Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 6th May 2004, 17:19   #1 (permalink)
Hi Friends,
I want to improve the ride of my Indigo which is a bit bumpy. Is it possible to tune the suspension? If possible will it affect the handling or milege? Any one plz give me some suggessions.
with luv,
Bhaskar.
bhaskarcse is offline   Reply With Quote
Old 12th May 2004, 21:41   #2 (permalink)
Shan2nu's Avatar
i dunno how easy it would be to tune the suspenssion. When i asked Honda if it was possible to maybe soften the rear suspenssiona a bit, they said that the suspenssion will have to be replaced for that.
Handling an comfort don't usually go hand in hand. If you hear anyone say their car offers both at the same time, then i'd stay away from thar car.
It's a different thing with cars that offer "Sports Mode".
I've driven the Indigo and it's very comfortable when compared to the ride quality of the Vtec. I don't think you need to make any changes to that or you'll end up with a very twitchy and unstable car.
Regards...
Shan2nu
__________________
VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE
Old 12th May 2004, 22:33   #3 (permalink)
Super-Admin
I second what Shantanu said. The Indigo offers class-leading ride quality levels. Dont think you need to mess around with that suspension.
__________________
Self-imposed limits are the only type that exist. Break them....then, make it a habit. Exceed.
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 13th May 2004, 05:04   #4 (permalink)
Team-BHP Moderator
Rehaan's Avatar
Hi Bhaskar,
You might want to check your tire pressure, because if it is too high it causes the ride to become very hard.
You can afford to lower your tire pressure to the lower end of the range that the manufacturer's reccomend.
The correct inflation levels are mentioned in the manual, as well as inside the fuel flap, or on the passenger or driver door (on the narrow side that faces the rear when the door is closed)
Hope this helps,
Rehaan.
__________________
The memory of you will ride by our side forever.
Rehaan is online now   Reply With Quote
Old 13th May 2004, 06:39   #5 (permalink)
Originally Posted by [b
Quote[/b] ]You might want to check your tire pressure, because if it is too high it causes the ride to become very hard.
Rehaan is right - especially when it gets warmer outsite, the air expands and your tires tend to 'inflate' more. Adjust the pressure, you should see a noticeable difference.
Powerslave is offline   Reply With Quote
Old 13th May 2004, 15:12   #6 (permalink)
Shan2nu's Avatar
Well, asuming that the Indigo has the same S322 175/65 R 14 tyres present on the Vtec, the recomended tyre pressure is 29 psi. The max tyre presssure the tubes can handle is 44 psi.
I usually keep it at 31 psi. It's a bit bouncy but you get faster acceleration and sharper handling.
I wouldn't suggest anything below 29 psi, as it would strain the sidewalls of the tyre.
Regards...
Shan2nu
__________________
Old 14th May 2004, 08:27   #7 (permalink)
Team-BHP Moderator
Rehaan's Avatar
Hey Shan2nu,
Tyre pressure might defer from car to car even if they are using the same tyres (due to the differnt weights of cars etc).
If Bhaskar uses his indigo for city driving even 28psi is considered fine, and will definitely improve ride quality.
Ofcourse for your useage, and highway driving 30-34psi depending on conditions is better.
cya
R
ps - once my friend car was riding incredibly hard, he couldnt figure out what was wrong initially, but then realised his sister had taken the car to the petrol pump and the tires were filled to 42psi!! on a santro!@!!
__________________
Thread Tools
Improve the FE of a 4 BHP engine? ag501 Technical Stuff 13 18th January 2008 18:32
How to Improve the Ride Quality - Ikhanna Technical Stuff 10 6th January 2007 23:03
Improve the Ride Comfort & Handling of Omni mithun Modifications & Accessories 14 17th October 2006 05:02
Indigo Marina conv to Indigo Advent vivek.singh.73 Modifications & Accessories 1 27th August 2005 09:26
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
