Old 16th September 2006, 19:42   #1
I own a palio 1.2 petrol which i purchased 4 yrs back, is it possible for me to replace the engine with a diesel engine? would it improve the FE, what would it cost on an average?
pc_001 is offline   Reply With Quote
Old 16th September 2006, 20:11   #2
jkdas's Avatar
Thanked: 1,436 Times
? wont be worth I guess! Why not sell it and get a second hand Palio D ?
well, why not a CNG?LPG kit?
Old 17th September 2006, 04:05   #3
hellspawn's Avatar
Infractions: 0/1 (10)
its better to sell off the current palio as the engine swap will cost you a lot as you will even have to stiffen your suspension,probably purchase the one which is available with the paio 1.9D,.change the transmission. etc.on top of it,there will always be some technical issues as the work carried out may not be satisfactory.
if selling the car is not an option,then you can fit a lpg or cng kit.it will work out cheaper than diesel and the kit will also cost less than the engine swap.
hellspawn is offline   Reply With Quote
Old 17th September 2006, 09:10   #4
moralfibre's Avatar
Thanked: 6,532 Times
As everyone suggested... go for a used Palio D rather than going for a swap. It involves a hell lot of changes and its better to go for a car swap to avoid the hassles.
Old 17th September 2006, 11:25   #5
Thanked: 17 Times
Let me tell you something;
Sell your petrol Palio. Get yourself a nice Palio D. If you go for a conversion, it'll cause more trouble than any help. I had converted a Maruti 1000 to diesel and sold it for nothing. It was running like a tractor more than a car. Maybe the job wasn't right, but it was what it was!
Old 18th September 2006, 20:51   #6
thanks guys , u have been really helpful, i have decided to sell off my palio, and go for a tata indica, hows the tata indica xeta diesel?
Old 18th September 2006, 21:02   #7
jkdas's Avatar
thers no Xeta diesel
Old 18th September 2006, 21:16   #8
are there any other options in diesel, my budget is 5 to 5.5 lakhs
Old 18th September 2006, 22:27   #9
wolfinstein's Avatar
There is only TATA Turbo Diesel or Regular model. XETA are the Petrol and CNG varient, The replacement to the Lsi series.
You could look at Fiesta D, Accent CRDI,Lancer D, for a little bit more on the price range. and Lastly you could also consider the New Safari ( Not Dicor) the revamped one its about a Lakh more than your range, But its an SUV...!
wolfinstein is offline   Reply With Quote
Old 18th September 2006, 23:29   #10
jkdas's Avatar
wolf; he has a budget
and there are 3 versions of Indica.
Old 19th September 2006, 04:27   #11
hellspawn's Avatar
my opinion would be to go for the indiaca cng.it will give u a good efficiency and will save you the hassles of owning a diesel car(indica diesel can be unpredictable)
Old 19th September 2006, 07:12   #12
are there any downsides to cng? are there equal cng outlets as petrol ones? ive just moved back to mumbai, hence the question
Old 19th September 2006, 08:42   #13
hellspawn's Avatar
in delhi you do have a couple of cng outlets.dont know about mumbai though.apart from using up the boot space i dont see any other downsides.
Old 12th November 2006, 17:32   #14
jalsa777's Avatar
Thanked: 1,065 Times
hey guys....even i have a palio 1.2 about 4 years old....
i want more performance from it.....is is possible to fit in an engine with larger diplacement.....if yes...whch one???
jalsa777 is offline   Reply With Quote
Old 12th November 2006, 19:31   #15
viper's Avatar
Thanked: 9 Times
The best option for you would be to swap with a 1.6 Palio engine though it would be abit expensive to procure. Also please remember to open the engine at a competant mechanic and have the health checked else overhaul before installation.
There are other ways by which you can increase the power of your existing engine as well like adding the following
1> Free Flow with Headers
2> K&N/Ractive Conical Filter
3> Iridium Plugs
4> Porting/Polishing
5> Throttle Body Enlargement
The above 5 mods should get you a gain of approx 15-20% easily.
Viper
viper is offline   Reply With Quote
Fiat Palio 1.2- Rusted Exhaust replacement: Stock/ FFE?(Cochin) aravindwarrier Technical Stuff 11 28th April 2014 19:05
Palio 1.2-Clutch MC replacement = Dashboard removal? clevermax Technical Stuff 3 16th November 2009 10:41
Problem with replacement FIAT Palio body panels Rahulkool Technical Stuff 6 11th November 2008 11:21
Replacement for Palio psp62in Hatchbacks 50 11th December 2007 12:52
