Old 12th April 2017, 12:56   #61
Thanked: 1,326 Times
Default Re: Remote locking : Autocop or Xenos or Nippon?
Originally Posted by ramki067 View Post
Just wanted to know for what purpose these sensors are needed?
They let the control unit know whether the doors / boot / bonnet are closed properly or not.
On second thoughts, I realise that the package is missing a horn too. So, door lock/unlock (audible) notification might not be supported here. It might also not be possible for the car to autolock after turning on the ignition.
This appears to be a very basic unit that will just enable you to lock/unlock your car using the remotes instead of the key and not a car security system which is what should purchase.
dailydriver is online now   (1) Thanks Reply With Quote
Old 17th April 2017, 17:29   #62
ramki067's Avatar
Thanked: 25 Times
Originally Posted by dailydriver View Post
It will work on your Wagon R Lxi. The manual central locking system has an inbuilt actuator. The installer will just have to connect the control unit of the remote to the already existing system and you are good to go.
I've one more question if it doesn't bother you.
After installation of remote keyless entry system, can we use the Manual key system to open the doors?
Thanks.
ramki067 is offline   Reply With Quote
Old 17th April 2017, 18:01   #63
Yes. You can lock/unlock the doors using the key just as you are doing now.
A minor rider though - if you lock the door using the remote, unlock it the same way. Using the key to unlock the doors will trigger the alarm (if equipped) and cause a minor commotion .
dailydriver is online now   Reply With Quote
Old 3rd October 2017, 11:52   #64
keeprevving's Avatar
Thanked: 231 Times
I installed Autocop remote central lock system in my 2012 Honda City iVtec. It works like a charm. No issues till now. However, the Autocop technician warned me that the door lever wire snaps easily after repeated use. He added that this issue is only with Honda City 3rd gen models (2008-2012). The replacement costs of the door lever wire assembly is somewhere around Rs.5000/- (not confirmed though). I took a chance, as I have come across many City owners who use the same without any issue. Fingers crossed.
keeprevving is offline   Reply With Quote
Fiat branded remote autocop central locking and parking sensor sidindica Modifications & Accessories 32 14th October 2016 13:22
Xenos or Autocop ?? nikunj_cal Modifications & Accessories 60 29th May 2010 18:14
Alto Xcite - Upgrade Manual Central Locking to Remote Central locking Laxminarayan Technical Stuff 1 28th December 2009 15:02
Central locking versus remote locking mb_jg Technical Stuff 40 2nd January 2009 20:08
Xenos / Autocop / Minda Central Locking keanu_reeves Modifications & Accessories 4 14th September 2007 04:56
