Old 20th May 2016, 23:27   #16
OSH
OSH's Avatar
Thanked: 513 Times
Default Re: Powerful headlamps for indica
Originally Posted by greenhorn View Post
Which makes more sense, a 100/90 upgrade or a set of hella 500/700FF's ?
My choice would have been a 100/90 upgrade. The reason is that aux lights will need cut-outs in the bumper which will firstly spoil the look and secondly it will start rattling down the years due to our pot-holed roads. Also cops may create problems for you when you are driving in the city and they see those additional lights.
I had a Indica and found the lights to be adequate, you can use the level adjuster to set the beam far ahead if you are comfortable driving like that. The reason for you not being comfortable on your last trip may be because of the high-beam focus not set properly, you can have that checked before investing in the upgrade or aux lights.
OSH is offline   Reply With Quote
Old 21st May 2016, 13:45   #17
greenhorn's Avatar
Thanked: 1,516 Times
I've seen a lot of cabs running fogs installed on mounts via the slots in the front grille.
The height adjustment in my headlights is kaput and one of them is a bit hazy. Polishing has not fixed it, so i had figured that buying a new pair of fogs is cheaper than a replacement set of headlamps (7k+ or so)
Old 21st May 2016, 16:32   #18
OSH
OSH's Avatar
Thanked: 513 Times
Yes aux lights will turn out much cheaper than a set of new headlights, the reason I mentioned slots in the bumper is because I had read somewhere that, these aux lights had to be fitted below the line of headlamps. Also there are some stupid rules to cover them when driving in the city etc. someone who is more familiar with the rules please help. I guess you have the older Indica, I had the Indica Vista which had an improved throw of light.
Old 22nd May 2016, 14:22   #19
Thanked: 78 Times
I have been using a Phillips rally 100/90 on my indica v2 for the past 8 years without any modifications to the wiring , with no issue , the lighting is good especially for night driving on unlit highways, have done a number highway trips with this setup.
I did a similar change on my indigo cs again with no wiring modifications and had no issues for the 5 years the car was with me . Again lighting was really good. These bulbs give a really long life.
hubolt is offline   Reply With Quote
The Most Powerful Diesel Engine in the world GTO Technical Stuff 63 28th July 2012 18:59
Worlds most powerful roadster! YES! S350L-E240 The International Automotive Scene 83 11th November 2006 13:24
more powerful lancer may be launched this year speedhunter The Indian Car Scene 25 13th April 2005 12:58
The Most Powerful Automotive People in the world GTO The International Automotive Scene 5 27th January 2005 01:12
Dont find the Getz powerful, eh?? v12 The International Automotive Scene 4 19th September 2004 19:40
