Old 26th April 2010, 10:48   #226
naveen.raju's Avatar
Thanked: 3,726 Times
My friend got his tail lights smoked using sunfilm. Extra care should be taken while using sun films. Make sure that the edges are smooth without any curls. Best way of doing so is by using heat gun. End result was excellent which had a gloss effect.
naveen.raju is offline   Reply With Quote
Old 26th April 2010, 14:23   #227
the_maassk's Avatar
I got my car's tail-lights smoked by using black spray paint from outside!
First the surface needs to be cleaned well. Then a 1:3 mixture of black paint and thinner is sprayed evenly on it. This is left to dry for a couple of hours and then a second coat is sprayed. You can control how dark the tails look by controlling the number of coats. After final drying, a clear coat is sprayed on top. This is then left to dry for 12-18 hours. The surface is then cleaned and polished.
The result is what you see below. The brightness is very mildly hindered. I initially though it would look horrible on a black car - but I was in for a surprise! I've had this for around 6 months now.
the_maassk is offline   Reply With Quote
Old 27th April 2010, 06:26   #228
punterccrx8s's Avatar
Thanked: 41 Times
^^ What spray paint did you buy?How much did it cost?
punterccrx8s is offline   Reply With Quote
Old 27th April 2010, 09:18   #229
the_maassk's Avatar
Went to my friendly neighborhood garage. They have a paint shop. Cost me a total of Rs.600 including everything.
Old 27th April 2010, 09:57   #230
Vik0728's Avatar
Thanked: 2,304 Times
hey @the maassk, you have virtually transformed the look & appearance of the UVA buddy. Looks pretty neat.
Have you thought about smoking the headlights as well ??
Also, how is the performance post the headers and filters??
Vik0728 is offline   Reply With Quote
Old 27th April 2010, 12:11   #231
the_maassk's Avatar
Thanks! I'm still to do a proper photo session for my ride .
About smoking the headlights - the proper way involves separating the lenses by heating and a lot of other headaches. I'm still to find a reliable guy who can help me through the process. Might do it soon. On the other hand, I've found replacement smoked headlamps for the car at a few shops in UK. I might just get them over on my next trip!
Performance post the headers and filter - rocking . I'm not running the K&N any more (yet to take off the decal from the back of the car). I'm on GC Wind with my own custom piping for cold air.
Old 4th May 2010, 21:06   #232
Thanked: 41 Times
Got my light blackened out for 500 Rs.Paint not sun film.
Old 5th May 2010, 10:32   #233
Stunn-R's Avatar
Thanked: 12 Times
Spray can and clear coat over
Stunn-R is offline   Reply With Quote
Old 5th May 2010, 19:09   #234
Thanked: 103,657 Times
The two of you have made regular hatchbacks look mouth-wateringly delicious!
I'm very tempted. Only concern : The brakelights dimming substantially. Can you post some pictures taken at night with the brake lights on, and no flash?
Old 5th May 2010, 19:40   #235
Thanked: 41 Times
Absolutely no problem in the morning only GTO sir,no question about night.It's pretty clear,the brake light.Only the indicators little dim.
Old 5th May 2010, 20:20   #236
rjstyles69's Avatar
Thanked: 795 Times
Attachment 342864
Attachment 342865
punter please get that number plate fixed properly, doesn't compliment the work done on the tail lamps.
Old 6th May 2010, 05:49   #237
Thanked: 41 Times
I didn't get you.Do you mean get it fixed at a different place or get it fixed properly only?
Old 6th May 2010, 07:06   #238
harishnayak's Avatar
Thanked: 118 Times
I think he meant that it should be fixed at it's original place.
RJ - I hope i got you right?
harishnayak is offline   Reply With Quote
Old 6th May 2010, 09:32   #239
the_maassk's Avatar
Saw GTO's pic request this morning otherwise would have taken some pics last night itself! No sweat though - will get some pics out today late evening
Old 6th May 2010, 13:58   #240
rjstyles69's Avatar
Thanked: 795 Times
I am talking of the marked locations, see the gap coz of the rubber beading. The plate looks tapered too. The angle of the pic couldn't be the culprit though.
I would go by harish's thought considering the fact that plate doesn't sit flat on the bumper.
PICS : BMW 320D PE roof Blackened! quattroa4 Modifications & Accessories 22 19th August 2012 13:34
Corolla Mods - Eibach Springs, Xenon HIDs and Angel Eye Projector Headlights novice Modifications & Accessories 14 2nd July 2011 03:46
Gear Lock and Headlights for Getz nishantgandhi Modifications & Accessories 21 6th August 2010 01:43
Accent Viva CRDI- Need the chrome blackened midlifecrisis Modifications & Accessories 9 14th June 2007 17:41
Turn your headlights off and only use the horn! Rtech Street Experiences 37 13th April 2006 16:04
