Old 17th September 2007, 00:27   #91
Thumbs up
Originally Posted by rocksterraghu View Post
i_own_tata_indica_xeta_glx_with_ps_ac
PS : I guess it is just a matter of getting used to Indica PS. With no time to do exercises and all, I take driving Indica 60 Kms per day as an opportunity to build my arm muscles, biceps and all
AC : It is actually good for the cars in Indica's segment. GLX comes with a 1400 cc engine, so it is not adversely impacting the car performance. For GL through GLG versions, it is a 1200 cc engine, and I felt the drag when test driving these versions. These versions, WagonR and Santro, I didn't like their performance with AC on.
This is off the topic I know, but please don't start bashing me ...
Mod's Note: Not more than 2 smilies per post please.
Extra smiley edited out.
i_own_xeta_glx is offline   Reply With Quote
Old 21st September 2007, 13:20   #92
Thumbs up
Fitted Roots Vibrosonic with relay and a toggle switch. Retained stock horn. Rs. 1350 Installed, exactly the way I wanted and where I wanted. Two roots on the sides under front bumper and stock horn at the center in front of condenser. Will try to post picture later.
One - 2 blips from stock horn
Wait 10 seconds
Two - 2 blips from stock horn
Wait 5 seconds
Three - break the hell loose using Roots.
Now I complain about very very very few drivers
One query though ... Normally, the temprature gauge is at center while driving. I never used to look at it. Last 2 days, while driving on highways, doing 90+ Kmph, I noticed it falls down and stays between center and cold. Later when I join city traffic, it goes back at the center. Is this normal ? Or effect of fitting stock horn in front of condenser ? Or something wrong in fitting the horns ?
cheers:
Old 22nd September 2007, 11:12   #93
gd1418's Avatar
Thanked: 656 Times
Though a bit off-topic here, I'll try to answer this. While on a highway at 90+ kmph you are driving at a steady speed in one gear and you vehicle gets continuous air flow from outside to coll the engine. Hence this phenomena.
While in City you are driving at a variable speed with lot of braking, changing of gears, stopping, slowing down etc. In this the radiator fan has to pull outside air in to cool the engine; especially true in case of fans not controlled by a thermostat.
However, all of this depends on the ambient outside temperature as well.
cheers:
Old 13th October 2007, 14:58   #94
babhishek's Avatar
perfect answer! the same happens to me during highway trips.
babhishek is offline   Reply With Quote
Old 18th November 2007, 14:32   #95
Default Swift diesel horn
Hi Guys,
I want to fit a good sounding loud horn in my Swift Diesel. But the accessory shop guys said there is no space in diesel swift to fit a new horn. Is that true?
kaputabo is offline   Reply With Quote
Old 18th November 2007, 15:00   #96
BUSA's Avatar
Not true. I have fitted a new horn in my Swift Diesel. You need to place it behind the left side of the front bumper. Turn the wheel to extremely right and from there the mechanic can fix the horn behind the bumper.
Old 18th November 2007, 17:22   #97
stampro's Avatar
Bosch from Germany.The best.
stampro is offline   Reply With Quote
Old 18th November 2007, 23:04   #98
Smile
Thanks a lot Busa, I'll ask my mechanic to try that option. By the way which is the horn you've fitted on your Swift Diesel?
Old 19th November 2007, 00:11   #99
BUSA's Avatar
I have put Fiam Windtone. Is much better then the stock and sounds the same as Optra/Skoda
Old 19th November 2007, 19:53   #100
Thanked: 127 Times
I have Swift, VXI. Can I fit Bosch-Symphony or Root's directly in place of OEM horn, without any change in wiring/relay circuit?
regards,
-manju
manjubp is offline   Reply With Quote
Old 19th November 2007, 20:16   #101
BUSA's Avatar
Petrol Swifts need relays/cut outs.
Diesels have inbuilt relay/cut outs.
Old 19th November 2007, 21:58   #102
humyum's Avatar
Thanked: 2,503 Times
Have a stebel 3 pipe pressure horn with fiam pipes in my 800 since many many years.Has 2 options of normal non musical tone for the city and musical tone for the highway.
Costed me 1500 bucks 7 years back but now are available for 850 bucks.I Retained the fiam pipes as they give a perfect musical tone where as the stebel ones sounded too harsh/and not pleasing to the ears.
Old 20th November 2007, 00:01   #103
satish_appasani's Avatar
Thanked: 45 Times
Are these horns easily available in India? My Bosch horns in Palio D gave up after 1.5 years and this time i am looking for horns that sound like Skoda/Optra.
If not Fiam, are there any alternatives?
satish_appasani is offline   Reply With Quote
Old 20th November 2007, 00:04   #104
BUSA's Avatar
Very much available. Just go to any shop and ask for Skoda/Optra horn or Windtone Rainbow. Costs Rs. 450
Old 20th November 2007, 01:41   #105
mail4ajo's Avatar
Thanked: 261 Times
I have noticed that after installing the vibrasonic, my OE horn has become rather weak. I rarely use it now. Any idea why?
mail4ajo is offline   Reply With Quote
The best sounding car... Revvmaster Technical Stuff 327 5th January 2016 14:45
Swift VDi sounding like old Amby!! archat68 Technical Stuff 12 21st April 2011 15:18
Great sounding simple SQ setup for Swift ece2k2 In-Car Entertainment 53 29th July 2008 22:44
Swift VDI - sounding very harsh maverickzCar Technical Stuff 10 4th February 2008 11:15
Confused !!..Cool Sounding Car Audio on Budget advice needed quake6 In-Car Entertainment 77 18th July 2006 11:30
