Old 30th January 2017, 09:31   #46
Thanked: 692 Times
Default re: XP Micro: Bi-Xenon Projector Foglamps. EDIT: Terrible experiences
Originally Posted by Dr.Naren View Post
Low Beam :
Stock headlight
Attachment 1597179
XP Micro
Attachment 1597185
When you compare the two the XP Micro has a rising cutoff line. This is totally wrong. The cutoff line should be below the center of your lamp line, ie a falling cutoff line. The stock lamps cutoff is near the wheels of the car ahead, the XP micros do the same.
Take a chair and sit next to the parked car so your eyes are at the level of a sedan's driver. Your stock low beam will not blind you, but the XP Micros low will.
High Beam :
Stock headlight
Attachment 1597183
XP Micro: Look at the massive difference in output these small micros do
Attachment 1597184
Again here you are illuminating far above what you need to illuminate. You should be able to see the ground floor window on the wall in high beam, not the first or second.
Rahul
Rahul Rao is online now   Reply With Quote
Old 30th January 2017, 09:59   #47
Dr.Naren's Avatar
Thanked: 6,811 Times
@Rahul Rao: It is about the alignment of projectors. Refer to post #44 and check my alignment . Yes, I agree that Warun had aligned XP Micros little higher and he has lowered it now, which is perfect.
Cheers!!
Check the present alignment: XP Micro Cut off is below stock HL cut off in low beam
XP Micro: Bi-Xenon Projector Foglamps. EDIT: Terrible experiences-fb_img_1485750739931.jpg
XP Micro: Bi-Xenon Projector Foglamps. EDIT: Terrible experiences-fb_img_1485750758201.jpg
Dr.Naren is online now   (2) Thanks Reply With Quote
Old 5th February 2017, 23:49   #48
Dr.Naren's Avatar
Beware of Fakes / poor quality Bixenon Fog Projectors!!
I have seen that many local shops have started selling Bixenon Fog Projectors recently. The output is nowhere close to XP Micro and many are getting duped.
Posting an output pic of the fake/poor quality fog projector: ( Customer prefers to remain anonymous)
XP Micro: Bi-Xenon Projector Foglamps. EDIT: Terrible experiences-img20170205wa0040.jpg
Look at the output and it is just crap. Also few guys are using Xenon Planet name to sell their low quality fog projectors. I advice everyone to contact Xenon Planet directly on their fb page / website for XP Micro.
Old 6th February 2017, 12:58   #49
DRIV3R's Avatar
Thanked: 1,387 Times
Attachment 1604615
What is the "customer" doing with the bixenons in his hand, inside a room aiming at the ceiling?
DRIV3R is offline   (6) Thanks Reply With Quote
Old 9th February 2017, 13:40   #50
dudevarkey's Avatar
Thanked: 72 Times
Yes there is some gap, but it is hardly noticeable from distance :
Attachment 1574078
Found this one in aliexpress. https://www.aliexpress.com/item/2Pcs...703932664.html
This may help to fill the gap, if you are ready to live with an additional chrome ornament.
dudevarkey is offline   (1) Thanks Reply With Quote
Old 9th February 2017, 14:07   #51
Dr.Naren's Avatar
I have checked this out. Also I have seen a pic of S-Cross with this cover after installation of XP Micro. It fills that gap upto 90 percent.
Dr.Naren is online now   (1) Thanks Reply With Quote
Old 9th February 2017, 18:09   #52
Dr.Naren's Avatar
I was just casually checking the output of XP Micro by standing "outside the car". I happened to notice that there are few streaks. I am not sure if it was present before. I checked my previous videos and couldn't find the streaks. Also there's a possibility that I missed them out because those streaks gets masked by stock head light and also not much visible from driver seat (streaks present close to car). I know at least 5 guys who have installed XP Micro in S-Cross and asked them to check for the same. Nobody had this issue. Anyways, these streaks doesn't affect the output and hardly noticeable while driving. I believe in perfection and will get this issue sorted out. Xenon planet has agreed to look into it and suspecting about bulb seating. I will get it checked soon.
XP Micro: Bi-Xenon Projector Foglamps. EDIT: Terrible experiences-img20170209wa0036.jpg
XP Micro: Bi-Xenon Projector Foglamps. EDIT: Terrible experiences-img20170209wa0035.jpg
Old 18th March 2017, 14:27   #53
BoneCollector's Avatar
Thanked: 1,559 Times
Hi, How are the Micros performing now? Have you been able to get the streaks rectified?
BoneCollector is offline   Reply With Quote
Old 18th March 2017, 14:37   #54
Dr.Naren's Avatar
There is no issue with performance. The streaks are present very close to the car and not visible from drivers seat. Also, I checked few old videos of mine and concluded that streaks were present from day one. According to Xenon Planet, it's a minor issue and would be rectified by proper bulb seating. I did not get it checked yet.
Check this video shot 2 days back (poor quality though)
Old 18th March 2017, 15:12   #55
harsh79's Avatar
Thanked: 630 Times
Probably checking the cut-off's sharpness for defects and if the cut-off shield is coming back to its original position after a flick to high-beam before installation.
harsh79 is online now   Reply With Quote
Old 29th March 2017, 08:32   #56
Dr.Naren's Avatar
I checked with Xenon Planet regarding the streaks in my XP Micro setup. Bulb seating / new bulbs have not solved the issue. The streaks are still present. The exact problem couldn't be identified and projectors have to be sent to Chandigarh. I don't have stock fog lamps with me right now and would get those from a fellow BHPian as he is using XP Micro. I have shifted to Mysore and I don't have much free time to drive. I will send the XP Micro to Chandigarh and would be running on stock fog lamps for at least a month. I would be free to get the XP Micro installation done in Bangalore only by May 1st week.
XP Micro: Bi-Xenon Projector Foglamps. EDIT: Terrible experiences-img20170329wa0003.jpg
XP Micro: Bi-Xenon Projector Foglamps. EDIT: Terrible experiences-img20170328wa0072.jpg
Also, I have confirmed that those streaks were present from day 1 by checking old video (shot one day after installation) and I shot a video just now. The streaks are not very prominent from drivers seat and it gets masked by stock headlights.
Video links : Look for the streaks when only XP Micro is on near the right side pillar
Dr.Naren is online now   (3) Thanks Reply With Quote
Old 30th March 2017, 12:32   #57
redbaron91's Avatar
Thanked: 219 Times
What bulb colur temperature you bought Dr.Naren?
After going through your thread, i'm now inclined towrards XP micro for my Ecosport.
Also could you please tell me whom to contact at EVO Bangalore for installtion?
redbaron91 is offline   Reply With Quote
Old 30th March 2017, 13:05   #58
Dr.Naren's Avatar
I have reverted back to stock fog lamps and waiting for the update regarding my XP Micro. I was using 4300K CN light bulb.
You can contact Shyam Hegde, XP Bangalore team member for the installation.
Dr.Naren is online now   Reply With Quote
Old 31st March 2017, 09:59   #59
aargee's Avatar
Thanked: 2,126 Times
Just incase, INCASE, you come across better, brighter (if non white more merrier), replacement for the stock D5S, please let me know & if I come across a better performing one, I'll keep you all posted as well.
I'm already tired of the stock 25W output!! My 13 year old WagonR had a better & reliable 130/100 setup & was much brighter than this one
Old 31st March 2017, 10:11   #60
Dr.Naren's Avatar
I did try very hard to find a direct replacement for OEM Philips 25W HID system. But, what's available is some Chinese 35W D5S setup. I don't think it would result in any big improvement. S-Cross 1.6 badly needs better lights and I find it very difficult without XP Micro now.
DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift a4anurag DIY - Do it yourself 64 27th December 2017 12:06
Spotted! Tata Xenon Facelift. EDIT: Launched as the Xenon Yodha tushky The Indian Car Scene 22 3rd February 2017 23:21
HID Kit / Projector / Xenon Lamps FAQ Takumi-san Modifications & Accessories 17 12th August 2015 14:34
DIY : Bi-Xenon Projector for Hyundai i20 3danikesh DIY - Do it yourself 42 2nd March 2015 18:15
Corolla Mods - Eibach Springs, Xenon HIDs and Angel Eye Projector Headlights novice Modifications & Accessories 14 2nd July 2011 03:46
