| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here! |
| | Thread Tools |
| | #1651 (permalink) |
| BHPian Join Date: May 2008 Location: gurgaon
| Hi all As advised, I visited qutab MASS and explained the mechanic the problem. The problem is as follows Earlier, I got 90/100 installed on my honda city with a relay. The output was a lot better than the stock lights but what used to happen was that with the car turned off as well, the lights woudn't turn off. Reason atributed to this was, faulty relay. Now, that i've got the relay changed, the high beam always keeps getting fused. If i get the right one changed, the left one blows out and if i get the left one changed, the high beam of the right one blows out. Now, what the guy said was: get the alternator checked as there is excessive current being passed. He said that the relay has nothing to do with the blowing out of the tubes. After this comment, I called up honda and told the service advisor what i was told about. He said that this has nothing to do with the alternator and that a relay of around 500Ampere was to be installed. He said none the less, i COULD bring the car in for a check up. Now, I'm totally confused. I got the car serviced about 2K before from honda and had there been a problem with the alternator, wouldn't have that come up during the service? Is the MASS guy taking me for a ride or should i get the alternator checked from Honda and get pinched from them? Please help . All i want is good bright headlights for my weak vision. |
| | #1652 (permalink) |
| Team-BHP Moderator ![]() | Hook up a multimeter to your battery terminals and rev the car. Tell us what the voltage is. In your case it appears that alternator is indeed surging(regulator issue). As for service, nobody checks alternator voltage at service unless its exceptionally high
__________________ .--- ..- ... - - .-- --- -- --- .-. . -.. .- -.-- ... - --- --. --- !! |
| | #1655 (permalink) |
| on a rev it showed a max of 14.38. 14 wasn't quite at idle but a low rev. I'll try putting on halonix but the question would still remain, why are the tubes blowin out. What is the relay there for then? May i mention that the stock tubes dn't blow out and last for over 2 years, while the aftermarket stuff, doesn't even last me 2 weeks. |
| | #1656 (permalink) |
| Team-BHP Moderator ![]() | If your stock tubes are lasting, it could be fakes. Try Halonix and see. The relay is there so that your stock wiring is not overloading. It won't alter your alternator voltage(which seems to be fine). Bulbs are rated for 14.4V, so no issues here.
| | #1657 (permalink) | ||
| Team-BHP Moderator ![]() | Quote:
Might be a faulty battery thats causing excessive current to be drawn - or they screwed up while wiring the relays. Would rule out the faulty battery if your other electrics are working OK.
__________________ Ein bißchen Frieden | ||
| | #1658 (permalink) | |
| Senior - BHPian Join Date: Sep 2007 Location: New Delhi
Infractions: 0/1 (4) | A relay cannot narmally be the cause of bulb failure. If the bulbs are GENUINE and are yet fusing, the problem seems to be with the regulator in that it is allowing voltage spikes through. Quote:
The relay only prevents your 'stock' column SWITCH from having to handle the high currents required for headlamps. This reduces the heat generated inside the switch and prolongs its life. | |
| | #1659 (permalink) |
| Team-BHP Moderator ![]() | @anup. when I said relay. I meant the whole kit since I have seen that most relays in market come with wiring and holders, so the old stock wiring(which is thinner) is not being used.
| | #1661 (permalink) |
| Thank you to all who took time out to reply to my query. The other electronics seem to be working fine and even the low beam is working fine. It's just the high beam which blows off and the pattern is quite erratic. It starts off from the right one and after the right one is replaced, the left one blows out. Seems like the car is conspiring against me not to have 2 full high beams ![]() aah78 - you mentioned about a mess up while wiring up the relay. How do we check if there's a problem with the relay. Some diagnostic perhaps. Maybe the relay itself is ok but the wiring not quite ok? Putting up halonix and hoping they don't blow out would only solve the problem but not help me understand why the problem is there. Also, how do i find out if the tubes are original? some marking to look out for perhaps. Please pardon me for my limited knowledge but this time i'm determined to get to the bottom of this and not be taken for a ride by the pesty mechanics tsk1979 - you mentioned my stock tubes could be fake? tubes put in by the honda personnel at the service station. How can they be fake? to add they are philips tubes. Thank you all for the advice. Appreciate it. Last edited by Zappo : 9th May 2008 at 18:14. Reason: Only 2 smileys per post please. |
| | #1662 (permalink) |
| Team-BHP Moderator ![]() | do you pull that stalk towards yourself frequently and enable high+low filaments together frequently? If so this could be the reason. Otherwise the only way to check is to stick the multimeter at the holder terminals and see what voltage you get.
| | #1663 (permalink) | |
Infractions: 0/1 (4) | Quote:
And a regular multimeter would not be able to report about the voltage spikes getting through. Last edited by anupmathur : 9th May 2008 at 13:50. | |
| | #1664 (permalink) |
| Team-BHP Moderator ![]() | Sometimes while driving on low beam, you can pull the stalk towards yourself and flash high beam. At that stage both high and low beam are on. This is a practice used on highways while flashing truckers. If you do this very often, it can lead to bulb blowout.
| | #1665 (permalink) | |
What I cannot figure out is WHY/HOW. | |
« tachometers
Help Swift Mods »
| Thread Tools | |
Similar Threads | ||||
| LED lighting in cars | gigy | Technical Stuff | 24 | 25th July 2008 21:20 |
| Lighting Upgrade Help Needed | NikN | Technical Stuff | 8 | 18th February 2008 12:03 |
| Need Help for car lighting | mod_to_odd | Modifications & Accessories | 2 | 5th December 2007 04:13 |
| Bullet Upgrade - The Lighting Effect | madbullram | Motorbikes | 6 | 19th July 2007 12:42 |
| Changing Interior Lighting - Octavia | Octavia2 | Modifications & Accessories | 10 | 4th October 2006 22:29 |
