Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 18th September 2004, 02:55   #1 (permalink)
X-Machine's Avatar
Default Gtech Pro
Hey guys.......
Is anyone using the Gtech Pro Performance Meter?
Just wanted to know a few things about it,like how accurate it is and the level of information provided.
Also is it available in India?? or has to be shopped over the net.
Thanks.
Cya.
__________________
------->> X <<-------
X-Machine is offline   Reply With Quote
Old 18th September 2004, 13:09   #2 (permalink)
Hey X-Machine,
I use the G-Tech and there are many who will vouch for it. It is said to be within 1% accuracy of the readings shown. Among other parameters, you can measure your 0 - 60 mph time, 60 - 0 braking time, the 1/4 mile time and lateral G's.
I have timed many cars in a 0 - 60 and the clock has always read around a tenth of the times posted by Autocarindia and Overdrive. Ditto for the 1/4 miles and braking times too.
Best of all, its very cheap ($50 from ebay) and extremely simple to use.
But dont get addicted to it. It will ruin your transmissions - especially if FWD.
__________________
Change the way you think, and watch the world change around you.
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 18th September 2004, 23:14   #3 (permalink)
X-Machine's Avatar
Thanks dude.....
I checked up on e-bay.They only have the 1994 model available.
And on the G-tech pro website,they have only 2004 models(2)
available at the price of 199$ and 299$.
Temme one thing,is is worth this price?
And is it available with anyone in India?
Cya.
__________________
Old 5th January 2005, 09:15   #4 (permalink)
lamborghini's Avatar
hey GTO
how does it screw up your engine ...
__________________
¢нєєяѕ
ℓαмвσ
lamborghinirules@gmail.com
lamborghini is offline   Reply With Quote
Old 5th January 2005, 09:35   #5 (permalink)
Lambo,
Using the Gtech is just too addictive. And constant clutch dumps to get a good timing is really really hard on the transmission. Heck, its easier to control your smoking than to keep the Gtech locked in the drawer for a month.
__________________
Old 20th July 2005, 13:13   #6 (permalink)
moralfibre's Avatar
Hey GTO
I just wanted to know how does the GTech manage to collect data... RTech told me that the GTech is connected by a wire to the 12V output (Cig lighter)
Does the GTech have any kind of sensor/cable that connects to the ECU or something to get the information.
What all features does your model of the device carry.. can I connect it to my comp and download data? Do they have any software to support this?
__________________
"As long as there are short, balding, middle-aged men, there will always be a market
for the Porsche 911." - A BMW Owner. :)
moralfibre is online now   Reply With Quote
Old 20th July 2005, 14:24   #7 (permalink)
DRC
DRC's Avatar
Moralfibre, I dunno how it works, But puttig my guess work.. ripple from the alternator is the best source to tap out of lighter socket..
I also understand that it uses the 3way accelerometers for accurate data on the vehicle physics...
One thing I also did not get is how could he calculate BHP with this data.. Then why the hell do we need the dynos?
GTO, you could try this experiment if you wish... disconnect the charger line from the alternator to battery and see if it still tell you about the RPM..
__________________
_____________________
Stand on your head, upside down..
The world does not look any different, but you sure will look different!
DRC is offline   Reply With Quote
Old 21st July 2005, 09:15   #8 (permalink)
This is the website: http://www.gtechpro.com/
The Gtech works only when the alternator is generating current. In fact the results are better if the headlights are switched on.
papaboost is offline   Reply With Quote
Old 15th August 2008, 10:23   #9 (permalink)
Red face
All - I know this is a pretty old thread, but I was reading through the gtech rr/ss user guide and had one question - for measuring rpm from the ciggie lighter, the gtech needs to be calibrated. More specifically, you need to hold your car at two rpm readings (eg 2k and 4k) for sometime and then it calibrates.
Now if my car has no tacho (its a santro ) then how do I know when my car is at 2k rpm or 4k rpm and hold the same to calibrate the gtech.
It is kinda like the chicken and egg problem, do I need a tacho in my car to calibrate the use of gtech as a tacho??
I am just a regular gadget freak, who thought of getting a gtech from ebay (if its real cheap not 199usd) for the sake of measuring rpms in my santro, as the santro has no tacho and it seems theres some probs fitting regular tachos in a santro as you get only half the true rpm (due to dual coils??)
jassi is offline   Reply With Quote
Old 15th August 2008, 10:58   #10 (permalink)
VJ_MAVRICK's Avatar
Jassi ! To my knowledge the Gtech is equipped with a Tachometer with shiftlights too and hence measuring RPM should not be a problem. As the basic functionality of a Gtech lies in
1.Handling G's,
2.Precision Sensors
3. A specific number of runs record
4. RPM meter
These are the some of the features which it is capable of and there might be other features too which am unaware of and maybe some of the experts who use might be of help.
So coming back to your query, i think you need not go for a specific tacho incase of going for a GTech. But then again the same query arises. Will you not face the same problem in your santro for using an inbuilt Tacho in Gtech ?
Experts do comment and correct me if am wrong.
__________________
Every SAINT has a PAST and Every SINNER has a FUTURE
VJ_MAVRICK is online now   Reply With Quote
Old 15th August 2008, 11:15   #11 (permalink)
Smile
@vj - i know the gtech has a tacho which works from the lighter socket, which is why I want it - I don't think you understood my query.
as per the user guide http://www.gtechprosupport.com/suppo...uals/SS1.0.pdf you need to calibrate the gtech for it to accurately give you the rpm and shiftlight readings (see page 41-42 and 66). This calibration process requires you to input the redline rpm (which i can get off santro datasheet - 5500rpm) and then hold the car at specific rpms (eg.2k and 4k rpm), so that it can sense the current variations in the lighter at those rpms and create a reference for itself).
If i don't already have a tacho, how do I hold my car at 2k and 4k rpm for calibration of the gtech
1.Handling G's,
2.Precision Sensors
4. RPM meter
Old 15th August 2008, 11:20   #12 (permalink)
VJ_MAVRICK's Avatar
Yea oh my bad! I think then in that case you need to have a RPM meter to gauge it to a gtech. Why dont you PM viper who might be able to answer it as some days back i had seen his GTECH pro for sale in our classified sections.
__________________
Old 15th August 2008, 11:26   #13 (permalink)
Rehaan's Avatar
...I am just a regular gadget freak, who thought of getting a gtech from ebay (if its real cheap not 199usd) for the sake of measuring rpms in my santro, ...
If its only RPM you are interested in, im sure you could find a much more affordable Tacho solution than the Gtech Pro RR/SS.
However, to answer your question on how to find 2kRPM and 4kRPM, you could either just get an electrician to connect a tacho to your santro temporarily just while you configure the Gtech - or alternatively, you might be able to use some sort of scantool / scanguage available at your a.s.s workshop. Lastly, you could always calculate using speed and gear rations and drive in a particular gear @ a certain speed which will be roughly 2kRPM and then again for 4kRPM.
cya
R
__________________
The memory of you will ride by our side forever.
Old 15th August 2008, 11:33   #14 (permalink)
Red face
@vj thanks I did pm viper
@rehaan - yeah I am sure I can find something more affordable, but seems I can do a lot more with gtech (did i mention gadget freak hehe). well i am not expecting much out of it on my santro, but yeah its mobile and on my next car which will definitely be a more performance minded purchase, the gtech would be good to have!!
Ok so - indeed it is a chicken and egg problem and I will need some other form of rpm measurement to calibrate the gtech, hmm!!
Old 16th August 2008, 05:05   #15 (permalink)
Rehaan's Avatar
Jassi,
I just assumed you have seen this thread, but maybe you havent > http://www.team-bhp.com/forum/gadget...et-iphone.html (Dynolicious : Want to Dyno your car? Get an iPhone.)
Only flaw is that it does not have RPM measurement in the software, and also, maybe you dont have an iphone...?
cya
R
__________________
Thread Tools
Gtech Pro EGS - The complete all in one meter?? binz Modifications & Accessories 31 2nd May 2008 15:25
Pro installer in Mumbai? amit_sound Ask the Gurus 1 12th October 2007 23:53
Gtech Pro SS X-Machine Shifting gears 1 17th May 2006 10:20
Wanted:Gtech Pro RR... veyron1 Shifting gears 3 7th December 2005 10:43
Gtech .. ???? khaadu75 Modifications & Accessories 3 4th January 2005 23:17
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
