Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here!
Thread Tools
Old 11th April 2008, 13:31   #1621 (permalink)
Eddy's Avatar
Originally Posted by thirst4torque View Post
This is the best option in the budget you have. You will need a relay. It will cost around 500 bucks. I have done a similar upgrade on my swift. It was done at the service centre itself and I was told they did not have to cut any wiring. For bulbs go for philips rally 90/100 bulbs. The visibility will improve considerably.Total cost will be around 900 bucks including labour
Thanks. Did you not get new holders ?
__________________
Car is no longer a luxury; parking space is.
Swift VDI(ABS) Sep 07 - 53K Kms
Ford Ikon Flair Sep 04 - 70K Kms
Eddy is offline   Reply With Quote
Old 11th April 2008, 15:05   #1622 (permalink)
thirst4torque's Avatar
No, The supervisor said its not required. Many swift owners on the forum are running the same setup. I picked up the advice from this thread itself
__________________
Regular naps prevent old age, especially if you take them while driving.
thirst4torque is offline   Reply With Quote
Old 11th April 2008, 20:44   #1623 (permalink)
tsk1979's Avatar
For 700 bucks you get a relay+holders(ceramic), and add labor to that the cost should not exceed 850rs, even at an authorized service center.
I got relay without holders initially from Tata service center(concorde blr) for 400rs.
__________________
Reclaimed, wrung dry and recycled....!
Old 11th April 2008, 21:01   #1624 (permalink)
Eddy's Avatar
I am facing a funny issue. The MUL service center guys refuse to do an upgrade to 90/100 bulbs and a couple of accessory shops I talked to (including Driven) say that a relay is not needed.
Can anyone suggest a reliable place where I can get an upgrade done ?
__________________
Old 12th April 2008, 10:40   #1625 (permalink)
vijay shekar's Avatar
Originally Posted by sanchits View Post
guys, only the HI & Low beams xenon H4 is for 25k, all the single beam HID are for 14.4k with 2 year warranty. and i believe they are giving a discount of 5k, if someone from bangalore or chennai can confirm, as these are the contact addresses mentioned on the website.
Hi friends, I tried calling the numbers of Chennai office . But it says Number does not exist. Their factory numbers are very old. I also tried their bangalore numbers but it belongs to some other company. So right now its a dead end. Shall see if I can get to their address.
vijay shekar is offline   Reply With Quote
Old 18th April 2008, 12:48   #1626 (permalink)
DesertKing's Avatar
Default Bright Bulb for my Jeep MM540
Hi, I have recently bought an old jeep MM540 and want to upgrade its bulb for safe night rides. I am not going to fit any extra light on jeep. Need to know which maximum Watt heloxan I can have and how much should it cost. Do I need to fit relay and other holders.
__________________
Papa always emphasized on making my own path, so I bought a 4x4 Jeep.
DesertKing is offline   Reply With Quote
Old 18th April 2008, 13:22   #1627 (permalink)
tsk1979's Avatar
You can go for 100/90W buy you would need a relay and holders kit(Roots costs 700rs).
__________________
Old 20th April 2008, 00:49   #1628 (permalink)
jkdas's Avatar
My friend wants the fog lights to throw white light instead of what he has now. This is a Swift VDi.
We are thinking of doing a DIY by buying a P220i's headlight and using the projector.
What other options do I have?
Can one get a different bulb for fog which will have white illumination?
__________________
Audio, video, disco
Tat tvam asi
Old 20th April 2008, 00:53   #1629 (permalink)
vid6639's Avatar
JKD, yes you can. Find out which bulb the swift uses for fogs. My lancer uses H3 and i just changed them to Osram cool blue 50W fog lamps. They give a lesser yellow light with a blue tinge. looks very cool and they are ok in illumination.
__________________
Let's get "instigated".....
\ / ][ |) `/ [_] "!"
vid6639 is offline   Reply With Quote
Old 21st April 2008, 17:49   #1630 (permalink)
smsrini's Avatar
Originally Posted by smsrini View Post
Hi!
I fit Philips Crystal Vision 55/60 H4 4500k bulbs on my safari. The light is ok for city driving, but high beam is poor.
Had a chance to drive at night on the Golden Quadrilateral between Srikakulam and Vizag, and was running the same Philips bulbs.... and had a change of opinion.
The high beam is pretty effective when there is less oncoming traffic. Probably if the light is white instead of the blue tinge due to the blue ring, it should be more effective...
__________________
"Horn Please OK Tata"
Landrover.....ka bhai, aur ek tall boy!
smsrini is offline   Reply With Quote
Old 21st April 2008, 18:11   #1631 (permalink)
Swift OEM fogs are h8 bulbs.
Avoid 100/90 in there as it will get hazy in no time.
__________________
No fate but what we make!
Old 22nd April 2008, 21:46   #1632 (permalink)
DesertKing's Avatar
Hi tsk1979, just wanted to confirm if the aprox cost INR 700 include the cost of the new helogen bulb. I do not want to have a wrong bargain witht the electrician so wanted to clarify on this.
Thank you.
__________________
Old 22nd April 2008, 23:55   #1633 (permalink)
tsk1979's Avatar
700 is for the relay and holders. Bulb are extra. Good 100/90W bulbs cost approx 350rs a pair. High end ones like bluevisions(which are pretty useless) cost 750 a pair.
__________________
Old 22nd April 2008, 23:59   #1634 (permalink)
Eddy's Avatar
My eternal query... where do I get them in Delhi ?
__________________
Old 23rd April 2008, 00:35   #1635 (permalink)
Default Improve lighting for Skoda Octavia
I am a novice out here. But can someone in this forum can update me what kind of different lighting equipments (in terms of high/low/fog) are there in Skoda Octavia. I am planning to upgrade my Octavia lights and need some basic knowledge and suggestions.
Thanks in advance.
Dibs
__________________
Dibs
dibbasu is offline   Reply With Quote
« Fake K&N Filters | - »
Thread Tools
LED lighting in cars gigy Technical Stuff 86 7th September 2009 19:28
MM550 rear lighting bigman 4x4 Vehicles 24 25th August 2009 11:49
HID lighting query re bulbs whatcanthisbe Modifications & Accessories 19 16th December 2008 19:19
Lighting Upgrade Help Needed NikN Technical Stuff 8 18th February 2008 13:03
Need Help for car lighting mod_to_odd Modifications & Accessories 2 5th December 2007 05:13
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
