Old 6th October 2016, 13:45   #16
ashishk29's Avatar
Thanked: 130 Times
Default Re: Speed-sensing Auto Lock for the Hyundai Creta! Simple OBD module for Rs 1,050 only
I checked this for Honda Jazz. Sadly it is available only for the AT version, not MT :(
I do not understand why loads of OEM are skipping this feature which would ideally require only like 10 lines of code.
ashishk29 is offline   Reply With Quote
Old 6th October 2016, 15:23   #17
SRM
Thanked: 24 Times
Originally Posted by Insane Devil View Post
hi,
my suggestion is to take the plunge, and go for it. its just Rs.1k, well worth it, if it works. Only order if your's is an AT, and you are ok to lose the money if it doesn't work. you could probably sell it to a fellow forum member for their Creta.
Thanks buddy for all the info and suggestion! Was planning to do that initially but mine is not an AT and I checked with the seller as well. He said he's only sure of this working in AT.
So I guess my wait continues
SRM is offline   (1) Thanks Reply With Quote
Old 6th October 2016, 17:36   #18
TorkBHP's Avatar
Thanked: 43 Times
@naikameya: Its better that it works 100% of times since you will be sure of the car locking beyond a certain speed. If its execution is any percentage lesser, it basically puts you at the same risk without it since you'll be under the impression that there's a speed auto lock & you will tend to hence ignore whether the car is locked or not.
If you are in any case going to monitor it at all times whether its locked or not you might as well do it manually.
This feature is for the car to take care of basic security at all times instead of you applying your mind or attention to it.
Absence of this has always been a glaring miss by Hyundai under the garb of considering this as a high end feature & not a basic security need.
Good find by Insane Devil
But unfortunately not available for a manual variant.
TorkBHP is offline   (1) Thanks Reply With Quote
Old 6th October 2016, 23:00   #19
Insane Devil's Avatar
Thanked: 164 Times
I think it cpuld work on an MT. i mean, the seller had initially asked me to send pic of the buttons/switches on the driver side door. I think he was looking for the "lock/unlock" switch there.
My i20 doesn't have the "lock/unlock" switch on the door switch panel, I have to lock the car or unlock it from the lock lever next to the door opening handle.
Actually, any one with a Hyundai car, which has the lock/unlock switch on the door, are welcome to try my device.
We could try out on a Verna, i10, or the new i20 if that has the lock/unlock button.
Insane Devil is offline   Reply With Quote
Old 6th October 2016, 23:02   #20
Thanked: 164 Times
Hey Ashish, could you please upload the pic of the switches on your driver side door?
Old 7th October 2016, 11:01   #21
ashishk29's Avatar
Thanked: 130 Times
Post Re: Speed-sensing Auto Lock for the Hyundai Creta! Simple OBD module for Rs 1,050 only
It's like this:
Speed-sensing Auto Lock for the Hyundai Creta! Simple OBD module for Rs 1,050 only-2015hondajazz14.jpg
Mine doesn't get a separate lock/unlock switch.
The central locking is operated by the drivers side lock button.
Old 7th October 2016, 13:02   #22
Thanked: 164 Times
It's like this:
Attachment 1563802
Same as my i20, so i doubt it will work on this.
Old 7th October 2016, 13:20   #23
ashishk29's Avatar
Thanked: 130 Times
Yeah. That, plus the details mention that it relies on the Auto transmission gear mode: D locks and P unlocks.
If the devices locks and unlocks based on this, then I don't think it'd work on manual variants
Old 7th October 2016, 14:23   #24
abhibh's Avatar
Thanked: 34 Times
IIRC even older i20 lacked this feature, but it was easily activated by service center guys with some coding.
http://www.team-bhp.com/forum/techni...ps-tricks.html (Hyundai i20 - Tips & Tricks)
abhibh is offline   (1) Thanks Reply With Quote
Old 7th October 2016, 15:02   #25
Thanked: 11 Times
Insane Devil -Glad to see that you found some solution for a problem I am still struggling to address.Can you pl tell me which part of Hyderabad you are located,I own Creta petrol MT and would like to get this tested if its fine with you.
amit_mind is offline   (1) Thanks Reply With Quote
Old 10th October 2016, 11:10   #26
ashishk29's Avatar
Thanked: 130 Times
I wonder if the Honda service center guys would oblige.
Gotta check it once I'm back to pune.
Old 13th October 2016, 15:46   #27
nkghai's Avatar
Thanked: 689 Times
Were you able to connect and test the device on MT.
A lot of people are eagerly waiting for the results.
nkghai is offline   Reply With Quote
Old 14th October 2016, 02:11   #28
Thanked: 164 Times
Not yet, as he doesn't have private messaging enabled, and i can't give out personal contact info anywhere but on private message.
Old 14th October 2016, 12:23   #29
Thanked: 11 Times
I think I have private messaging enabled.
amit_mind is offline   Reply With Quote
Old 14th October 2016, 13:59   #30
Thanked: 14,609 Times
No buddy. You are a 'Newbie' now so 'no PM' facility.
You'll need to cross the 25 post barrier to promote to a BHPian status to activate the PM facility.
a4anurag is online now   Reply With Quote
$50 only! Launch X431 OBD-II Scanner with Maruti & Hyundai software a4anurag Technical Stuff 59 23rd January 2017 08:41
DIY - Simple Hand brake for Jeeps - Ball Valve as a Line Lock svsantosh 4x4 Technical 22 16th June 2014 06:57
Speed-sensing Auto door lock issue (after ICE install) vigsom Technical Stuff 3 3rd December 2013 15:34
Security : Gear lock, steering lock venkatrx Modifications & Accessories 11 25th January 2011 18:04
Advantages of OBD 2 over OBD 1 Sprucegoose Technical Stuff 19 20th October 2009 06:44
