| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here! |
| | Thread Tools |
| | #2071 (permalink) |
| BHPian | guys a couple of quick questions. Can a 100/130 with relay be fitted easily to the stock unit of a lancer or its better to stick with 90/100 for an upgrade from 55/60W stock bulbs. My main concern is heat messing up with the lens and reflector. My lancer doesn't have clear lenses so makes sense to go for yellow lights ratehr than whiter ones like Osram night breaker. Which one to go for ? Osrams or Philips ?
__________________ 2003 Mitsubishi Lancer GLi - 94K 2002 Bajaj Caliber UG - 18K 1991 Bajaj Chetak 12V - 85K |
| | #2072 (permalink) |
| Team-BHP Support ![]() | leadf00t 130/100W has a "luck issue also". For example my indica earlier had 130/110W, and there was slight reflector damage as well as holder damage since it was designed for 100W max. Later due to a small accident, the LHS headlight got replaced. I am using 130/110W in LHS(new headlight) and 100/90 Halonix in RHS. There have been no issues with this till now. So there is a small chance that reflector can get damaged. Irrespective of that make sure you get a relay with bakelite holders which can handle the high heat of 130W
__________________ Reclaimed, wrung dry and recycled....! Last edited by tsk1979 : 29th August 2008 at 18:55. |
| | #2073 (permalink) |
| BHPian | thanks Tsk In that case i think its better to stick to 90/100. I don't want to end up with burnt reflector in search of brighter light. what bulb would you suggest in 90/100W? OSRAM/Philips ?
| | #2074 (permalink) |
| Team-BHP Support ![]() | Different reflectors give different light patterns for different bulbs. Try Halonix/Philips/Mico/Bosch etc., before buying. Some reflectors like OHC are very suited to Hella Gold(Don't ask me why!)
__________________ Reclaimed, wrung dry and recycled....! |
| | #2075 (permalink) |
| Distinguished - BHPian ![]() | But the bulbs are a pain! Blew out 2 set in 4 months & finally switched to Halonix which might not be as good but have been infinitely more reliable & less than half the cost!
__________________ Reminds me of my safari in Africa.Somebody forgot the corkscrew and for several days we had to live on nothing but food and water. |
| | #2076 (permalink) |
| BHPian Join Date: Dec 2007 Location: Greater Noida
| I have just upgraded the headlight bulbs of my new GETZ D to 100/90. Used Halonix bulbs with a relay. Unfortunately as the changeover happened during broad daylight, it was not possible to check the complete functionality of the headlights. On the same night, I have noticed two issues: 1. Although the light intensity has improved over the stock bulbs, the headlight has started to spray the beam all over the place. ![]() 2. The mechanic seem to have messed up the high & low beam connections as it is now functions the opposite way, i.e. - pulling the lever close to steering engages high beam & pushing it away puts in on low beam. ![]() Any idea what could be the solutions to both the problems?
__________________ The first Foxtrot Azure LINEA on TBHP GETZ CRDi 2008 SCORPIO 2005 SANTRO 2004 - sold ENTICER 2002 M800 1998 - sold |
| | #2079 (permalink) |
| BHPian Join Date: Oct 2005 Location: Dublin, OH
| Hi Guys, wanted to know that where can I find original Phillips Bi Xenon HID KIT in NCR. Heard that the prices are slashed to around 9K now. Plan to get it installed in my Getz D. Would be glad if someone can guide me, thanks in advance.
__________________ Getz CRDi 08'/ Safari Dicor 3.0L 06'/ Ikon Flair 05'/ Vitara 2.7L V6 "We all have ability. The difference is how we use it." |
| | #2081 (permalink) | |
| BHPian | Quote:
I bought it from ebay and it looks good and original.
__________________ There are three types of people in this world: 1. Who make things happen 2. Who watch things happen 3. Who wonder what happened. | |
| | #2082 (permalink) | |
| Senior - BHPian Join Date: Aug 2008 Location: Bangalore
| Hi, These are Xenon lamps that you are referring to.. Cheers, gpa Quote:
| | #2084 (permalink) | |
| Hi Bhaskar, To sort out the problem of your headlight switch working the opposite, suggest you check the wiring of the modifications done. The mechanic could have the connections reversed which is why your lights function in the way thet do now. This once happened to me when I changed a blown relay in my Maruti 800, but luckily I checked it before leaving the service center. Tip: Always check the functioning of the lights (low/high beams) after you have changed the stock bulbs/wiring or relays. Cheers, Pritish Quote:
| | #2085 (permalink) |
| Hi, You can get the entire range of original Philips auto bulbs in Bangalore as an alternative to ebay Contact AK Traders on JC Road. The gentleman by name Mr. SK Mittal has the entire range of Philips bulbs. He's a genuine importer of Philips bulbs and I have bought two sets of Philips bulbs from him and vouch for the quality of his products. Mr. Mittal has good knowledge on bulbs for cars. He will recommend a better version along with the appropriate relays as well if you tell him exactly what you are looking for. You sure will find what you are looking for here and can even get a discount Here are his contact details AK TRADERS PH: 4114-3199, 4114-3958 # 22/23, 1 FLOOR, SEETHALAKSHMI COMPLEX, 3'RD CROSS, JC ROAD, BLORE 02 |
| Thread Tools | |
Similar Threads | ||||
| LED lighting in cars | gigy | Technical Stuff | 86 | 7th September 2009 19:28 |
| MM550 rear lighting | bigman | 4x4 Vehicles | 24 | 25th August 2009 11:49 |
| HID lighting query re bulbs | whatcanthisbe | Modifications & Accessories | 19 | 16th December 2008 19:19 |
| Lighting Upgrade Help Needed | NikN | Technical Stuff | 8 | 18th February 2008 13:03 |
| Need Help for car lighting | mod_to_odd | Modifications & Accessories | 2 | 5th December 2007 05:13 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
