Old 17th October 2006, 10:15   #1
dsinz's Avatar
Lightbulb Shift - Light Tachometer for Alto
I am planning to put a Shift - Light tachometer for my Alto Lxi. Would be great if you guys can help me with my queries.
1. Can it be fixed?
2. Type of Tacho that will go well with Alto..
3. Does it work as good as Alto Vxi one?
4. Cost factor
5. What does it take to fix? wiring etc etc
6. Place to fix it in Bangalore.
7. Does the tachometer need to be a 3 cylinder compatible or any specification will do? Some Gyan needed.
8. If i get the tacho from US, can it be fixed here?
Thanks!
dsinz is offline   Reply With Quote
Old 17th October 2006, 11:37   #2
swale84's Avatar
dsinz,
1. Can it be fixed? Yes it can
2. Type of Tacho that will go well with Alto.. Depends on your taste, really, shouldn't be too big IMHO,
3. Does it work as good as Alto Vxi one? depends on the quality, brand, fitting etc.
4. Cost factor. I believe prices befin at roughly 2.5 k. I have no concrete idea though
5. What does it take to fix? wiring etc etc Usually all the required wiring etc. is included in the packaging along with installation instructions
6. Place to fix it in Bangalore.I'm from Mumbai, so no idea, someone else will come along and shed some light on this, I'm sure
7. Does the tachometer need to be a 3 cylinder compatible or any specification will do? Some Gyan needed.Yeah, the tachometer will have to be 3 cylinder compatible, the one I have fitted on my Zen has a slider switch at the back to choose between 4, 6 or 8 cylinders.
8. If i get the tacho from US, can it be fixed here?Yes, I got my tachometer in the U.S , actually my dad bought it for me !!
Installation was done by my regular mechanic, he did a pretty neat job, took a little under an hour.
Suhail
swale84 is offline   Reply With Quote
Old 2nd December 2007, 17:34   #3
where can i find one in Mumbai.. i have a new ALto LXi and am looking to install one.
ddd08 is offline   Reply With Quote
Old 2nd January 2008, 22:20   #4
well I guess my query has missed peoples eyes... its been a month now since i've asked.
Old 8th January 2008, 19:56   #5
hello
yes can be done is ur engine a 3 cyl or 4 cyl as the tacho for 3 and 4 is different
armotosport is offline   Reply With Quote
Old 27th June 2008, 15:25   #6
vrooooooom's Avatar
Default Suggestion on fitting tacho with shift indicators
I am planning to fit a tacho with shift light indicator. But I am not sure what are the pros and cons. Any issues with calibration. I was looking on amazon for few. But I am not sure whether it will fit in Baleno or not. Also what are the hassles of fitting one. Can it be a DIY task? It would be great if anyone can suggest. Here are some links of the tachos I was looking at.
Amazon.com: Black Digital Tachometer & Blue LED Shift Light: Automotive
Amazon.com: Proform 67005C Adjustable RPM Shift Light: Automotive
Amazon.com: Silver Digital Tachometer w/ Red LED Shift Light: Automotive
Note from mod: threads merged, please use search function before starting new threads
vrooooooom is offline   Reply With Quote
Old 27th June 2008, 16:05   #7
vrooooooom's Avatar
@Swale84: Can you tell me the make and model of your tacho? Also if you have some pics then it would b great.
Cable Shift vs Direct Shift Gearboxes BlackPearl Technical Stuff 14 15th September 2013 13:35
Adding a Tachometer to Alto! ramki067 Modifications & Accessories 15 1st September 2009 15:11
Wanted Tachometer with gear shift indicator for my Gypsy Hemanth Shifting gears 4 3rd January 2008 15:41
For Sale: Autogauge 3'3/4"TACH 0-10,000 R.P.M. (W/SHIFT-LIGHT) s0uljah Shifting gears 12 19th September 2006 22:05
Tach With a shift light needed... Rice_tuner Modifications & Accessories 6 3rd January 2005 09:13
