Old 23rd April 2009, 16:34   #121
freakrz's Avatar
Thanked: 50 Times
Originally Posted by adi99 View Post
For Swift petrol, its K&N Extreme. It will cost you 5.5K for the filter and another 3K for the pipe, clamp, labor etc.
Thank you for the info....!
can someone provide me a contact or a place in chennai where i can get it...?
freakrz is offline   Reply With Quote
Old 29th April 2009, 19:48   #122
from where can i get stock replacement for my baleno? please give the approximate price also....
premdiv is offline   Reply With Quote
Old 29th April 2009, 21:58   #123
Surprise's Avatar
Thanked: 272 Times
Why do u want to spend Rs.8.5k for the filter when U have RACTIVE conical filter and may be a customized pipe at just half of the cost with a equal performance if not higher
Contact pjspeed for filter and viper for customized pipe
Surprise is offline   Reply With Quote
Old 21st June 2009, 18:49   #124
Folks, Planning for Piper cross filter set for Indica Xeta, this costs 3500/- and is available at prabhadevi shop. Any indica users can concur the boost in performance and efficiency?
silverwheel is offline   Reply With Quote
Old 2nd July 2009, 11:30   #125
Hey Guys, please help me in choosing air filter for my swift.
I am confused about the kind of filter to choose in extreme range, whether to go for K&N or Pipercross or greencotton.
Also heard there is apollo filter from k&n, how different is it from extreme?
Have fitted my swift with a FFE (4 x 2 x 1), so would like to know which filter suits best for this.
I havent got time to do much of a research on this, so taking help from you guys.
_abhishek is offline   Reply With Quote
Old 12th July 2009, 19:35   #126
sabsubs's Avatar
Thanked: 40 Times
Has anybody used K&N filters on their i10. I am planning to upgrade my i10's air filter to K&N. Could somebody who has already done it for i10 tell me whether it is really worth it?
sabsubs is offline   Reply With Quote
Old 9th December 2009, 19:14   #127
sterlingjames's Avatar
Thanked: 36 Times
Default fuel consumption more after installation of K&N fliter on Swift Vdi
ever since i installed the K&N filter there has been quite a drop in fuel avearge and the car now consumes more fuel than before. initially i thought that it is because of the extra power surge when one tends to rev more often.
but after almost a month of sedate driving, the fuel averages are not improving at all. i switched to the OE filters and the fuel average improved dramatically although the car seems to struggle for breath. has anyone else had this problem, i wonder?
sterlingjames is offline   Reply With Quote
Old 9th December 2009, 19:36   #128
Thanked: 66 Times
what type of filter have you used? stock replacement or K&N apollo ?
streetracer_919 is offline   Reply With Quote
Old 9th December 2009, 20:00   #129
harishnayak's Avatar
Thanked: 118 Times
Have you installed the original K&N , i mean did you get it installed from a known person/acquaintance?
What is the dip in the mileage 1 , 2 kmpl ? How much
Although i'm comparing apples to oranges but my Alto's mileage improved by about 1.5 kmpl after i got a original K&N installed in my ride.
harishnayak is offline   Reply With Quote
Old 9th December 2009, 20:05   #130
motionfreak's Avatar
Thanked: 54 Times
A k&N filter: the air intake of the engine is increased considerably.
Now extra air volume with normal fuel volume results in leaner mixture. To compensate this, the ECU increases fuel intake which results in slight drop in FE.
This how it should be.
Increse in FE means you are burning leaner mixture.
In newer FI cars, with ECUs and sensors, we need not do this manually. but in older cars, and bikes, with carbs , it is necessary to replace the main jet by larger diameter jet, to gain performance. This increses the fuel intake and in turn results in gain in power.
motionfreak is offline   Reply With Quote
Old 10th December 2009, 10:49   #131
Thanked: 36 Times
regular K&N free flow filter. not the apollo type. and yes the filter was an original and was fitted at the dealership.
around 3 to 3.5kmpl. since i drive almost 50kms a day, it is a big difference.
Old 10th December 2009, 13:18   #132
ashlyak's Avatar
Thanked: 22 Times
I moved to K&N 3 years back, and i am very happy with it. I believe all the cars should have this by default !! I am getting 1KM to 1.5KM more with K&N.
In my case, (for normal K&N in WaganR), i was able to install it by myself. It is just Open the bonnet, open the air filter box, pull out the old one, just place the K&N - that is it. u don't even need a screwdriver.
i think the reason would be as "motionfreak" said. What is your car make and model ?
ashlyak is offline   Reply With Quote
Old 10th December 2009, 15:10   #133
Thanked: 36 Times
dear ashlyak
this was how the K&N filter was fitted(open bonnet pop the air filter box and put it in). the car is a swift VDi.
Old 10th December 2009, 17:03   #134
Try to reset the car's ECU by disconnecting the battery for some time (10 min). The car's ECU needs to be reset when switching from stock to after market air filters.
Leop is offline   Reply With Quote
Old 10th December 2009, 17:29   #135
JMaruru's Avatar
Thanked: 107 Times
Default K&N Filter cost ?
How much does this K&N Filter cost for swift VDi ?
JMaruru is offline   Reply With Quote
Suzuki gets mired in the Fuel-Efficiency scandal volkman10 The International Automotive Scene 21 30th August 2016 20:12
Swift Diesel fuel efficiency dilemma ece2k2 Technical Stuff 20 20th March 2014 21:12
Amazing fuel efficiency from my Swift abhaybakshi Technical Stuff 17 15th November 2012 20:39
Swift ZXi Climate control_improve fuel efficiency pranil Technical Stuff 21 13th March 2006 18:16
