Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here!
Thread Tools
Old 4th August 2008, 13:05   #1981 (permalink)
pshyamsundar's Avatar
tsk,
I already have silverstar on my swift. It is useless when it is raining and when it is night time. That is the reason i want to go for 100/90. I see a lot of postings that Narva is good
questions:
You have suggested buy from Philips distributor can you tell where is the distributor in Bangalore?
Where can I get (reliable original) Narva bulbs in bangalore?
Some have suggested Green tracks. Where is it in bangalore?
pshyamsundar is offline   Reply With Quote
Old 4th August 2008, 13:16   #1982 (permalink)
govigov's Avatar
Originally Posted by shazikon View Post
Has any one used this?? Is this available in india??
sorry for quoting an old post... but really intrested in these.... how can i procure these? is there a website from where i can order online? went to zetecs.com but their market place is not available.
FORD FIESTA MK5 BLACK ANGEL EYE PROJECTOR HEAD LIGHTS on eBay, also Head Lamps, Lights Lighting Accessories, Car Tuning Styling, Cars, Parts Vehicles (end time 12-Aug-08 00:37:41 BST)
found these on ebay... is some one coming from uk ?
__________________
Alpine ida X 200 | Blua GTA 450 | Bull CS525.75 | Velocity VXS 12
'00 Ford Ikon 1.6 ZXi
'05 Pulsar 150
govigov is offline   Reply With Quote
Old 4th August 2008, 13:19   #1983 (permalink)
tsk1979's Avatar
Originally Posted by pshyamsundar View Post
tsk,
questions:
1. Pick up any autocar india, they have Philips regional office numbers
2. Narva have blue coating which reduces light, so if you want more light avoid blue coated bulbs. Moreover cops will also stop you
__________________
Reclaimed, wrung dry and recycled....!
Old 4th August 2008, 14:39   #1984 (permalink)
abhik's Avatar
For what?
They could never make out the difference between a 65/55W or a 100/90W without looking at the bulbs directly. And the blue coated ones dont give out brightness of an HID light, so dont understand why the cops would stop anybody, they have never stopped me! I am using Hella 100/90W with yellow light and previously Phillips Bluevision 100/90W bulbs with a slight blue tinge and white light.
__________________
AbhiK
D shortest way b/w 2 points is a straight line…what's the fun in that?
Straights R 4 Fast Cars, Turns R 4 Fast Drivers!
abhik is offline   Reply With Quote
Old 4th August 2008, 15:11   #1985 (permalink)
nithz's Avatar
cananyone tell me is it safe to use 130/100 doesnt it damage the plastic glasses of the headlight unit (i was told so by a local electrical fellow)?i am currently runnin on 90/100 the visibility with this light is not upto the mark for me,and what are the things i need to change before putting this?i currently have relay for this ,and whats the difference btw h4&h7?is it a direct plug n play for h4? need help
__________________
when u drift u feel the rush
nithz is offline   Reply With Quote
Old 4th August 2008, 15:46   #1986 (permalink)
tsk,
Are you suggesting that philips is better than Narva or Osram. If so which one of the philips should I pick up. (crystal vision, diamond vision, rallye) etc
Old 4th August 2008, 16:00   #1987 (permalink)
theMAG's Avatar
Given an option, steer clear of the 130/100. Your local electrical fellow is right, and even assuming plastics hold up, there are cases where the bulbs dont. If you arent satisfied with 100/90, look at adding fog lights or HIDs.
__________________
If I hold a hammer, everything looks like a nail.
Old 4th August 2008, 16:06   #1988 (permalink)
ankitahuja's Avatar
What car do you want to run these bulbs on? Lot of members are using 100/130 on their rides without much complications.
I feel 100/90 bulbs produce sufficient lighting, check if your head lamp assembly requires replacement (if they are balcked out or reflector already damaged). Post some day light pictures of HL.
They fit different, H4 are double filament bulbs with high and low beam in one. H7 are different. All replacement bulbs are plug and play. Google them!
__________________
åĐïğŧėđ Tŏ Ÿoů...
Old 4th August 2008, 17:25   #1989 (permalink)
Has anybody over here used bulbs from WUERTH ?If so could you post the reviews.
D.V.R is offline   Reply With Quote
Old 4th August 2008, 23:13   #1990 (permalink)
Originally Posted by Epic View Post
Hi Souljah!
Are the lighting in ur headlamps and fogs HID or halogen bulbs?
The picture I posted earlier is with only the fogs on.
Low Beam - H1 6000k
High Beam - H1 Halogen
Fog Lamps - H8 4300k
The build quality of the lumax fogs arent all that great.
__________________
No fate but what we make!
Old 5th August 2008, 15:58   #1991 (permalink)
abhik's Avatar
Your Honda desparately needs a replacement or HIDs since your headlamps are "SMOKED"-quite literally.
__________________
AbhiK
Old 5th August 2008, 16:10   #1992 (permalink)
suren181's Avatar
Check the given link to my post with pics, you would realise that it is harmful for the reflectors and do damage them.
http://www.team-bhp.com/forum/modifi...tml#post905418 (Auto Lighting thread : Post all queries about automobile lighting here)
__________________
1957 Fiat Elegant,
2008 Verna,
1963 Vespa,
1982 Rajdoot GTS (Bobby)
2005 Bajaj Discover DTSi
suren181 is offline   Reply With Quote
Old 5th August 2008, 17:45   #1993 (permalink)
ultimatechamp's Avatar
Smile
can anyone tell me is it safe to use 130/100 doesnt it damage the plastic glasses of the headlight unit (i was told so by a local electrical fellow)
I am using Philips Rally 130/100W bulb since last few months with separate relays for each bulb and ceramic(bakelite) holders. Touch wood,no problems till date.
I have used the same type bulbs in my previous M800 for >3yrs.Never had a problem.
Its true the 130/100W bulbs generate enormous amount of heat,but you have to have properly fitted individual relays,good wiring harness capable of carrying extra load and maintain the reflectors as well.
See my Gallery page,the lights are there.
Happy driving!
__________________
Ice,Ice....My Baby !!
[Pearl silver Zen Estilo Lxi,May 2008]
[Moonbeam silver M 800,March 2003 -Sold]
ultimatechamp is offline   Reply With Quote
Old 5th August 2008, 18:15   #1994 (permalink)
tsk1979's Avatar
Many people do not find problems with 130/110W. but some do.There is a 15-20% risk that the 130/110 will foul the reflector, so if you are willing to take the risk, you can go ahead.
__________________
Old 5th August 2008, 18:22   #1995 (permalink)
bblost's Avatar
A thin layer of dirt and grime on your head lamps will reduce the brightness.
Dirty windscreens will reduce visibility to a great degree.
Try keeping them as clean as possible.
Maybe you will not really need such high power lights.
just my two very annoying cents.
__________________
Ever catch yourself listening to a nice song on the radio and dedicating it to your car.
Thread Tools
LED lighting in cars gigy Technical Stuff 86 7th September 2009 19:28
MM550 rear lighting bigman 4x4 Vehicles 24 25th August 2009 11:49
HID lighting query re bulbs whatcanthisbe Modifications & Accessories 19 16th December 2008 19:19
Lighting Upgrade Help Needed NikN Technical Stuff 8 18th February 2008 13:03
Need Help for car lighting mod_to_odd Modifications & Accessories 2 5th December 2007 05:13
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
