| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here! |
| | Thread Tools |
| | #1669 (permalink) | ||
| Team-BHP Moderator ![]() | Quote:
Eventually these're electronic & mechanical components - which may / may not fail as they please. If your car starts up OK and the normal electricals are functioning as they should, then your alternator can be ruled out as the culprit. Your mechanic wants to install a 500A relay, or do you have 500A relays installed? If so, use a different mechanic. ![]() 30A relays should be more than sufficient for normal operation. Quote:
Direct lines (12V) from your battery (preferable) or alternator - make sure they have inline fuses (20-30A) before the relays, not too far from the source. The headlights will be grounded but check that your relays are too. Make sure they're grounded tightly to the chassis with paint scraped off. Alternate: Get rid off all this wiring mumbo-jumbo and get yourself the new Philips X-treme Power bulbs. They're great. Just had a pair fitted onto my LR3 - 12V, 55W - standard wattage but much brighter than the standard OSRAM halogens.
__________________ A guy can only be called "Annie" so many times before he flips. Last edited by aah78 : 9th May 2008 at 20:39. Reason: alternate | ||
| | #1670 (permalink) |
| Newbie Join Date: May 2008 Location: gurgaon
| Hi again all Tsk 1979 - u got it bull's eye. The tube does blow out soon after or during the FLASHING process but as anupamathur mentioned, how or why? from what i understand is that the tubes blow out when excess of current is passed onto them. With the alternator giving a aah78 - There is just a single relay installed and although i do understand your point of view, what i don't understand is that most of the other cars too have a single relay installed. Has anyone else experienced such frequent blow outs? 2nd installing more than 1 relay, wont' that be a drainer on the battery? PS: I did run the thought across the guy at qutab motors of putting in 4 relays, something which he laughed at [Alternate: Get rid off all this wiring mumbo-jumbo and get yourself the new Philips X-treme Power bulbs. They're great. Just had a pair fitted onto my LR3 - 12V, 55W - standard wattage but much brighter than the standard OSRAM halogens.[/quote] how about putting a picture across. Thanks again for all the suggestions. this surely is fun and informative ![]() |
| | #1672 (permalink) | |
| BHPian Join Date: Sep 2007 Location: New Delhi
| Quote:
![]() Now, please try to figure out the how & why of it. Is this to do with both high & low beams coming on together? Ought not to be. Does it mean the bulbs are inherently of 'poor' quality/design? Like the cold resistance being too low, attracting a heavy inrush of current which blows the filament? | |
| | #1673 (permalink) |
| BHPian Join Date: Jun 2006 Location: Mumbai
| On the High and low beam being flashed simultaneously. I think if the wattage is 90/100, then you stand a chance of fusing the high beam. Not so in a 55/60. Since the glass/gas in the bulb is tuned to receive not more than the high beam (100), when you flash both, it causes the wattage to reach 100+90=190. Sustained wattage at 190 will cause the bulb to fuse. On Philips xtreme, Ive been using it for about 4 months on my NHC. The light is far better than the stock and no issue of relay etc, since it is stock wattage(60/55). Do try it out.. Will solve your problem AFAIK.. Ive heard it is now available in the market. They were plagued with supply problems initially. but that has now been taken care of.. |
| | #1674 (permalink) | |
| [quote] Quote:
![]() Also, when the flash is being used, then the switch turns on which means that the current to the low beam is routed/bypassed to the high beam, so there's only 1 light on at a given point of time to keep the maximum load of 100. If this doesn't happen, then what you are saying would also apply to 60/55W, which means at flashing the total should be 115W and even these lights should blow out but they don't. Your thoughts please M2S | |
| | #1675 (permalink) | |
| Quote:
I would expect that the low beam would be cut-off when flashing. And if there are cars where both can be turned on together, even momentarily, it would be fair to expect that bulb makers enable/design their bulbs to withstand that condition. Can someone please throw more light on this (high beam preferred!)? | |
| | #1676 (permalink) |
| Team-BHP Moderator ![]() | I use 130/110W philips in the left headlight and 100/90 halonix in right. On highways I flash beams, and many times high and low come on together. But unless you do it very very frequently there will not be an issue. In the past 2 years I have had just one high beam blow. Since in married2speed's case, this tube blowout is happening while flashing, it looks to be a relay wiring problem, with terminals fouled up. Good quality relays come with a wiring diagram, so check that out and see if matches. I know a good electrician in Noida, if you want his contact PM me. He will check your car's entire wiring. You can get halonix 100/90 from noida itself and try it out too.
__________________ My DCMAG Portfolio! |
| | #1677 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
![]() Anup ji - Want a demo of this phenomenon? I might be around X - 1 soon!!
__________________ I'm killing time while I wait for life to shower me with meaning and happiness. | |
| | #1678 (permalink) | |
| Quote:
Im however not able to explain how either of the bulbs fuses and not both together. | |
| | #1679 (permalink) | |
| Quote:
______________and Ishan, you are most welcome to drop by if you're ever in the vicinity! ![]() | |
| | #1680 (permalink) | |
| Quote: TSK 1979 - sounds like it's down to the relay issue. I'll come down to noida as soon as I can. Cheers! M2S | |
| Thread Tools | |
Similar Threads | ||||
| Lighting Upgrade Help Needed | NikN | Technical Stuff | 8 | 18th February 2008 12:03 |
| Need Help for car lighting | mod_to_odd | Modifications & Accessories | 2 | 5th December 2007 04:13 |
| Bullet Upgrade - The Lighting Effect | madbullram | Motorbikes | 6 | 19th July 2007 12:42 |
| Changing Interior Lighting - Octavia | Octavia2 | Modifications & Accessories | 10 | 4th October 2006 22:29 |
| LED lighting in cars | gigy | Technical Stuff | 22 | 17th August 2006 07:57 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407
