| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here! |
| | Thread Tools |
| | #1681 (permalink) |
| Senior - BHPian | I plan to instal the new head lights on my Ikon. The mechanic is informing instead of philips make I can go in for GE make. The wattage will be 90/100. Is this equally good or better than Philips. Pls suggest...
__________________ Love your job but Never love your company because you never know when your company stops loving you-NRN |
| | #1685 (permalink) |
| Senior - BHPian Join Date: May 2007 Location: Vadodara
| I have a very important question: I have people screaming at me that 45W bult does give better light than 65W one. 65W will definately get fused early. While the bulb fusing part is understood as the 65W bulb will emit more heat, giving less light is not understood. Can anyone educate me...? The original Cabiler ( 7.7 bhp ) came with 45W Normal ( i..e not halogen ) bulb. I went ahead to fit in 65W M800 bulb. I was warned that connector willl melt and wires will not be able to take the laod. But 65W halogen worked fine for more than one year. Can I do the same with Suzuki Zeus? Here also I am warned that the wiring and the connector will not be in a position to support that 60/65W bulb and will melt. But I am simply not satisfied with the present level of lightning offered by my bike. I want to fit in H4 60/65W. Can I do this. Has anyone earlier tried this? Help ![]()
__________________ EVENTUALLY FATE DECIDES EVERYTHING. |
| | #1686 (permalink) | |
| BHPian | Quote:
45W cannot be brighter than 65W. But in case of a bike, all we have a a small battery and the headlights run off the alternator. In this case simply putting a higher wattage bulb will not gives the desired results. Simply because there is not enough "juice". Yes you can put a 65W and can make it brighter, this will require as some local shop guys call "flashing" the alternator (costs around 700-1000, what i think they does is to increase the power o/p by re-winding, not sure if this is the right term). This can be done, Yes. But I know a buddy of mine who has done this and he burned out 3 - 50/55W bulbs till date on his Yamaha RXZ. Usually this will not require and changes in the wiring and the harness for the bulb unless you plan to use it for extended periods. You can get a relay installed in the circuit -> "Really recommended as this can save a lot of grief as in burned wires and switches" (any good shop can do that) and you will be able to find good quality connector and even Ceramic one's (Hard to find and more difficult to get it fixed) So makes you wonder is it worth all the effort...! Bottom line : its better to use stock. | |
| | #1687 (permalink) | |
| Quote:
And is it true that 65W bulb will give less lumens ? I am ready to risk warranty from day one because under most of the circumstances, they have one word " Normal wear and tear " and they can escape any warranty claim. And changing bulb is for my safety and I need some more technical stuff before going for this. Is there any other way to extract more stuff from alternator?
__________________ EVENTUALLY FATE DECIDES EVERYTHING. | |
| | #1689 (permalink) |
| Senior - BHPian | I have taken out my OE bulbs Phoenix H4U 12V 60/55WE1 2F8 in my Ikon and replaced with GE Megalight plus which promises 60% more light than that of normal bulb. The specs are: 12V 60/55 W P43t-38 H4 E1 2D7. These lights are certainly better than the OE bulbs in my car. They claim "60% more light on the road ahead, longer beam, brighter illumination". Personally the light is brighter and visibility is also good. Couple of pics of the cover is enclosed below. The construction of bulb is same as the OE. But I'am facing one problem. The focussing in my car is not proper. When the mechanic tried to focus but ultimtely gave up stating that the a wire has snapped inside the bulb assy and needs to replace the whole assy. Is this really true or the focussing can be done. Need your inputs.
| | #1691 (permalink) |
| BHPian Join Date: Apr 2007 Location: Bangalore
| Attn Bangy boys! I need a spare "narva white" H3 bulb for my fog lamps. Earlier, I had picked up a pair from JC Road for Rs 500. But now, the same stuff doesnt seem to be available anywhere. Does anyone know where I can pick up a pair? Its a bit urgent as I am moving out to Trivandrum by the end of the month and it'll be a hundred times more difficult to find such stuff there.
__________________ --------------------------------- 2005 Baleno Vxi, 2003 Pulsar 150 1998 Splendor (Still in love with it) |
| | #1692 (permalink) | |
| BHPian Join Date: Dec 2007 Location: Bangalore
| Quote:
Do check as to how long GE has been in the market? Maybe it is a new entrant in this line of business.. But, unless the price is a killer, why don't you just go and try it? You never know. | |
| | #1693 (permalink) |
| Senior - BHPian | I bought it from a local service centre...United Motors, Rajajinagar Indl. Town, Bangalore-10. I have paid Rs.400 (for bulbs) and Rs.50 for installation. Totaling to Rs.450/-
| | #1695 (permalink) |
| Senior - BHPian | If you OEM bulbs were already aligned, dont thing the replacement should have needed an alignment. These seem similar to Osram Silverstar 50%
__________________ Remember, its a machine |
« tachometers
Help Swift Mods »
| Thread Tools | |
Similar Threads | ||||
| LED lighting in cars | gigy | Technical Stuff | 25 | 26th July 2008 21:05 |
| Lighting Upgrade Help Needed | NikN | Technical Stuff | 8 | 18th February 2008 12:03 |
| Need Help for car lighting | mod_to_odd | Modifications & Accessories | 2 | 5th December 2007 04:13 |
| Bullet Upgrade - The Lighting Effect | madbullram | Motorbikes | 6 | 19th July 2007 12:42 |
| Changing Interior Lighting - Octavia | Octavia2 | Modifications & Accessories | 10 | 4th October 2006 22:29 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
