Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 10th June 2008, 12:19   #1786 (permalink)
thirst4torque's Avatar
Originally Posted by spadival View Post
They are right next to the firewall. Now I have moved them as close to the battery/fuse box as possible, because thats possibly the driest area in the engine compartment. I will also check if water is leaking from the top near the firewall.
You have got me worried now!The relays in my car are also placed near the firewall
But the water should not have reached there in the first place right?
__________________
Living in sanity results in insanity
thirst4torque is offline   Reply With Quote
Old 10th June 2008, 12:47   #1787 (permalink)
gopinathann's Avatar
Originally Posted by funkydevil View Post
hey gopinathan,
Dont they have a shorter life as compared to the stock lamps?? How long do you have em on, any problems so far??
I had Crystal vision for the past 10 months, still working, however I wanted more light and went for Narva 100/90. It has been 2 weeks I have put them, have to see how long it works. I think if we use more low-high beam for signalling it will blow out soon.
__________________
Why do they call it rush hour when nothing moves?
_________________
SX4 ZXI - 2007
gopinathann is offline   Reply With Quote
Old 10th June 2008, 14:11   #1788 (permalink)
smsrini's Avatar
Originally Posted by kdeepakk View Post
Can i use Osram Night breaker for my safari 2.2? Do i need to put any relay?
Do i need to change the bulb holder? Please somebody message me fast cos i am going to buy one on saturday.
I have spoken to the dealer and its around Rs.1600/-
Deepak
I believe, nightbreaker is also available in 60/55w so you dont have to change the holders.
__________________
"Horn Please OK Tata"
Landrover.....ka bhai, aur ek tall boy!
smsrini is offline   Reply With Quote
Old 10th June 2008, 16:25   #1789 (permalink)
spadival's Avatar
Not to worry. I feel there is a slight water leak near the firewall in my car. Will test it out today by pouring a bottle of water on the windshield.
spadival is offline   Reply With Quote
Old 11th June 2008, 16:01   #1790 (permalink)
razor4077's Avatar
Just fitted 90/100 Philips Rallye with a relay on my Lancer. Switched from the previous Philips X-treme Power (+80%) bulbs. The older bulbs were pretty powerful and provided good lighting (much better than the stock bulbs), but the spread wasn't so good, and lighting felt inadequate on highways and other ill-lit stretches of road.
The new bulbs are super bright with great spread and throw. My initial reaction is positive - will need to drive it on a highway at night to truly test them out. Will do so soon and post an update here.
razor4077 is offline   Reply With Quote
Old 11th June 2008, 16:30   #1791 (permalink)
90/100 Philips Rallye are good both in the city and on highway. The high beam is good enough to command respect from most of the oncoming vehicles who would not even bother if you had stock lights.
Maibaa is offline   Reply With Quote
Old 12th June 2008, 12:22   #1792 (permalink)
Default Found this on the net
BMW has thermal Night vision camera on them
its really good..
regards
Jaxy
Jaxy is offline   Reply With Quote
Old 12th June 2008, 12:57   #1793 (permalink)
razor4077's Avatar
Looks like something out of Splinter Cell! Very cool indeed, and am sure it would be a useful gadget to have. But, that camera itself looks very vulnerable. Would always run the risk of getting damaged in our cities. And I bet it costs a bomb!
Old 12th June 2008, 21:26   #1794 (permalink)
udit78's Avatar
I wish to replace my existing headlight bulbs in my Esteem with the white xenon bulbs, can i do that easily? Then why are there so costly kits available for such lights too, when you can just change the bulbs.
Need help of the gurus.
See the bulb here - eBay India: POWERFULL WHITE LIGHT HALOGEN BULBS, H4 TYPE 100/90W (item 110261137884 end time 18-Jun-2008 13:06:01 IST)
__________________
wwwdotuditsawhneydotcom
89' Maruti 800 - stolen June '06
97' Maruti Esteem Lx
04' Wagon R
06' - City VTEC
udit78 is offline   Reply With Quote
Old 12th June 2008, 22:08   #1795 (permalink)
Shakensoul's Avatar
Originally Posted by udit78 View Post
You are confused between the HID xenon light and the normal white light.
HID stands for high-intensity discharge, the technical term for the electric arc that produces the light. Automotive HID lamps are commonly called 'xenon headlamps', although they are actually metal halide lamps that contain xenon gas. The xenon gas allows the lamps to produce minimally adequate amounts of light immediately upon startup and speed the warmup time. If argon were used instead, as is commonly done in street and other stationary metal halide lamp applications, it would take several minutes for the lamps to reach their full output. HID headlamps use a small, purpose-designed burner which produces more light than ordinary tungsten and tungsten-halogen bulbs. The light from HID headlamps has a distinct bluish tint when compared with tungsten-filament headlamps. The high intensity of the arc comes from metallic salts that are vapourised within the arc chamber.
To install the HID light, you need the complete kit which is expensive.
You can replace the headlamp bulbs with the white bulb, or a more bulb with more power, which is done at any car accessories shop.
Shakensoul is offline   Reply With Quote
Old 13th June 2008, 02:45   #1796 (permalink)
furioussphinx's Avatar
Guys, I need your advise asap. Am in qatar right now and planning to carry some goodies back home for my little zen. Regarding the headlight bulbs, am thinking if it is ok to take white bulbs with the rating 100/90??? Am not going to talk about brands like philips/osram/bosch etc as beggers cant be choosers now. Am scared if the high rating will burn my reflector. Mine is the old 2001 model zen. So can I go for 100/90 rating? Another thing, what is the pin/socket for the bulb? I mean, are the bulbs universal or differ with cars?
Query 2, am planning to buy strobes too, to use it for dipper mostly. So which would be the points to be kept in mind when shopping for it?
just did a quick research on this in this thread, and now I endup in more confusion. Am a total novice at this. Does the bulb include both high andlow beam or they are two different bulbs?
I want a cool bluish tinged white light. I dont want a blue colour but a tinge of it. So now are those bulbs available in more than 100/90 rating? I want to the brightest ratingI can go for. At the sametime,I dont want to burn anything.
When I buy the bulbs, should I buy a relay and stuff? Or the bulbs are just a plug and play?
Am very confused, I want to end up having a much brighter white light with blue tinge instead of the regular stock yellow. Guide me guys, am going shopping tom for the bulbs. I dont want to end up blabbering **** and getting duped.
Note from mod: Do not type in all bold, it makes reading difficult
__________________
...Go Hard or Go Home...
furioussphinx is offline   Reply With Quote
Old 13th June 2008, 14:09   #1797 (permalink)
lamborghini's Avatar
Hey guys,
I have a question. I want to get neon lights fitted on our car. But I am just scared. As it is a big investment (dad still has to agree. I want to have full research before going to him), I was wondering how they would look on a stock Fiesta and whether they are suited to indian conditions. I mean would they break? What are the chances of anything going wrong? I was looking at the Gold series from Streetglow.
__________________
¢нєєяѕ
ℓαмвσ
lamborghinirules@gmail.com
lamborghini is online now   Reply With Quote
Old 13th June 2008, 15:36   #1798 (permalink)
razor4077's Avatar
Hey furioussphinx,
First, would appreciate it if you didn't type in bold unless you want to highlight some specific point.
Now for you queries,
- If you go for 100/90 rating, you will have to get a relay kit to account for the higher wattage. I am not sure about the Zen in particular, but these bulbs work fine with most cars without affecting the reflectors. Some Zen owners can chip in here...
- The wiring kit I got had a holder with it, which can withstand the extra heat generated by the bulbs. You can get ceramic holders if your kit doesn't contain holders.
- Pin/socket - the Zen most probably uses H4 halogens (Zen owners?), and these have the same kind of socket, regardless of the car.
- High beam & low beam are in one bulb - 100/90 means 100W high beam, 90W low beam
- No idea about strobes, but pretty sure you cannot use it as a "dipper"
- White/blue tinge bulbs are available. This thread lists many of them - example: Blue Vision, Diamond Vision etc. Most of these are regular 60/55 bulbs though, in a different colour, so you should keep an eye open for that.
- Some have used 130/100 bulbs - these are probably the brightest you can fit, but they might be overkill.
- This, and some other threads mention prices, so you can use them as a reference when you go shopping.
Hope this helps. Let us know what you get.
Old 14th June 2008, 23:51   #1799 (permalink)
I recently went for the Narva 100/90 with Roots relay. When I flip the high beam to signal opposite vehicle, the light stays on. Showed it to the Maruti dealer, he said that the relay is the problem and nothing wrong with the switch. I have to go to the shop where I bought for a replacement. I thought ROOTS relay was good and insisted him to put that. Actually he gave the imported kit and I asked him to change the relay to ROOTS, that caused me the problem.
__________________
_________________
SX4 ZXI - 2007
Old 16th June 2008, 15:00   #1800 (permalink)
nirav_j's Avatar
Question burnt OHC headlights issue , and HID suitability ...
Hello guys, i have an OHC 1.3 exi (Type 1), i had bought it used and its headlights came with bullet like holes @ the focus of the beam.
I replaced the headlights, (the plastic) with new ones, they lasted for around 6-8 months and even these are melting around the focus are of the headlight, and developing into bullet holes, (( size of a 50 paise coin hole )) on the headlight.
I have checked the bulbs, and they are 130/100. I guess the high beams the culprit @ 130W and am thoroughly dissatisfied with the low beam, so was planning to install HIDs.
Anyone here installed HIDs on the OHC type 1?? and could someone please guide me as to the wattage of the HID and its effect on the headlights.
I have installed a 55W HID on my karizma, its an H4 bulb with high and low beams and 6000K, illuminations just great, and as of now i havent had any reflector getting burnt issues, but i havent used it to a great extent @ night. So will have to see how it performs @ longer night rides.
@ my OHC : i want to make sure that the plastic in the headlight doesnt burn away even more after putting the HIDs compared the the previous halogen bulbs, would appreciate any pointers in this regard.
Note from the Team-BHP Support : Please take the time to use proper punctuation as per Team-BHP rules. Avoid...typing...like...this. Thanks.
Last edited by Jaggu : 16th June 2008 at 15:27. Reason: dot dot dot, phew thats hard work!
nirav_j is offline   Reply With Quote
Thread Tools
LED lighting in cars gigy Technical Stuff 31 18th August 2008 15:48
Lighting Upgrade Help Needed NikN Technical Stuff 8 18th February 2008 12:03
Need Help for car lighting mod_to_odd Modifications & Accessories 2 5th December 2007 04:13
Bullet Upgrade - The Lighting Effect madbullram Motorbikes 6 19th July 2007 12:42
Changing Interior Lighting - Octavia Octavia2 Modifications & Accessories 10 4th October 2006 22:29
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406
