| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here! |
| | Thread Tools |
| | #1996 (permalink) | ||
| BHPian | Quote:
![]() Quote:
I have also seen headlight assemblies that have small heat outlet pipes to prevent them from melting or getting damaged. Can anyone comment whether it is an OK option to drill a hole or 2 in a sealed HL assembly to disperse heat? I know there is a problem of dust/moisture but if the bulbs are 100/130, the moisture will vanish in seconds due to the heat.
__________________ • åĐïğŧėđ Tŏ Ÿoů... Last edited by ankitahuja : 5th August 2008 at 22:47. | ||
| | #1997 (permalink) | |
| BHPian | Quote:
![]() That would be surely curtains for any head-lamp set-up! Best options are to switch off your head-lights when you dont require them,like in well-lit streets,when you are standing at some red-light,etc. Dont keep flashing between high and low beams constantly. Check more often than required for any signs of wear 'n tear. Or one can fit either of these --> ![]()
__________________ Ice,Ice....My Baby !! [Pearl silver Zen Estilo Lxi,May 2008] [Moonbeam silver M 800,March 2003 -Sold] | |
| | #1999 (permalink) |
| BHPian Join Date: Nov 2007 Location: *****
| In pune there is a guy who is selling a chinese company light which has 140/180w,should i buy it because as it is, it's totally illegal+chinese company so may not last for long
__________________ TEAM SUZUKI:Way of Life, |
| | #2001 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
Would it really be 140/180W? And what about the holders for it? Most wire/relay kit support only upto 300W max.
__________________ Audio, video, disco Tat tvam asi | |
| | #2002 (permalink) |
| BHPian Join Date: Nov 2005 Location: Mumbai
| Am happy using the Philips 100w with pnp relay and ceramic wire coupler. so far its good. I down graded from 130w as it sort browned my reflector caps. on my swift vdi.
__________________ A nuclear bomb can shake my mortal frame, but nothing will stir my moral soul. |
| | #2003 (permalink) |
| BHPian Join Date: Sep 2007 Location: Noida
| i need to improve my cedia in the lighting department. the lights dont seem to be sufficient for me at least. i have gone through some of the posts but would really appreciate responses. initially i had thought of getting osram's/philips but the wattage being the same there wouldnt be too much of a difference (logically?). and therefore now HID's seem to be the answer. The car uses H4 60/55's (single lamp, unlike my dear palio's double lamp which i am so used to as far as the lights are concerned and therein it seems lies the problem). now to the questions: - the HID would be better for low beam...am i right? (since i do highway, both hi/lo xenon's may not make sense). pls. correct if i am wrong. - but would a xenon lo beam bulb also have a halogen hi beam? - should the wattage of the xenon be 60/55 (since the current halogens have those wattage) ? with type 6000K i suppose, since 4500K are hard to find? - for switching to the xenon HID: should it be a projector setup or will the current reflector based setup suffice? - the HID setup would require additional wiring bypassing the oem wiring, harness, ballast, and holders? - finally, from where in delhi/NCR to get the Xenon's from and which brand? (if anyone has dealer contact numbers pls. let me know, thru a PM if you please.). i only need to get the kit. the installation would get done from the dealership...to be on the safer side of warranty issues
__________________ GTX '03 Cedia Sports '08 |
| | #2004 (permalink) |
| Senior - BHPian | a projector setup would be better. try and get the projector setup. most HIDs are 35w. in the projector setup i think there is a separate bulb for high and low and otherwise in h4 HIDs the bulbs moves to give the high beam effect. 6000k would be fine but 4500k would give better visibility. |
| | #2005 (permalink) | |
| BHPian | Quote:
Then read this link here IPF light bulbs H4 Super Low Beam XX series headlight bulb upgrade They even have a 150/190W option ,but in actuality these are 60/80W bulbs with coatings and some have 'double-tube' inside them,which allegedly gives 'extra performance' !! ![]()
__________________ Ice,Ice....My Baby !! [Pearl silver Zen Estilo Lxi,May 2008] [Moonbeam silver M 800,March 2003 -Sold] Last edited by ultimatechamp : 7th August 2008 at 01:07. | |
| | #2006 (permalink) |
| BHPian Join Date: Oct 2007 Location: Mumbai
| Do anybody know where can i get Osram headlamps in Mumbai. I am desparately looking for them but most of the shops have Philips or some chinese brands with them. i stay in Dadar area in mumbai so anyone around that area. |
| | #2007 (permalink) | |
| Quote:
__________________ TEAM SUZUKI:Way of Life, | |
| | #2009 (permalink) | |
| BHPian | Quote:
Team-S,if you look carefully to the left of the picture,outside the red circle,it says that it is an 60/80W bulb,which claims to give out light in the range of 4100K! ![]()
| | #2010 (permalink) | |
| Senior - BHPian | Quote:
65/50 would be better than these unknown 140/180's ![]()
__________________ No fate but what we make! | |
| Thread Tools | |
Similar Threads | ||||
| LED lighting in cars | gigy | Technical Stuff | 86 | 7th September 2009 19:28 |
| MM550 rear lighting | bigman | 4x4 Vehicles | 24 | 25th August 2009 11:49 |
| HID lighting query re bulbs | whatcanthisbe | Modifications & Accessories | 19 | 16th December 2008 19:19 |
| Lighting Upgrade Help Needed | NikN | Technical Stuff | 8 | 18th February 2008 13:03 |
| Need Help for car lighting | mod_to_odd | Modifications & Accessories | 2 | 5th December 2007 05:13 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
