Old 19th June 2004, 14:58   #1
Tom
Tom's Avatar
Exclamation
How does work upon the brakes to improve it's performance?
Any tips?
cheers!
Tom
Tom is offline   Reply With Quote
Old 20th June 2004, 19:59   #2
lamborghini's Avatar
Thanked: 1,664 Times
if u get disc brakes all round it will not only save yours but people around u lives.
it also improves 0 - 100 - 0 times .
i suggest putting discs all round as an important safety measure sometimes as important as an seatbelt if not more
cheers
lamborghini
lamborghini is offline   Reply With Quote
Old 22nd June 2004, 01:29   #3
Revvmaster's Avatar
Thanked: 45 Times
Hey lambo
Putting discs all around doesnt guarantee better braking times or shorter distances. Also that is just not what u only need. What about tyres locking up if the discs are huge/smaller than standard, not set correctly etc. Also not just brakes but tyres and the body as well shud be able to take the discs well. The tyres need to be of a right size and width as well as the body and suspensions taut enough to take this change in momentum.
Revv
Revvmaster is offline   Reply With Quote
Old 22nd June 2004, 03:25   #4
hey rev
never thought about that
bigger tyres o improve brake timings but i never knew that putting discs all round had a side effect.
i dont think there should be a problem if i put larger discs in front and a bit smaller in the rear.
wht do u guys say
take the case of say an ikon with 14 inch wheels
on 175 rubber
i think that it should improve.
whts ure say on this
heers
lamborghini
Old 22nd June 2004, 18:56   #5
Thanked: 103,418 Times
I remember speaking to Sunil Shanbagh (The best tuner in Bombay IMHO) about fitting rear discs in my poor braking Esteem. He said that it is a very very difficult talk to install the plumbing correctly and get the balance. Its not as simple as it sounds.
Old 22nd June 2004, 19:33   #6
Rtech's Avatar
Thanked: 221 Times
Just like you can "over-tyre" your car by fitting too wide a tyre, you can "over-brake" your car too!
To elaborate by using an extreme case, a M800 with vented discs on all wheels will not stop any faster than with the normal brakes IF the stock wheel/tyre combo is retained.
Remember, the only thing that connects your car to the ground are your tyres...hence, the first step towards better braking would be upgrading your wheel/tyres. This is where you will notice an immediate effect in all aspects of your cars handling, not only braking.
Rtech
Old 24th June 2004, 18:38   #7
Jaggu's Avatar
Thanked: 8,682 Times
imagine putting a disk set up for rear wheels and braking at speed and doing couple of 360 deg turns lol..
you bet u need to do loads of calculation reg the brake distrubution which can be handled by the car or loose the composure completely..
Old 24th June 2004, 21:32   #8
Shan2nu's Avatar
Thanked: 89 Times
I agree with Rtech, if your normal brakes manage to lock the wheels then it would be useless to upgrade your brakes. You should be looking out for better tyres.
Regards...
Shan2nu
Old 24th June 2004, 22:49   #9
Originally Posted by [b
Quote[/b] ]
OT But you scared the hell out of me before the Expressway toll booth on the way to Bombay.
And Rehaan did more than that
Old 25th June 2004, 00:24   #10
speedsatya's Avatar
Thanked: 712 Times
Quote[/b] (GTO @ June 24 2004,21:19)]
Quote[/b] ]
gto,
y wat happened .seems like u were going very fast
speedsatya is offline   Reply With Quote
Old 25th June 2004, 01:39   #11
Thanked: 27,207 Times
Quote[/b] (speedsatya @ June 24 2004,22:54)]gto,
You have to experience the black Accent late braking treatment with Rehaan to understand what happened.
Aditya is offline   Reply With Quote
Old 25th June 2004, 01:59   #12
Dippy's Avatar
Thanked: 192 Times
Quote[/b] ]You have to experience the black Accent late braking treatment with Rehaan to understand what happened
uh hum... late braking or no braking??
I still cant forget the black Accent charging towards the Vtec.. boy is the Accent Scary or what
Dippy
Dippy is offline   Reply With Quote
Retarder in Volvo B7R buses (air-brakes / jake brakes) sfilinto Commercial Vehicles 12 30th March 2010 00:55
Modifying the exhausts of commercial vehicles normally_crazy Commercial Vehicles 6 6th July 2009 18:07
Modifying and Engineering skype Shifting gears 17 29th March 2006 16:30
Modifying a mahindra? amogh Modifications & Accessories 2 3rd October 2004 16:56
Modifying cars in Bangalore. civic93_gen2 The Indian Car Scene 1 6th March 2004 16:30
