 1st December 2015, 20:08   #2
AbhiJ's Avatar
Thanked: 465 Times
Default re: Review: A8 Head-Up Display
Nice ...
How did you manage to the get the OBD cable from the display to the OBD port?
Is it visible or concealed?
AbhiJ is offline   (2) Thanks Reply With Quote
Old 1st December 2015, 20:12   #3
PatchyBoy's Avatar
Originally Posted by AbhiJ View Post
Nice ...
At the moment, it just runs across the dash. A proper install and cable routing has to be done. But still some of the cable will be visible. It cannot be completely concealed, unless I drill a hole in the dash.
PatchyBoy is offline   (2) Thanks Reply With Quote
Old 2nd December 2015, 09:39   #4
batterylow's Avatar
Thanked: 677 Times
Originally Posted by PatchyBoy View Post
The product
It is simply called A8 HUD. ...... Credits to respective owners.
Nice!
If only they could connect the device over Blue-tooth, the wiring hassle can be done away with.
I think it will look brilliant at night, ain't it?
I think the OBD connection must be disconnected everytime the car is parked as it will keep draining power otherwise.
batterylow is offline   (2) Thanks Reply With Quote
Old 2nd December 2015, 10:01   #5
PatchyBoy's Avatar
Originally Posted by batterylow View Post
Nice!
That would mean a battery power source for the device which would need recharging. This way, it just draws power from the OBD port
Yes. It does look cool in the night. But the display does dim a bit in the night to make it less distracting.
No. When the car is turned off, the device also turns off after a few seconds. Watch the end of the video that I have posted. As per the manufacturer, there will be no battery drain.
Old 2nd December 2015, 11:53   #6
aswin ajith's Avatar
Thanked: 69 Times
The product
It is simply called A8 HUD....
Nice addition there. Wanted to buy one of these for sometime now. Only thing holding me back is I don't have a credit card
Will it hold up against the heat generated due to sun light ? Asking since it can be quite a lot especially during noon.
aswin ajith is offline   Reply With Quote
Old 2nd December 2015, 12:11   #7
PatchyBoy's Avatar
I don't have a credit card either. I paid via paypal, which is linked to my savings account.
Good point. It might be a good idea to disconnect the device and store it in the glove compartment, when parking in the hot sun.
PatchyBoy is offline   Reply With Quote
Old 3rd December 2015, 17:32   #8
nijelj's Avatar
Thanked: 368 Times
Default Re: Review: A8 Head-Up Display
The Android market has a free app called 'Torque'. This uses the OBD bluetooth to display information on your phone. In the settings, there is an option called 'Toggle HUD view'. This would invert the fonts and the gauge displays, so you could use your phone to act like the A8 heads-up display.
If you have a old or cheap android phone, download the free app, buy a Bluetooth OBD connector and you are golden
nijelj is offline   (6) Thanks Reply With Quote
Old 3rd December 2015, 23:22   #9
PatchyBoy's Avatar
Tried that a couple of years back. Works. Not golden though
PatchyBoy is offline   (3) Thanks Reply With Quote
Old 3rd December 2015, 23:47   #10
nijelj's Avatar
Thanked: 368 Times
What was the draw back with this method, that you found then?
nijelj is offline   Reply With Quote
Old 4th December 2015, 00:15   #11
akshay4587's Avatar
Thanked: 1,629 Times
Display gets totally washed out in light.
And even in darkness, its not that effective.
And you don't get an Android phone for $40?; Do you?
Old 4th December 2015, 06:22   #12
nijelj's Avatar
Thanked: 368 Times
The display for torque can be adjusted to look just like a digital display like that of the A8 (black background with white digits). This will take care of the visibility issues in Day or Night conditions.
A new sansui android phone comes for rs2100 or approx 32$.
To make the phone+obd bluetooth dongle system equivalent to the A8, we'd need a phone+ELM bluetooth OBD+phone charger. This would make the price around 2100+1000+100= rs 3200. Approx 48$.
Yes, there is a difference of 16$ or rs1070. But that looks more expensive only if you want the just the information that can be shown by the A8. The possibilities of customization within torque + having navigation capabilities of a phone overcomes the price differential, for me atleast.
Old 4th December 2015, 10:06   #13
batterylow's Avatar
Thanked: 677 Times
The Android market has a free app called 'Torque'. ....
I have tried Torque previously but I have not tried this feature yet.
I too am sceptical of the ability of the display to overcome the ambient light. Nonetheless, I shall give it a demo run today and get back with the results.
batterylow is offline   Reply With Quote
Old 4th December 2015, 11:43   #14
yogeshnagpal's Avatar
Thanked: 81 Times
Any advantages of this over the ELM327 Bluetooth interface OBD-II devices?
You can easily connect an ELM327 device using Bluetooth to a 7 inch tab mounted on a holder and get diagnostic metrics.
You can get basic tabs for around 2-3k and an ELM327 device costs 600/- max and Torque Pro app is bundled with the ELM device.
Any specific reason for not using the above setup?
I may have missed something specific to your device, hence asking.
Cheers,
Yogesh.
yogeshnagpal is offline   Reply With Quote
Old 4th December 2015, 12:06   #15
Mafioso's Avatar
Thanked: 97 Times
It's a cool setup! But just wondering the use of this for a common man as it only shows the statistics of a car. It would have been really helpful if this is integrated with bluetooth and can display maps with directions - like the Jaguar cars Are there any such devices available? It must be a similar technology which receives data and projects it ( I know it may not be as simple as that!) Just checking
Mafioso is offline   Reply With Quote
Aftermarket Head-Up Display (HUD Add-ons & Mobile Apps) sukhoi30 Modifications & Accessories 49 19th January 2018 09:44
Skully's Android-powered Helmet with HUD. EDIT: Skully shuts down! Warwithwheels Motorbikes 32 28th July 2016 22:55
Garmin launches Head-Up Display for Rs. 15,000 GTO Modifications & Accessories 8 24th March 2016 07:50
