Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 18th May 2008, 22:45   #1696 (permalink)
vid6639's Avatar
Rs.50 for installing headlight bulbs! That's crazy. It's as easy as changing a bulb at home. Unscrew, remove, put back new, screw and connect. Voila.
They are priced a little more than Osram Silver star which costs Rs.350 a pair.
__________________
\ / ][ |) `/ [_] "!"
(o.o)
( X )
This is Bunny. Copy Bunny into your signature to help him achieve world domination.
vid6639 is offline   Reply With Quote
Old 18th May 2008, 23:21   #1697 (permalink)
Jaggu's Avatar
Vid try it in a iKON and you will run to the workshop, after bandaging the bleeding hands. 50 Rs is very cheap if you ask me, for labor.
Take night shots of the light from inside the car, that will give us some idea about the lights.
Aligning, well there are two screw/bolts on each of the headlight units (If i remember 10 size spanner or a really short length star screw driver) will help. First park the car on a dark street and figure out which side is out of alignment, cover each beam at a time, this will give you an idea. Then park the car with beams facing a wall and slowly adjust the beams in the desired direction and recheck on the street.
Oh yeah for accessing up and down bolt/screw i had to get underneath the car and then use the spanner, yes its a difficult task. I guess a short stub star screwdriver will ease this to a great extent.
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 18th May 2008, 23:28   #1698 (permalink)
Rs.50 for fixing! Seems to be a bit too much.
Snaronikar, did you try with one OE and one GE bulb and check the difference?
HappyWheels is online now   Reply With Quote
Old 19th May 2008, 10:44   #1699 (permalink)
Vid, any suggestions onto, where to pick the Silverstar in the south of Bglr ?? any shopnames ??
__________________
Remember, its a machine
dadu is online now   Reply With Quote
Old 19th May 2008, 11:23   #1700 (permalink)
Would this work for Swift.
I am looking for a upgrade to my VDi without "large" difference to wattage.
Just concerned about damaging electrical stuff...
Any shops towards Indiranagar/Airport Rd would be of great help.
__________________
Swift VDi - Apr 2008
Alto LXi - Jun 2004 - Apr 2008
sriturl is offline   Reply With Quote
Old 19th May 2008, 11:44   #1701 (permalink)
sanjaymugur's Avatar
OSRAM|Consumer|Automotive Lighting|Products|Headlights|NIGHT BREAKER|NIGHT BREAKER Family|index
NIGHT BRAKER now available in bangalore, H4 costs 1600 per pair, available in JC road opposite to mahaveer store.. dont know the shop name, it is in 1st floor, authorized osram product distributor..
FIAT, always...
sanjaymugur is offline   Reply With Quote
Old 19th May 2008, 11:59   #1702 (permalink)
tsk1979's Avatar
Avoid those +80% or 90% bulbs. In indian conditions where you do frequent high low on highways, the life of such bulbs is very less. You would need to replace a bulb after around 100 nights of usage.
__________________
Reclaiming.....!
Old 19th May 2008, 12:17   #1703 (permalink)
vid6639's Avatar
The distributor is Nilesh Gandhi - 9880896117. Ask him for directions to the shop. It's on JC road on the first floor. It's on the road towards Lalbagh gate and not towards town hall side.
__________________
(o.o)
( X )
Old 19th May 2008, 12:33   #1704 (permalink)
snaronikar's Avatar
Yes, I have tried with one GE bulb and another with OE. Infact the service centre guy himself showed this and there was a difference which was noticable.
@ Jaggu: Thanks for the tips. Will try to do the same.
@ others: I felt Rs.50 was OK. Will take care of this from next time.
__________________
Love your job but Never love your company
because you never know when your company
stops loving you-NRN
snaronikar is offline   Reply With Quote
Old 19th May 2008, 17:41   #1705 (permalink)
Raajiv's Avatar
Hi Guys,
I have a i10 and the lighting is really poor on both city roads and highways.I am planning for a normal upgrade.Which set of Bulbs to go for and what other things are needed for the instllation.Please suggest a safe upgrade which would not cause any problem.
Would like to know apporoximately the bulb costs and the cost for total installation.
__________________
Acheivement is almost AUTOMATIC when the goal becomes inner commitment
Raajiv is offline   Reply With Quote
Old 19th May 2008, 17:51   #1706 (permalink)
n_aditya's Avatar
Originally Posted by Raajiv View Post
Which set of Bulbs to go for and what other things are needed for the instllation.Please suggest a safe upgrade which would not cause any problem. Would like to know apporoximately the bulb costs and the cost for total installation.
Raajiv, go for Philips 100w/90w bulbs. They cost around 250 bucks a pair IIRC (maybe lesser). Along with that a wiring kit (from Lucas) should cost around 500 bucks. Installation another 100 - 200 bucks.
you can procure the above mentioned at Mahavir on G.P. Road. Total cost with bulbs and wiring kit with installation wont cost 800 bucks to 1k max.
__________________
RIP Tootie !!! Missing you terribly.
Old 20th May 2008, 04:38   #1707 (permalink)
amitverma's Avatar
Hey guys. I need to switch to HIDs on my Palio 1.2. as i have read some bit on ceramic holders, i am curious to know what are these and from where can i get those in delhi?
and also, the market is flooded with fake chinese HIDs? how do i spot a genuine product from a fake?
__________________
GM need not make a Hummer Hatch - Fiat Already Made PALIO
amitverma is online now   Reply With Quote
Old 21st May 2008, 16:17   #1708 (permalink)
Can anyone suggest some easy way to remove the glass from the body of the headlight? I've opened one, but its so difficult as they are glued together with some sort of sealant.
kaynmantis is offline   Reply With Quote
Old 21st May 2008, 16:26   #1709 (permalink)
amitverma
You can get bosch HID Kit for around 8k-10k. Don't know if they are fake or genuine. Check out your local dealers or you can also get some details on eBay India - Online Shopping Mall: Free Auctions, Shop/Buy/Sell Mobiles, Cameras, Apparel, Computers, Bollywood Clothes & Indian Products
Old 22nd May 2008, 04:44   #1710 (permalink)
amitverma's Avatar
but i still need to know about the ceramic holders before i go for the xenons.
__________________
Thread Tools
LED lighting in cars gigy Technical Stuff 37 22nd September 2008 11:03
HID lighting query re bulbs whatcanthisbe Modifications & Accessories 6 6th September 2008 10:46
Lighting Upgrade Help Needed NikN Technical Stuff 8 18th February 2008 12:03
Need Help for car lighting mod_to_odd Modifications & Accessories 2 5th December 2007 04:13
Changing Interior Lighting - Octavia Octavia2 Modifications & Accessories 10 4th October 2006 22:29
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
