Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here!
Thread Tools
Old 18th January 2007, 11:56   #136 (permalink)
condor's Avatar
Tanveer, thanks .. the option to upgrade to 100/90 later, or when driving on high-ways is one of the things I was thinking about.
Going for a full 100/90 setup for the Sumo. Prerana guys are suggesting Mico or Minda. But they say it's better to change the relay also if I want to go for the 75/70.
__________________
Life is Analog. Digital is an approximation.
Old 18th January 2007, 11:58   #137 (permalink)
tsk1979's Avatar
Mico, minda etc., are good companies for relay. Make sure you get the whole wiring kit and not just the relay.
__________________
Reclaimed, wrung dry and recycled....!
Old 19th January 2007, 16:04   #138 (permalink)
functional non show lighting requirements:
I am new member, posting this message for the first time. I have Maruti 800( 97 Model) car. I would like to upgrade headlamps. Can I fit ALto's Halogen 12V 60/55W bulb to my car? Let me know your thoughts.
Thanks.
Geekay
geekay is offline   Reply With Quote
Old 19th January 2007, 17:02   #139 (permalink)
tsk1979's Avatar
Your car already has 60/55W halogens.
Alto does not come with any special lamps, these are standard mico/philips etc., bulbs which are there in all cars with H4 bulbs which include the M800,indica, wagonR. santro etc., too
__________________
Old 20th January 2007, 11:56   #140 (permalink)
jas_mirage's Avatar
Originally Posted by speedzak View Post
Get Philips rally bulbs of 100/90 ratings. they are tend to be illegal but will help a lot and won't cause too much of a trouble to opposite vehicles if the focussing is done correctly. Don't put in anything brighter.
You can get these from any reputed automotive spare shop or accessories shops.
If you have the stock wiring for the Headlamps, it will have to be replaced with a more higher capacity headlamp wiring kit. This can be done from any service workshops or accessories shops.
If you have some spare time, visit Emperor @ Palarivattom, Car shoppe @ Palarivattom, General motor accessories @ Mamangalam or any nearest shop in Cochin.
Wanna know more? Come for our proposed meet. Read about it here: http://www.team-bhp.com/forum/team-b...-2006-a-8.html (Rumble in the Jungle - Kerala Meet)
P.S. Next time, type properly to avoid warnings.
hey zak, thanks man.. did the checking out bit in those shops.. they were pretty good and helpful..
sad i couldn't be there for the kerala meet.. was very busy.. and sheesh.. i myself am logging in after a couple of days.. hopefully the typing is done correctly this time around.. sorry about the typing errors in the earlier post..
__________________
Cheers,
Jasim
SPEED is not an option.. Its a way of LIFE..
jas_mirage is offline   Reply With Quote
Old 22nd January 2007, 17:57   #141 (permalink)
condor's Avatar
Guys, need help here: Got a 200W relay and swapped the 60/55W bulbs with 100/90W. But dont seem to find much difference. One thing is I got Mico / Bosch H4's rated at 2600 & 1700 lumens, IIRC. Are the bulbs the culprit? Or is it something else?
__________________
Old 22nd January 2007, 18:23   #142 (permalink)
tsk1979's Avatar
The best way to find is to fit one old bulb and one new and then park against a wall. You will find out whether output is different.
Do the Bosch H4's say "30% more light" on their packing?
You could also compare with Philips Bluevision, Hella Gold etc., and choose what you like best.
__________________
Old 22nd January 2007, 20:00   #143 (permalink)
condor's Avatar
Tanveer, thanks. The package doesnt say 30% more light. Are there special / different bulbs from Bosch with such packaging ?
But the brightness did look better on the way back today. I will check out the ones you have mentioned. But mean-while, ensuring correct focussing should help.
I also asked the Bosch dealer regarding the 75/70W's mentioned on the Bosch web-site. The dealer didnt seem aware of these. Atleast, it looks like those are not regularly moving products.
__________________
Old 22nd January 2007, 20:16   #144 (permalink)
rahul_intlad's Avatar
Do the Bosch 100/90 W also come with 30% more light feature ,similar to philips vision plus.
Ps:
Power Bulbs
rahul_intlad is offline   Reply With Quote
Old 25th January 2007, 15:12   #145 (permalink)
NikN's Avatar
Default Palio Bulb Type
Just a quick question on what kind of bulbs the palio uses on the low and high beam ? H7s on both ? any idea ?
__________________
Power without control is pointless
NikN is offline   Reply With Quote
Old 25th January 2007, 17:00   #146 (permalink)
tsk1979's Avatar
AFAIK its a H7. Your service manual will have the details.
__________________
Old 25th January 2007, 17:21   #147 (permalink)
hydrashok's Avatar
I guess Palios will need 4 bulbs in total? Because Palios have separate low beam lamps & high beam lamps? I was actually going to ask the same question here today :-)
__________________
Alpine 9887 | TRU Tech STEEL S44 & S500 | Image Dynamics XS65 & CTX6 | Image Dynamics IDQ12 D2V2 | Connection Audison
Old 25th January 2007, 17:55   #148 (permalink)
tsk1979's Avatar
Yes, 4 bulbs if you going for an upgrade.
If you want to upgrade the fogs too, then its like 6 bulbs.
To save costs you can just upgrade the high beams as low beams are pretty adequate on most cars, its the long throw which is an issue.
Make sure you fit in the bulb before buying and observe the throw. Different bulbs have different geometries, so a bulb which does great in a corolla may not be the same in a Palio.
__________________
Old 25th January 2007, 19:06   #149 (permalink)
hydrashok's Avatar
Thanks, TSK1979! I guess I'll stick to just the high beams. And I will fit and try before I buy.
__________________
Old 29th January 2007, 12:06   #150 (permalink)
NikN's Avatar
Awesome , H7s it is then !, thanks guys
__________________
Thread Tools
LED lighting in cars gigy Technical Stuff 86 7th September 2009 19:28
MM550 rear lighting bigman 4x4 Vehicles 24 25th August 2009 11:49
HID lighting query re bulbs whatcanthisbe Modifications & Accessories 19 16th December 2008 19:19
Lighting Upgrade Help Needed NikN Technical Stuff 8 18th February 2008 13:03
Need Help for car lighting mod_to_odd Modifications & Accessories 2 5th December 2007 05:13
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
